@RobertCNelson Thank you. I tried to upgrade kernel:
info: you are running: [4.19.94-ti-r66], latest is: [4.19.94-ti-r67] updating...
After upgrade kernel, I found the leds still not working … (I also tried update_kernel.sh again. )
Here is the console log :
Welcome to minicom 2.8
OPTIONS:
Compiled on Jan 4 2021, 00:04:27.
Port /dev/cu.usbserial-144110, 11:49:10
Press Meta-Z for help on special keys
[ 382.201069] watchdog: watchdog0: watchdog did not stop!
[ 382.601964] reboot: Restarting system
U-Boot SPL 2019.04-g047fc48 (Aug 05 2021 - 00:39:11 +0000)
Trying to boot from MMC2
Loading Environment from EXT4... Card did not respond to voltage select!
U-Boot 2019.04-g047fc48 (Aug 05 2021 - 00:39:11 +0000)
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
Reset Source: Global warm SW reset has occurred.
RTC 32KCLK Source: External.
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: BeagleBoard.org BeagleBone Black Wireless:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net: eth0: MII MODE
Could not get PHY for cpsw: addr 0
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[BBBW] ...
switch to partitions #0, OK
Scanning mmc 1:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
2000 bytes read in 12 ms (162.1 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.19.94-ti-r67 ...
10170880 bytes read in 660 ms (14.7 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/4.19.94-ti-r67/am335x-boneblack-uboot-univ.dtb ...
167492 bytes read in 35 ms (4.6 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r67/overlays/BB-ADC-00A0.dtbo ...
645 bytes read in 57 ms (10.7 KiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r67/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1605 bytes read in 58 ms (26.4 KiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r67/overlays/BB-HDMI-TDA998x-00A0.dtbo ...
5321 bytes read in 107 ms (47.9 KiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r67/overlays/BB-BBBW-WL1835-00A0.dtbo ...
3575 bytes read in 101 ms (34.2 KiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r67/overlays/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo ...
3627 bytes read in 118 ms (29.3 KiB/s)
loading /boot/initrd.img-4.19.94-ti-r67 ...
7864165 bytes read in 517 ms (14.5 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_qua.
debug: [bootz 0x82000000 0x88080000:77ff65 88000000] ...
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f880000, end 8fffff65 ... OK
Loading Device Tree to 8f7f3000, end 8f87ffff ... OK
Starting kernel ...
[ 0.002341] timer_probe: no matching timers found
[ 0.196603] l4_wkup_cm:clk:0010:0: failed to disable
[ 1.439824] pinctrl-single 44e10800.pinmux: pin PIN74 already requested by 481a6000.serial; cannot claim for leds
[ 1.450217] pinctrl-single 44e10800.pinmux: pin-74 (leds) status -22
[ 1.456632] pinctrl-single 44e10800.pinmux: could not request pin 74 (PIN74) from group pinmux_bt_pins on device pinctrl-single
[ 1.468273] leds-gpio leds: Error applying setting, reverse things back
[ 1.572941] omap_voltage_late_init: Voltage driver support not added
rootfs: clean, 97209/233392 files, 581406/932864 blocks
Debian GNU/Linux 10 beaglebone ttyS0
BeagleBoard.org Debian Buster IoT Image 2021-08-09
Support: https://bbb.io/debian
beaglebone login:
This is dmesg :
debian@beaglebone:~$ dmesg
[ 0.000000] Linux version 4.19.94-ti-r67 (voodoo@x1-am57xx-beagle-x15-2gb) (gcc version 8.3.0 (Debian 8.3.0-6)) #1buster SMP PREEMPT Wed Sep 15 22:54:22 UTC 2021
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black Wireless
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] On node 0 totalpages: 130560
[ 0.000000] Normal zone: 1148 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 130560 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x4c0 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s38988 r8192 d22452 u69632
[ 0.000000] pcpu-alloc: s38988 r8192 d22452 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
[ 0.000000] Kernel command line: console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=t
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 437124K/522240K available (13312K kernel code, 1142K rwdata, 4344K rodata, 1024K init, 350K bss, 35964K reserved, 49152K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0000000 - 0xff800000 ( 504 MB)
lowmem : 0xc0000000 - 0xdfe00000 ( 510 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (14304 kB)
.init : 0x(ptrval) - 0x(ptrval) (1024 kB)
.data : 0x(ptrval) - 0x(ptrval) (1143 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 351 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 42219 entries in 124 pages
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000027] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000045] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000056] OMAP clocksource: timer1 at 24000000 Hz
[ 0.002688] Console: colour dummy device 80x30
[ 0.002774] Calibrating delay loop (skipped) preset value.. 995.32 BogoMIPS (lpj=1990656)
[ 0.002792] pid_max: default: 32768 minimum: 301
[ 0.003078] Security Framework initialized
[ 0.003092] Yama: becoming mindful.
