Hi, I plugged in a new BB to Linux Mint 18.1, the problem as in topic.
I attach the syslog. Any ideas?
Dec 23 19:12:10 mint kernel: [ 1390.005861] usb 2-1.6: new high-speed USB device number 13 using ehci-pci
Dec 23 19:12:10 mint kernel: [ 1390.099150] usb 2-1.6: New USB device found, idVendor=1d6b, idProduct=0104
Dec 23 19:12:10 mint kernel: [ 1390.099154] usb 2-1.6: New USB device strings: Mfr=2, Product=3, SerialNumber=4
Dec 23 19:12:10 mint kernel: [ 1390.099156] usb 2-1.6: Product: BeagleBoneBlack
Dec 23 19:12:10 mint kernel: [ 1390.099158] usb 2-1.6: Manufacturer: Circuitco
Dec 23 19:12:10 mint kernel: [ 1390.099160] usb 2-1.6: SerialNumber: A0-4816BBBK2EBD
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1239] device (eth0): failed to find device 5 ‘eth0’ with udev
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1251] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/4)
Dec 23 19:12:10 mint kernel: [ 1390.102922] rndis_host 2-1.6:1.0 eth0: register ‘rndis_host’ at usb-0000:00:1d.0-1.6, RNDIS device, 60:64:05:fe:ff:6b
Dec 23 19:12:10 mint kernel: [ 1390.103446] cdc_acm 2-1.6:1.2: ttyACM0: USB ACM device
Dec 23 19:12:10 mint kernel: [ 1390.103993] usb-storage 2-1.6:1.4: USB Mass Storage device detected
Dec 23 19:12:10 mint kernel: [ 1390.104108] scsi host8: usb-storage 2-1.6:1.4
Dec 23 19:12:10 mint mtp-probe: checking bus 2, device 13: “/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6”
Dec 23 19:12:10 mint mtp-probe: bus: 2, device: 13 was not an MTP device
Dec 23 19:12:10 mint kernel: [ 1390.116570] rndis_host 2-1.6:1.0 enx606405feff6b: renamed from eth0
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1586] device (eth0): interface index 5 renamed iface from ‘eth0’ to ‘enx606405feff6b’
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1629] devices added (path: /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.0/net/enx606405feff6b, iface: enx606405feff6b)
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1630] device added (path: /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.0/net/enx606405feff6b, iface: enx606405feff6b): no ifupdown configuration found.
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1634] device (enx606405feff6b): state change: unmanaged → unavailable (reason ‘managed’) [10 20 2]
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1639] device (enx606405feff6b): link connected
Dec 23 19:12:10 mint kernel: [ 1390.143135] IPv6: ADDRCONF(NETDEV_UP): enx606405feff6b: link is not ready
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1652] keyfile: add connection in-memory (b658715f-b7f9-3986-a744-cfbba6bd59be,“Wired connection 1”)
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1656] settings: (enx606405feff6b): created default wired connection ‘Wired connection 1’
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1672] device (enx606405feff6b): state change: unavailable → disconnected (reason ‘none’) [20 30 0]
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1678] policy: auto-activating connection ‘Wired connection 1’
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1686] device (enx606405feff6b): Activation: starting connection ‘Wired connection 1’ (b658715f-b7f9-3986-a744-cfbba6bd59be)
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1687] device (enx606405feff6b): state change: disconnected → prepare (reason ‘none’) [30 40 0]
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1690] device (enx606405feff6b): state change: prepare → config (reason ‘none’) [40 50 0]
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1692] device (enx606405feff6b): state change: config → ip-config (reason ‘none’) [50 70 0]
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1695] dhcp4 (enx606405feff6b): activation: beginning transaction (timeout in 45 seconds)
Dec 23 19:12:10 mint NetworkManager[1552]: [1482520330.1706] dhcp4 (enx606405feff6b): dhclient started with pid 4939
Dec 23 19:12:10 mint dhclient[4939]: DHCPREQUEST of 192.168.7.1 on enx606405feff6b to 255.255.255.255 port 67 (xid=0x4c673499)
Dec 23 19:12:10 mint colord-sane: [bjnp] create_broadcast_socket: ERROR - bind socket to local address failed - Cannot assign requested address
Dec 23 19:12:11 mint kernel: [ 1391.102720] scsi 8:0:0:0: Direct-Access Linux File-CD Gadget 0308 PQ: 0 ANSI: 2
Dec 23 19:12:11 mint kernel: [ 1391.103047] sd 8:0:0:0: Attached scsi generic sg7 type 0
Dec 23 19:12:11 mint kernel: [ 1391.104223] sd 8:0:0:0: [sdg] 196608 512-byte logical blocks: (101 MB/96.0 MiB)
Dec 23 19:12:11 mint kernel: [ 1391.104942] sd 8:0:0:0: [sdg] Write Protect is off
Dec 23 19:12:11 mint kernel: [ 1391.104946] sd 8:0:0:0: [sdg] Mode Sense: 0f 00 00 00
Dec 23 19:12:11 mint kernel: [ 1391.105580] sd 8:0:0:0: [sdg] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
Dec 23 19:12:11 mint kernel: [ 1391.108845] sdg:
Dec 23 19:12:11 mint kernel: [ 1391.111952] sd 8:0:0:0: [sdg] Attached SCSI removable disk
Dec 23 19:12:11 mint avahi-daemon[1554]: Joining mDNS multicast group on interface enx606405feff6b.IPv6 with address fe80::c48a:3113:9d4a:2580.
Dec 23 19:12:11 mint avahi-daemon[1554]: New relevant interface enx606405feff6b.IPv6 for mDNS.
