please follow the README when sending patches, this is the wrong list
+angstrom-distro-devel
corrected my typo of beagleboard list name
oe-core list moved to BCC to avoid additional follow-up
secondly, use the patches from the export/ directory, they have much less cruft in them
Should I include the bias patches that are there now? I'm not sure
what cruft you are highlighting.
The following changes since commit c6251231c603256eff6ccd0181c20bb182f9e03b:
gstreamer-ti: use MEMARGS variable instead of hardcoding omap3
config (2011-09-16 16:04:42 +0200)
are available in the git repository at:
git://github.com/jadonk/meta-texasinstruments.git for-koen
Jason Kridner (1):
[meta-ti] linux-3.0: use die-id for BeagleBoard-xM eth mac
...e-add-support-for-beagleboard-xM-revision.patch | 6 +-
...OMAP3-beagle-add-support-for-expansionboa.patch | 6 +-
...0003-HACK-OMAP3-beagle-switch-to-GPTIMER1.patch | 6 +-
.../0004-OMAP3-beagle-HACK-add-in-1GHz-OPP.patch | 6 +-
...5-omap3-Add-basic-support-for-720MHz-part.patch | 6 +-
...Set-dto-to-max-value-of-14-to-avoid-SD-Ca.patch | 33 ++++
...add-cpu-id-register-to-MAC-address-helper.patch | 89 ++++++++++
...BeagleBoard-Fix-up-random-or-missing-MAC-.patch | 156 ++++++++++++++++++
...3630-PRM-add-ABB-PRM-register-definitions.patch | 4 +-
...P3-PM-VP-generalize-PRM-interrupt-helpers.patch | 4 +-
...P3-PRM-add-tranxdone-IRQ-handlers-for-ABB.patch | 4 +-
...P3-ABB-Adaptive-Body-Bias-structures-data.patch | 4 +-
...-OMAP3-OPP-add-ABB-data-to-voltage-tables.patch | 4 +-
...3-Voltage-add-ABB-data-to-voltage-domains.patch | 4 +-
...3-ABB-initialization-transition-functions.patch | 4 +-
...-OMAP3-Voltage-add-ABB-to-voltage-scaling.patch | 4 +-
...01-Enabling-Hwmon-driver-for-twl4030-madc.patch | 4 +-
.../madc/0002-mfd-twl-core-enable-madc-clock.patch | 4 +-
...nking-error-in-twl-common.c-for-OMAP2-3-4.patch | 4 +-
...-introduce-function-to-free-cpufreq-table.patch | 6 +-
...q-ensure-driver-initializes-after-cpufreq.patch | 4 +-
...PUfreq-ensure-policy-is-fully-initialized.patch | 4 +-
.../0004-OMAP3-PM-CPUFreq-driver-for-OMAP3.patch | 4 +-
...AP-PM-CPUFREQ-Fix-conditional-compilation.patch | 4 +-
...-cpufreq-fixup-after-new-OPP-layer-merged.patch | 4 +-
...q-Split-OMAP1-and-OMAP2PLUS-CPUfreq-drive.patch | 4 +-
...cpufreq-Add-SMP-support-to-cater-OMAP4430.patch | 4 +-
...pufreq-Fix-typo-when-attempting-to-set-mp.patch | 4 +-
...P2-cpufreq-move-clk-name-decision-to-init.patch | 4 +-
...-cpufreq-deny-initialization-if-no-mpudev.patch | 4 +-
...012-OMAP2-cpufreq-dont-support-freq_table.patch | 4 +-
...3-OMAP2-cpufreq-only-supports-OPP-library.patch | 4 +-
...-OMAP2-cpufreq-put-clk-if-cpu_init-failed.patch | 4 +-
.../0015-OMAP2-cpufreq-fix-freq_table-leak.patch | 4 +-
...eq-Remove-superfluous-check-in-target-for.patch | 4 +-
...ufreq-notify-even-with-bad-boot-frequency.patch | 4 +-
...req-Enable-all-CPUs-in-shared-policy-mask.patch | 4 +-
...eq-update-lpj-with-reference-value-to-avo.patch | 4 +-
...egulator-supply-definitions-in-mach-omap2.patch | 4 +-