[ 0.003239] AppArmor: AppArmor initialized
[ 0.003351] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.003363] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.004448] CPU: Testing write buffer coherency: ok
[ 0.004513] CPU0: Spectre v2: using BPIALL workaround
[ 0.005086] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.029117] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.037025] rcu: Hierarchical SRCU implementation.
[ 0.048261] EFI services will not be available.
[ 0.053031] smp: Bringing up secondary CPUs ...
[ 0.053044] smp: Brought up 1 node, 1 CPU
[ 0.053056] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.053062] CPU: All CPU(s) started in SVC mode.
[ 0.054788] devtmpfs: initialized
[ 0.089432] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.090078] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.090106] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.094057] xor: automatically using best checksumming function neon
[ 0.094074] pinctrl core: initialized pinctrl subsystem
[ 0.095398] NET: Registered protocol family 16
[ 0.100547] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.236922] audit: initializing netlink subsys (disabled)
[ 0.241136] audit: type=2000 audit(0.232:1): state=initialized audit_enabled=0 res=1
[ 0.246327] OMAP GPIO hardware version 0.1
[ 0.249451] GPIO line 106 (LS_BUF_EN) hogged as output/high
[ 0.270243] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.297176] raid6: using algorithm neonx8 gen() 0 MB/s
[ 0.297189] raid6: .... xor() 0 MB/s, rmw enabled
[ 0.297196] raid6: using neon recovery algorithm
[ 0.305255] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.312933] SCSI subsystem initialized
[ 0.317142] libata version 3.00 loaded.
[ 0.317478] usbcore: registered new interface driver usbfs
[ 0.317536] usbcore: registered new interface driver hub
[ 0.317657] usbcore: registered new device driver usb
[ 0.319677] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.321220] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.321797] pps_core: LinuxPPS API ver. 1 registered
[ 0.321805] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.321831] PTP clock support registered
[ 0.322744] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.325419] Advanced Linux Sound Architecture Driver Initialized.
[ 0.326264] NetLabel: Initializing
[ 0.326276] NetLabel: domain hash size = 128
[ 0.326280] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.326368] NetLabel: unlabeled traffic allowed by default
[ 0.327444] clocksource: Switched to clocksource timer1
[ 0.490003] VFS: Disk quotas dquot_6.6.0
[ 0.490117] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.490979] AppArmor: AppArmor Filesystem Enabled
[ 0.503983] NET: Registered protocol family 2
[ 0.504992] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.505027] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.505069] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.505127] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.505264] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.505287] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.505647] NET: Registered protocol family 1
[ 0.518834] RPC: Registered named UNIX socket transport module.
[ 0.518844] RPC: Registered udp transport module.
[ 0.518850] RPC: Registered tcp transport module.
[ 0.518855] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.519886] Unpacking initramfs...
