Not able to login to the beagle bone black using SSH
I am new to the Beagle bone black and trying to work on beagle bone black. after flashing the new software image to the BBB , i am not able to login to the BBB using SSH.
if i checked the IP address using ifconfig it is giving two ip address :
192.168.6.2
192.168.7.2
here we can see the two ip addess .
if i used to login the board using :
sudo SSH debian@192.168.6.2
but it is showing connection refused…
how to login to the board using that ip addresses?? please help me to resolve this
in the picture it is : 192.168.6.1 and 192.168.7.1
i tried login with same ip address it is showing connection refused
On Fri, 19 Jul 2019 03:49:19 -0700 (PDT), Megha Bhirade
<meghsbhirade@gmail.com> declaimed the
following:
[image: ipadressof bbb.png] <about:invalid#zClosurez>
  Please don't insert IMAGES -- it's a text window, just cut&paste the
TEXT.
but it is showing connection refused..
resolve this
  Short answer: YOU DON'T
  Longer answer: 192.168.7.1 is YOUR MACHINE's end, not the BBB end.
(192.168.6.1 is the IP Macintosh systems see, Windows only sees 192.168.7.1
-- Linux may activate on both).
  The BBB will be found at 192.168.7.2
  Observe (and this is a cut&paste of the TEXT IN THE CONSOLE):
hi,
i used ssh debian@beaglebone.local, it is login to board fine