...style-supply.dev-assignments-common-in-hs.patch | 4 +-
...parate-init_irq-functions-to-avoid-cpu_is.patch | 6 +-
...parate-timer-init-functions-to-avoid-cpu_.patch | 8 +-
...05-omap-Move-dmtimer-defines-to-dmtimer.h.patch | 4 +-
...-subset-of-dmtimer-functions-into-inline-.patch | 4 +-
...7-omap2-Use-dmtimer-macros-for-clockevent.patch | 4 +-
.../0008-omap2-Remove-gptimer_wakeup-for-now.patch | 4 +-
...OMAP3-SR-make-notify-independent-of-class.patch | 4 +-
...010-OMAP3-SR-disable-interrupt-by-default.patch | 4 +-
...1-OMAP3-SR-enable-disable-SR-only-on-need.patch | 4 +-
.../0012-OMAP3-SR-fix-cosmetic-indentation.patch | 4 +-
...ve-clocksource-and-timesource-and-initial.patch | 4 +-
...-omap2-Use-dmtimer-macros-for-clocksource.patch | 4 +-
...p2-Remove-omap2_gp_clockevent_set_gptimer.patch | 4 +-
...e-timer-gp.c-into-timer.c-to-combine-time.patch | 4 +-
.../0017-omap-cleanup-NAND-platform-data.patch | 4 +-
...omap-board-omap3evm-Fix-compilation-error.patch | 4 +-
.../0019-omap-mcbsp-Drop-SPI-mode-support.patch | 4 +-
...map-mcbsp-Drop-in-driver-transfer-support.patch | 4 +-
.../voltdm/0021-omap2-fix-build-regression.patch | 4 +-
...w-twl-common-for-common-TWL-configuration.patch | 6 +-
...common-twl6030-configuration-to-twl-commo.patch | 4 +-
...ve-common-twl-configuration-to-twl-common.patch | 4 +-
...common-regulator-configuration-to-twl-com.patch | 4 +-
...mcbsp-Remove-rx_-tx_word_length-variables.patch | 4 +-
.../0027-omap-mcbsp-Remove-port-number-enums.patch | 4 +-
.../0028-OMAP-dmtimer-add-missing-include.patch | 4 +-
...P2-hwmod-Fix-smart-standby-wakeup-support.patch | 4 +-
...4-hwmod-data-Add-MSTANDBY_SMART_WKUP-flag.patch | 4 +-
...-Enable-module-in-shutdown-to-access-sysc.patch | 4 +-
...-Do-not-write-the-enawakeup-bit-if-SYSC_H.patch | 4 +-
...wmod-Remove-_populate_mpu_rt_base-warning.patch | 4 +-
...4-OMAP2-hwmod-Fix-the-HW-reset-management.patch | 4 +-
...-OMAP-hwmod-Add-warnings-if-enable-failed.patch | 4 +-
...-Move-pr_debug-to-improve-the-readability.patch | 4 +-
...use-a-null-structure-record-to-terminate-.patch | 4 +-
...share-identical-omap_hwmod_addr_space-arr.patch | 4 +-
...use-a-terminator-record-with-omap_hwmod_m.patch | 4 +-
...share-identical-omap_hwmod_mpu_irqs-array.patch | 4 +-
...use-a-terminator-record-with-omap_hwmod_d.patch | 4 +-
...share-identical-omap_hwmod_dma_info-array.patch | 4 +-
...share-identical-omap_hwmod_class-omap_hwm.patch | 4 +-
...-data-Fix-L3-interconnect-data-order-and-.patch | 4 +-
...-OMAP4-hwmod-data-Remove-un-needed-parens.patch | 4 +-
.../0046-OMAP4-hwmod-data-Fix-bad-alignement.patch | 4 +-
...-data-Align-interconnect-format-with-regu.patch | 4 +-
...48-OMAP4-clock-data-Add-sddiv-to-USB-DPLL.patch | 4 +-
...-data-Remove-usb_host_fs-clkdev-with-NULL.patch | 4 +-
...-data-Re-order-some-clock-nodes-and-struc.patch | 4 +-
...ck-data-Fix-max-mult-and-div-for-USB-DPLL.patch | 4 +-
...OMAP4-prcm-Fix-errors-in-few-defines-name.patch | 4 +-
...MAP4-prm-Remove-wrong-clockdomain-offsets.patch | 4 +-