[ 0.981775] Freeing initrd memory: 7680K
[ 0.982637] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.985872] Initialise system trusted keyrings
[ 0.986283] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.993471] zbud: loaded
[ 1.000948] NFS: Registering the id_resolver key type
[ 1.000992] Key type id_resolver registered
[ 1.000998] Key type id_legacy registered
[ 1.001017] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.001371] fuse init (API version 7.27)
[ 1.011886] Key type asymmetric registered
[ 1.011900] Asymmetric key parser 'x509' registered
[ 1.012007] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.015475] random: fast init done
[ 1.016378] io scheduler noop registered
[ 1.016386] io scheduler deadline registered
[ 1.016699] io scheduler cfq registered (default)
[ 1.016709] io scheduler mq-deadline registered
[ 1.020371] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 1.033433] gpio-of-helper ocp:cape-universal: ready
[ 1.044680] gpio-clk: probe of ocp:clk_mcasp0 failed with error -17
[ 1.047263] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.050880] console [ttyS0] disabled
[ 1.050989] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[ 1.061091] console [ttyS0] enabled
[ 1.062275] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[ 1.063275] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 32, base_baud = 3000000) is a 8250
[ 1.064542] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 33, base_baud = 3000000) is a 8250
[ 1.064780] serial serial0: tty port ttyS3 registered
[ 1.065381] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 34, base_baud = 3000000) is a 8250
[ 1.066355] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 35, base_baud = 3000000) is a 8250
[ 1.070030] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 1.070977] sdhci: Secure Digital Host Controller Interface driver
[ 1.070985] sdhci: Copyright(c) Pierre Ossman
[ 1.071755] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 1.071766] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.072360] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.2
[ 1.073029] random: crng init done
[ 1.096969] omap_hsmmc 481d8000.mmc: Linked as a consumer to regulator.2
[ 1.123612] omap_hsmmc 47810000.mmc: Linked as a consumer to regulator.1
[ 1.167522] mmc1: new high speed MMC card at address 0001
[ 1.172932] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 1.173559] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[ 1.174171] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[ 1.174519] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB, chardev (245:0)
[ 1.180450] mmcblk1: p1
[ 1.229370] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.241376] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
[ 1.253867] mmc2: new high speed SDIO card at address 0001
[ 1.354633] eqep 48300180.eqep: ver. 1.0
[ 1.354866] eqep 48300180.eqep: count_mode:0
[ 1.354878] eqep 48300180.eqep: invert_qa:1
[ 1.354887] eqep 48300180.eqep: invert_qb:1
[ 1.354896] eqep 48300180.eqep: invert_qi:0
[ 1.354904] eqep 48300180.eqep: invert_qs:0
[ 1.354912] eqep 48300180.eqep: swap_inputs:0
[ 1.354922] eqep 48300180.eqep: QDECCTL:0x0180
[ 1.354930] eqep 48300180.eqep: QPOSINIT:0x00000000
[ 1.354937] eqep 48300180.eqep: QPOSMAX:0xffffffff
[ 1.354944] eqep 48300180.eqep: QPOSCNT:0x00000000
[ 1.354952] eqep 48300180.eqep: omit_interrupt:0
[ 1.354959] eqep 48300180.eqep: QEINT:0x0800
[ 1.354967] eqep 48300180.eqep: QUPRD:0x05f5e100
[ 1.354974] eqep 48300180.eqep: QEPCTL:0x009e write
[ 1.354981] eqep 48300180.eqep: QEPCTL:0x009e read
[ 1.355007] eqep 48300180.eqep: irq:134, clk_rate:100000000
[ 1.355301] eqep 48302180.eqep: ver. 1.0
[ 1.355621] eqep 48302180.eqep: count_mode:0
[ 1.355632] eqep 48302180.eqep: invert_qa:1
[ 1.355640] eqep 48302180.eqep: invert_qb:1
[ 1.355648] eqep 48302180.eqep: invert_qi:0
[ 1.355656] eqep 48302180.eqep: invert_qs:0
[ 1.355663] eqep 48302180.eqep: swap_inputs:0
[ 1.355671] eqep 48302180.eqep: QDECCTL:0x0180
[ 1.355679] eqep 48302180.eqep: QPOSINIT:0x00000000
[ 1.355686] eqep 48302180.eqep: QPOSMAX:0xffffffff
[ 1.355693] eqep 48302180.eqep: QPOSCNT:0x00000000
[ 1.355701] eqep 48302180.eqep: omit_interrupt:0
[ 1.355708] eqep 48302180.eqep: QEINT:0x0800
[ 1.355716] eqep 48302180.eqep: QUPRD:0x05f5e100
[ 1.355723] eqep 48302180.eqep: QEPCTL:0x009e write
[ 1.355730] eqep 48302180.eqep: QEPCTL:0x009e read
[ 1.355754] eqep 48302180.eqep: irq:136, clk_rate:100000000
[ 1.355987] eqep 48304180.eqep: ver. 1.0
[ 1.356152] eqep 48304180.eqep: count_mode:0
[ 1.356162] eqep 48304180.eqep: invert_qa:1
[ 1.356170] eqep 48304180.eqep: invert_qb:1
[ 1.356178] eqep 48304180.eqep: invert_qi:0
[ 1.356186] eqep 48304180.eqep: invert_qs:0
[ 1.356193] eqep 48304180.eqep: swap_inputs:0
