For some reason, I cannot close my USB device in /dev/. Is this a source code error on my part or is it a known issue with the BeagleY-AI?
Oh. Here is the source code:
// Found here: https://www.pololu.com/docs/0J44/6.7.3 but their site is goofed
// So, trying other avenues
// Uses POSIX functions to send and receive data from the virtual serial
// port of a Pololu Simple Motor Controller.
// NOTE: The Simple Motor Controller's Input Mode must be set to Serial/USB.
// NOTE: You must change the 'const char * device' line below.
#include <fcntl.h>
#include <stdio.h>
#include <unistd.h>
#include <signal.h>
#include <stdlib.h>
#ifdef _WIN32
#define O_NOCTTY 0
#else
#include <termios.h>
#endif
#define SERIAL_ERROR -9999
// Reads a variable from the SMC and returns it as number between 0 and 65535.
// Returns SERIAL_ERROR if there was an error.
// The 'variableId' argument must be one of IDs listed in the
// "Controller Variables" section of the user's guide.
// For variables that are actually signed, additional processing is required
// (see smcGetTargetSpeed for an example).
int smcGetVariable(int fd, unsigned char variableId)
unsigned char command[] = {0xA1, variableId};
if(write(fd, &command, sizeof(command)) == -1)
perror("error writing");
return SERIAL_ERROR;
unsigned char response[2];
if(read(fd,response,2) != 2)
perror("error reading");
return response[0] + 256 * response[1];
// Returns the target speed (-3200 to 3200).
// Returns SERIAL_ERROR if there is an error.
int smcGetTargetSpeed(int fd)
int val = smcGetVariable(fd, 20);
return val == SERIAL_ERROR ? SERIAL_ERROR : (signed short)val;
// Returns a number where each bit represents a different error, and the
// bit is 1 if the error is currently active.
// See the user's guide for definitions of the different error bits.
int smcGetErrorStatus(int fd)
return smcGetVariable(fd, 0);
// Sends the Exit Safe Start command, which is required to drive the motor.
// Returns 0 if successful, SERIAL_ERROR if there was an error sending.
int smcExitSafeStart(int fd)
const unsigned char command = 0x83;
if (write(fd, &command, 1) == -1)
return 0;
// Sets the SMC's target speed (-3200 to 3200).
int smcSetTargetSpeed(int fd, int speed)
unsigned char command[3];
if (speed < 0)
command[0] = 0x86; // Motor Reverse
speed = -speed;
else
command[0] = 0x85; // Motor Forward
command[1] = speed & 0x1F;
command[2] = speed >> 5 & 0x7F;
if (write(fd, command, sizeof(command)) == -1)
return 0;
void intHandler(int) {
fprintf(stderr, "\nintHandler called\n");
exit(0);
int get(int argc, char** argv) {
__sighandler_t rc;
rc = signal(SIGINT, intHandler); // catches ctrl c
if (rc == SIG_ERR) {
perror("SIGINT error");
rc = signal(SIGTERM, intHandler); // catches kill commands
perror("SIGTERM error");
int main()
// Open the Simple Motor Controller's virtual COM port.
const char * device = "/dev/ttyACM0"; // Linux
//const char * device = "\\\\.\\COM6"; // Windows
//const char * device = "/dev/cu.usbmodemfa121"; // Mac OS X
int fd = open(device, O_RDWR | O_NOCTTY);
if (fd == -1)
perror(device);
return 1;
#ifdef _WIN32
_setmode(fd, _O_BINARY);
#else
struct termios options;
tcgetattr(fd, &options);
options.c_iflag &= ~(INLCR | IGNCR | ICRNL | IXON | IXOFF);
options.c_oflag &= ~(ONLCR | OCRNL);
options.c_lflag &= ~(ECHO | ECHONL | ICANON | ISIG | IEXTEN);
tcsetattr(fd, TCSANOW, &options);
#endif
smcExitSafeStart(fd);
printf("Error status: 0x%04x\n", smcGetErrorStatus(fd));
int speed = smcGetTargetSpeed(fd);
printf("Current Target Speed is %d.\n", speed);
int newSpeed = (speed <= 0) ? 3200 : -3200;
printf("Setting Target Speed to %d.\n", newSpeed);
smcSetTargetSpeed(fd, newSpeed);
close(fd);
close(get == 0);
perror("Cannot close now...\n");
return 0;
Any advice is welcomed. Even where to look online for specifics is welcomed. My research is shotty now.
