Hi I am trying to build a fresh Angstrom image using OE, from what it
seems the required revision being asked for in the recipe does not
exost as of now (verified from the browser):
http://www.angstrom-distribution.org/unstable/sources/git_arago-project.org.git.people.sriram.ti-psp-omap.git_a6bad4464f985fdd3bed72e1b82dcbfc004d7869.tar.gz
Any hints will be appreciated ? Not able to build for now.
Vijay
Seems like the revision got cutoff, here it is again:
That's a source mirror, which get tried first before hitting the (overloaded) arago servers. So it if isn't present it will fetch it from the arago servers using git. So double check your git config
regards,
Koen
git config for OE under conf/site.conf ? Is that correct ?
VIjay