[ 1.356201] eqep 48304180.eqep: QDECCTL:0x0180
[ 1.356209] eqep 48304180.eqep: QPOSINIT:0x00000000
[ 1.356216] eqep 48304180.eqep: QPOSMAX:0xffffffff
[ 1.356223] eqep 48304180.eqep: QPOSCNT:0x00000000
[ 1.356231] eqep 48304180.eqep: omit_interrupt:0
[ 1.356238] eqep 48304180.eqep: QEINT:0x0800
[ 1.356245] eqep 48304180.eqep: QUPRD:0x05f5e100
[ 1.356252] eqep 48304180.eqep: QEPCTL:0x009e write
[ 1.356260] eqep 48304180.eqep: QEPCTL:0x009e read
[ 1.356279] eqep 48304180.eqep: irq:138, clk_rate:100000000
[ 1.397029] libphy: Fixed MDIO Bus: probed
[ 1.398000] CAN device driver interface
[ 1.399612] c_can_platform 481cc000.can: c_can_platform device registered (regs=72e301b5, irq=43)
[ 1.400741] c_can_platform 481d0000.can: c_can_platform device registered (regs=7eee952c, irq=44)
[ 1.402684] usbcore: registered new interface driver smsc95xx
[ 1.404465] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.404532] ehci-platform: EHCI generic platform driver
[ 1.404905] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.405847] usbcore: registered new interface driver usb-storage
[ 1.409322] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[ 1.409513] am335x-phy-driver 47401300.usb-phy: Linked as a consumer to regulator.0
[ 1.413103] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 1.413265] am335x-phy-driver 47401b00.usb-phy: Linked as a consumer to regulator.0
[ 1.416762] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 1.416813] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 1.417146] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.417157] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.417164] usb usb1: Product: MUSB HDRC host driver
[ 1.417172] usb usb1: Manufacturer: Linux 4.19.94-ti-r67 musb-hcd
[ 1.417179] usb usb1: SerialNumber: musb-hdrc.1
[ 1.417984] hub 1-0:1.0: USB hub found
[ 1.418060] hub 1-0:1.0: 1 port detected
[ 1.429982] omap_rtc 44e3e000.rtc: already running
[ 1.430670] omap_rtc 44e3e000.rtc: registered as rtc0
[ 1.432473] i2c /dev entries driver
[ 1.436588] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.437199] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 1.475009] leds-gpio: probe of leds failed with error -22
[ 1.475258] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.475871] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.476212] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 1.478809] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.482753] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.490623] gnss: GNSS driver registered with major 242
[ 1.500800] NET: Registered protocol family 10
[ 1.571979] Segment Routing with IPv6
[ 1.572135] mip6: Mobile IPv6
[ 1.572308] NET: Registered protocol family 17
[ 1.572337] can: controller area network core (rev 20170425 abi 9)
[ 1.572424] NET: Registered protocol family 29
[ 1.572520] 8021q: 802.1Q VLAN Support v1.8
[ 1.572598] Key type dns_resolver registered
[ 1.572605] mpls_gso: MPLS GSO support
[ 1.572915] ThumbEE CPU extension supported.
[ 1.572930] Registering SWP/SWPB emulation handler
[ 1.581167] registered taskstats version 1
[ 1.581178] Loading compiled-in X.509 certificates
[ 1.581314] zswap: loaded using pool lzo/zbud
[ 1.584796] Btrfs loaded, crc32c=crc32c-generic
[ 1.584910] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.750306] tda998x 0-0070: found TDA19988
[ 1.754612] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops)
[ 1.754640] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.754646] [drm] No driver support for vblank timestamp query.
[ 1.814166] Console: switching to colour frame buffer device 160x64
[ 1.821770] tilcdc 4830e000.lcdc: fb0: DRM emulated frame buffer device
[ 1.822652] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[ 1.836921] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[ 1.837777] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 1.838715] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.839761] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.839881] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.844416] cpu cpu0: Linked as a consumer to regulator.4
[ 1.844524] cpu cpu0: Dropping the link to regulator.4
[ 1.845021] cpu cpu0: Linked as a consumer to regulator.4
[ 1.848373] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[ 1.850439] omap_rtc 44e3e000.rtc: setting system clock to 2021-09-16 03:49:36 UTC (1631764176)
[ 1.852208] ALSA device list:
[ 1.852224] #0: TI BeagleBone Black
[ 1.858710] Freeing unused kernel memory: 1024K
[ 1.859523] Run /init as init process
[ 19.205357] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 19.884918] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +B)
[ 19.885676] systemd[1]: Detected architecture arm.