Dec 23 19:12:11 mint avahi-daemon[1554]: Registering new address record for fe80::c48a:3113:9d4a:2580 on enx606405feff6b.*.
Dec 23 19:12:11 mint udisksd[2423]: Mounted /dev/sdg at /media/mint/BEAGLEBONE on behalf of uid 999
Dec 23 19:12:11 mint kernel: [ 1391.347548] FAT-fs (sdg): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Dec 23 19:12:12 mint ntpd[2894]: Listen normally on 10 enx606405feff6b [fe80::c48a:3113:9d4a:2580%5]:123
Dec 23 19:12:12 mint ntpd[2894]: new interface(s) found: waking up resolver
Dec 23 19:12:13 mint dhclient[4939]: DHCPREQUEST of 192.168.7.1 on enx606405feff6b to 255.255.255.255 port 67 (xid=0x4c673499)
Dec 23 19:12:13 mint dhclient[4939]: DHCPNAK from 192.168.7.2 (xid=0x9934674c)
Dec 23 19:12:13 mint NetworkManager[1552]: [1482520333.8024] dhcp4 (enx606405feff6b): state changed unknown → expire
Dec 23 19:12:13 mint NetworkManager[1552]: [1482520333.8058] dhcp4 (enx606405feff6b): state changed expire → unknown
Dec 23 19:12:13 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 3 (xid=0x7e9a4a4e)
Dec 23 19:12:16 mint dhclient[4939]: DHCPREQUEST of 192.168.7.1 on enx606405feff6b to 255.255.255.255 port 67 (xid=0x4e4a9a7e)
Dec 23 19:12:16 mint dhclient[4939]: DHCPOFFER of 192.168.7.1 from 192.168.7.2
Dec 23 19:12:19 mint dhclient[4939]: DHCPREQUEST of 192.168.7.1 on enx606405feff6b to 255.255.255.255 port 67 (xid=0x4e4a9a7e)
Dec 23 19:12:23 mint ModemManager[1568]: Creating modem with plugin ‘Generic’ and ‘2’ ports
Dec 23 19:12:23 mint ModemManager[1568]: Could not grab port (tty/ttyACM0): ‘Cannot add port ‘tty/ttyACM0’, unhandled serial type’
Dec 23 19:12:23 mint ModemManager[1568]: Couldn’t create modem for device at ‘/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6’: Failed to find primary AT port
Dec 23 19:12:27 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 3 (xid=0x6d8b650b)
Dec 23 19:12:30 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 7 (xid=0x6d8b650b)
Dec 23 19:12:37 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 14 (xid=0x6d8b650b)
Dec 23 19:12:51 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 18 (xid=0x6d8b650b)
Dec 23 19:13:09 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 8 (xid=0x6d8b650b)
Dec 23 19:13:17 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 13 (xid=0x6d8b650b)
Dec 23 19:13:30 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 10 (xid=0x6d8b650b)
Dec 23 19:13:40 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 7 (xid=0x6d8b650b)
Dec 23 19:13:47 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 8 (xid=0x6d8b650b)
Dec 23 19:13:55 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 11 (xid=0x6d8b650b)
Dec 23 19:14:06 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 13 (xid=0x6d8b650b)
Dec 23 19:14:19 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 15 (xid=0x6d8b650b)
Dec 23 19:14:34 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 13 (xid=0x6d8b650b)
Dec 23 19:14:47 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 17 (xid=0x6d8b650b)
Dec 23 19:15:04 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 9 (xid=0x6d8b650b)
Dec 23 19:15:13 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 12 (xid=0x6d8b650b)
Dec 23 19:15:25 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 15 (xid=0x6d8b650b)
Dec 23 19:15:40 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 10 (xid=0x6d8b650b)
Dec 23 19:15:51 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 11 (xid=0x6d8b650b)
Dec 23 19:16:02 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 13 (xid=0x6d8b650b)
Dec 23 19:16:15 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 9 (xid=0x6d8b650b)
Dec 23 19:16:24 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 11 (xid=0x6d8b650b)
Dec 23 19:16:35 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 7 (xid=0x6d8b650b)
Dec 23 19:16:42 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 15 (xid=0x6d8b650b)
Dec 23 19:16:57 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 9 (xid=0x6d8b650b)
Dec 23 19:17:01 mint CRON[5126]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Dec 23 19:17:06 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 15 (xid=0x6d8b650b)
Dec 23 19:17:21 mint dhclient[4939]: DHCPDISCOVER on enx606405feff6b to 255.255.255.255 port 67 interval 7 (xid=0x6d8b650b)
Dec 23 19:17:28 mint dhclient[4939]: No DHCPOFFERS received.
Dec 23 19:17:28 mint dhclient[4939]: No working leases in persistent database - sleeping.
Dec 23 19:17:28 mint NetworkManager[1552]: [1482520648.7546] dhcp4 (enx606405feff6b): state changed unknown → fail
Dec 23 19:17:28 mint NetworkManager[1552]: [1482520648.7867] dhcp4 (enx606405feff6b): canceled DHCP transaction, DHCP client pid 4939
Dec 23 19:17:28 mint NetworkManager[1552]: [1482520648.7867] dhcp4 (enx606405feff6b): state changed fail → done
Dec 23 19:17:28 mint NetworkManager[1552]: [1482520648.7871] device (enx606405feff6b): state change: ip-config → failed (reason ‘ip-config-unavailable’) [70 120 5]
Dec 23 19:17:28 mint NetworkManager[1552]: [1482520648.7875] device (enx606405feff6b): Activation: failed for connection ‘Wired connection 1’
Dec 23 19:17:28 mint NetworkManager[1552]: [1482520648.7883] device (enx606405feff6b): state change: failed → disconnected (reason ‘none’) [120 30 0]