...54-OMAP4-powerdomain-data-Fix-indentation.patch | 4 +-
...move-RESTORE-macros-to-avoid-access-from-.patch | 4 +-
...6-OMAP4-prcm_mpu-Fix-indent-in-few-macros.patch | 4 +-
...domain-data-Fix-data-order-and-wrong-name.patch | 4 +-
...evice-replace-_find_by_pdev-with-to_omap_.patch | 4 +-
...OMAP-PM-remove-OMAP_PM_NONE-config-option.patch | 4 +-
...-data-Remove-McASP2-McASP3-and-MMC6-clock.patch | 4 +-
...MAP4-clock-data-Remove-UNIPRO-clock-nodes.patch | 4 +-
...62-OMAP4-hwmod-data-Modify-DSS-opt-clocks.patch | 4 +-
...itialise-sleep_switch-to-a-non-valid-valu.patch | 4 +-
...domain-data-Fix-core-mem-states-and-missi.patch | 4 +-
...-data-Keep-GPMC-clocks-always-enabled-and.patch | 4 +-
...domain-data-Remove-unsupported-MPU-powerd.patch | 4 +-
...AP4-hwmod-data-Change-DSS-main_clk-scheme.patch | 4 +-
...et-hwmod-flags-to-only-allow-16-bit-acces.patch | 4 +-
...ncrease-omap_i2c_dev_attr-flags-from-u8-t.patch | 4 +-
...AP2-Introduce-I2C-IP-versioning-constants.patch | 4 +-
...MAP2-create-omap-I2C-functionality-flags-.patch | 4 +-
...ag-all-OMAP2-hwmod-defintions-with-I2C-IP.patch | 4 +-
...dd-correct-functionality-flags-to-all-oma.patch | 4 +-
...d-fix-the-i2c-reset-timeout-during-bootup.patch | 4 +-
...evice-Create-clkdev-entry-for-hwmod-main_.patch | 4 +-
...-data-Add-missing-divider-selection-for-a.patch | 4 +-
...AP4-hwmod-data-Add-clock-domain-attribute.patch | 4 +-
...OMAP2-hwmod-Init-clkdm-field-at-boot-time.patch | 4 +-
...-Replace-CLKCTRL-absolute-address-with-of.patch | 4 +-
...hwmod-Wait-the-idle-status-to-be-disabled.patch | 4 +-
...-Replace-RSTCTRL-absolute-address-with-of.patch | 4 +-
...eplace-warm-reset-API-with-the-offset-bas.patch | 4 +-
...083-OMAP4-prm-Remove-deprecated-functions.patch | 4 +-
...wmod-data-Add-PRM-context-register-offset.patch | 4 +-
...-data-Add-modulemode-entry-in-omap_hwmod-.patch | 4 +-
...m-Add-two-new-APIs-for-modulemode-control.patch | 4 +-
...-Introduce-the-module-control-in-hwmod-co.patch | 4 +-
...omain-Remove-redundant-call-to-pwrdm_wait.patch | 4 +-
...domain-Add-2-APIs-to-control-clockdomain-.patch | 4 +-
...0090-OMAP2-clockdomain-add-clkdm_in_hwsup.patch | 4 +-
...P2-PM-idle-clkdms-only-if-already-in-idle.patch | 4 +-
...domain-Add-per-clkdm-lock-to-prevent-conc.patch | 4 +-
...-allow-per-SoC-clock-init-code-to-prevent.patch | 4 +-
...-Follow-the-recommended-PRCM-module-enabl.patch | 4 +-
...bugfs-node-to-show-the-summary-of-all-clo.patch | 4 +-
...hwmod-remove-unused-voltagedomain-pointer.patch | 4 +-
...ge-move-PRCM-mod-offets-into-VC-VP-struct.patch | 4 +-
...ge-move-prm_irqst_reg-from-VP-into-voltag.patch | 4 +-
...ge-start-towards-a-new-voltagedomain-laye.patch | 4 +-
...ltage-rename-mpu-voltagedomain-to-mpu_iva.patch | 4 +-
...MAP3-voltagedomain-data-add-wakeup-domain.patch | 4 +-
...oltage-add-scalable-flag-to-voltagedomain.patch | 4 +-
...domain-add-voltagedomain-to-struct-powerd.patch | 4 +-
...oltage-domains-and-connect-to-powerdomain.patch | 4 +-
