I want to use the RT linux for my project. so i was trying a sample program. But few error i can’t build the code. below i given my step
First i prepared the RT linux patch from below link
https://www.digikey.com/eewiki/display/linuxonarm/BeagleBone+Black, here i choose “For am33x-rt-v5.4 (Longterm 5.4.x + Real-Time Linux):” kernel
RT linux was booting i can able to run simple program such as thread. And i cross check in .menu config also High resolution timer was enabled.
then i downloaded the linux-headers -$(uname -r)
Once the simple program work i was trying the RT linux example from below link
https://tldp.org/HOWTO/RTLinux-HOWTO-4.html
to compile the above program i need rtl.mk, rtl.h …I checked in whole directory ,not able to find.
there is some script called “rtl-config”, which generate the rtl.mk , i can’t able to find that file too
Refer rtl-config in link: http://cs.uccs.edu/~cchow/pub/rtl/doc/html/MAN/rtl-config.1.html
I want to locate rtl.mk.
Let me anyone have done this, thanks in advance.
Regards
Deva