[ 19.909314] systemd[1]: Set hostname to <beaglebone>.
[ 21.386404] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 21.388289] systemd[1]: Listening on Journal Socket (/dev/log).
[ 21.388972] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 21.390172] systemd[1]: Listening on udev Control Socket.
[ 21.396832] systemd[1]: Listening on Syslog Socket.
[ 21.397656] systemd[1]: Listening on udev Kernel Socket.
[ 21.398855] systemd[1]: Listening on Journal Audit Socket.
[ 22.415234] EXT4-fs (mmcblk1p1): re-mounted. Opts: errors=remount-ro
[ 23.456656] systemd-journald[942]: Received request to flush runtime journal from PID 1
[ 33.767628] wlan-en-regulator: disabling
[ 34.379135] using random self ethernet address
[ 34.379155] using random host ethernet address
[ 34.857871] Mass Storage Function, version: 2009/09/11
[ 34.857896] LUN: removable file: (no medium)
[ 35.218434] using random self ethernet address
[ 35.218453] using random host ethernet address
[ 35.460073] usb0: HOST MAC f4:5e:ab:6a:1e:c3
[ 35.464451] usb0: MAC f4:5e:ab:6a:1e:c2
[ 35.483974] usb1: HOST MAC f4:5e:ab:6a:1e:c5
[ 35.484276] usb1: MAC f4:5e:ab:6a:1e:c6
[ 35.717503] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 36.004868] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 55.116464] Bluetooth: Core ver 2.22
[ 55.116629] NET: Registered protocol family 31
[ 55.116637] Bluetooth: HCI device and connection manager initialized
[ 55.116667] Bluetooth: HCI socket layer initialized
[ 55.116679] Bluetooth: L2CAP socket layer initialized
[ 55.116740] Bluetooth: SCO socket layer initialized
[ 55.363215] Bluetooth: HCI UART driver ver 2.3
[ 55.363235] Bluetooth: HCI UART protocol H4 registered
[ 55.452469] Bluetooth: HCI UART protocol LL registered
[ 55.452486] Bluetooth: HCI UART protocol ATH3K registered
[ 55.463349] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 55.484291] Bluetooth: hci0: change remote baud rate command in firmware
[ 66.208918] pvrsrvkm: loading out-of-tree module taints kernel.
[ 66.584277] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.sgx on minor 1
[ 71.431176] remoteproc remoteproc0: wkup_m3 is available
[ 71.539737] remoteproc remoteproc0: powering up wkup_m3
[ 71.539772] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 71.540070] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 71.540099] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 71.641914] PM: bootloader does not support rtc-only!
[ 74.672756] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 74.672768] Bluetooth: BNEP filters: protocol multicast
[ 74.672796] Bluetooth: BNEP socket layer initialized
[ 75.363750] Bluetooth: RFCOMM TTY layer initialized
[ 75.363793] Bluetooth: RFCOMM socket layer initialized
[ 75.363859] Bluetooth: RFCOMM ver 1.11
[ 75.911805] remoteproc remoteproc1: 4a334000.pru is available
[ 75.911967] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[ 75.915015] remoteproc remoteproc2: 4a338000.pru is available
[ 75.915196] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
[ 76.711020] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 76.724810] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 77.772583] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 77.801484] wlcore: loaded
[ 78.372621] wlcore: PHY firmware version: Rev 8.2.0.0.245
[ 78.420148] wlcore: firmware booted (Rev 8.9.0.0.88)
[ 78.435930] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 78.951399] IPv6: ADDRCONF(NETDEV_UP): SoftAp0: link is not ready
[ 79.772340] wlan0: authenticate with 40:b0:76:34:16:98
[ 79.783516] wlan0: send auth to 40:b0:76:34:16:98 (try 1/3)
[ 79.812355] wlan0: authenticated
[ 79.818103] wlan0: associate with 40:b0:76:34:16:98 (try 1/3)
[ 79.822985] wlan0: RX AssocResp from 40:b0:76:34:16:98 (capab=0x1411 status=0 aid=8)
[ 79.841039] wlan0: associated
[ 80.125640] cryptd: max_cpu_qlen set to 1000
[ 80.248473] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 80.277566] wlcore: Association completed.
[ 80.774409] wlcore: down
[ 80.839140] IPv6: ADDRCONF(NETDEV_CHANGE): SoftAp0: link becomes ready
Thanks for your help.
