Once Again I am Here,
Sensors — BeagleBoard Documentation
So far, I think this photo is a bit off. There is an empty PWR (3.3v) populating the breadboard…
- One would think 3.3v is needed to power the rotary dial.
- I will test this idea soon so I can be sure, i.e. as I do not mess w/ rotary dials much so far.
- If you use rotary dials a lot or some in the past too, please chime in.
P.S. After testing w/ a purchased rotary dial, a particular dial in general, I will update the docs. so people do not 3.3v the breadboard w/out it leading to some part of the dial. It is a floating 3.3v so far.
Update
#!/usr/bin/env python
# // This uses the eQEP hardware to read a rotary encoder
# // bone$ config-pin P8_11 eqep
# // bone$ config-pin P8_12 eqep
import time
eQEP = '2'
COUNTERPATH = '/dev/bone/counter/counter'+eQEP+'/count0'
ms = 100 # Time between samples in ms
maxCount = '1000000'
# Set the eEQP maximum count
f = open(COUNTERPATH+'/ceiling', 'w')
f.write(maxCount)
f.close()
# Enable
f = open(COUNTERPATH+'/enable', 'w')
f.write('1')
f.close()
f = open(COUNTERPATH+'/count', 'r')
olddata = -1
while True:
f.seek(0)
data = f.read()[:-1]
# Print only if data changes
if data != olddata:
olddata = data
print("data = " + data)
time.sleep(ms/1000)
# Black OR Pocket
# eQEP0: P9.27 and P9.42 OR P1_33 and P2_34
# eQEP1: P9.33 and P9.35
# eQEP2: P8.11 and P8.12 OR P2_24 and P2_33
# AI
# eQEP1: P8.33 and P8.35
# eQEP2: P8.11 and P8.12 or P9.19 and P9.41
# eQEP3: P8.24 and P8.25 or P9.27 and P9.42
The above source is for the rotary dial or encoder which a eQEP pin can handle…
I just tested the source w/ a “near” perfect dial but used a trim potentiometer instead. It worked. I had to change the source a bit… Can you see where the source is a bit off?