...MAP3-powerdomain-data-add-voltage-domains.patch | 4 +-
...MAP4-powerdomain-data-add-voltage-domains.patch | 4 +-
...domain-add-voltage-domain-lookup-during-r.patch | 4 +-
...ge-keep-track-of-powerdomains-in-each-vol.patch | 4 +-
...ge-split-voltage-controller-VC-code-into-.patch | 4 +-
...ge-move-VC-into-struct-voltagedomain-misc.patch | 4 +-
...ge-enable-VC-bypass-scale-method-when-VC-.patch | 4 +-
...ge-split-out-voltage-processor-VP-code-in.patch | 4 +-
...pport-PMICs-with-separate-voltage-and-com.patch | 4 +-
...RM-VP-functions-for-checking-clearing-VP-.patch | 4 +-
...place-transaction-done-check-clear-with-V.patch | 4 +-
...M-add-register-access-functions-for-VC-VP.patch | 4 +-
...ge-convert-to-PRM-register-access-functio.patch | 4 +-
...C-cleanup-i2c-slave-address-configuration.patch | 4 +-
...eanup-PMIC-register-address-configuration.patch | 4 +-
...pass-use-fields-from-VC-struct-instead-of.patch | 4 +-
...-cleanup-voltage-setup-time-configuration.patch | 4 +-
...ve-on-onlp-ret-off-command-configuration-.patch | 4 +-
...AP3-VC-abstract-out-channel-configuration.patch | 4 +-
...ge-domain-move-PMIC-struct-from-vdd_info-.patch | 4 +-
...ke-I2C-config-programmable-with-PMIC-spec.patch | 4 +-
...-handle-mutant-channel-config-for-OMAP4-M.patch | 4 +-
...e-last-nominal-voltage-setting-to-get-cur.patch | 4 +-
...eanup-move-VP-instance-into-voltdm-misc.-.patch | 4 +-
...voltage-remove-unneeded-debugfs-interface.patch | 4 +-
...ruct-omap_vp_common-replace-shift-with-__.patch | 4 +-
...ve-SoC-specific-sys-clock-rate-retreival-.patch | 4 +-
...ve-timing-calculation-config-into-VP-init.patch | 4 +-
...eate-VP-helper-function-for-updating-erro.patch | 4 +-
...0134-OMAP3-VP-remove-omap_vp_runtime_data.patch | 4 +-
...ve-voltage-scale-function-pointer-into-st.patch | 4 +-
...6-OMAP-VP-Explicitly-mask-VPVOLTAGE-field.patch | 4 +-
...P3-VP-update_errorgain-return-error-if-VP.patch | 4 +-
...P3-VP-remove-unused-omap_vp_get_curr_volt.patch | 4 +-
...mbine-setting-init-voltage-into-common-fu.patch | 4 +-
...ge-rename-scale-and-reset-functions-using.patch | 4 +-
...ge-move-rename-curr_volt-from-vdd_info-in.patch | 4 +-
...AP3-voltdm-final-removal-of-omap_vdd_info.patch | 4 +-
...ge-rename-omap_voltage_get_nom_volt-voltd.patch | 4 +-
...ge-update-nominal-voltage-in-voltdm_scale.patch | 4 +-
...PM-TWL6030-fix-voltage-conversion-formula.patch | 4 +-
...AP4-PM-TWL6030-fix-uv-to-voltage-for-0x39.patch | 4 +-
...7-OMAP4-PM-TWL6030-address-0V-conversions.patch | 4 +-
...-OMAP4-PM-TWL6030-fix-ON-RET-OFF-voltages.patch | 4 +-
.../0149-OMAP4-PM-TWL6030-add-cmd-register.patch | 4 +-
...isplay-single-block-read-console-messages.patch | 6 +-
...-omap_device-activate-dectivate-latency-m.patch | 6 +-
...dd-bootarg-for-selecting-svideo-or-compos.patch | 6 +-
...iminate-noisey-uncorrectable-error-messag.patch | 6 +-
.../sakoman/0005-video-add-timings-for-hd720.patch | 6 +-
...-smsc911x-return-ENODEV-if-device-is-not-.patch | 6 +-
...ut-touchscreen-ads7846-return-ENODEV-if-d.patch | 6 +-
...08-Revert-omap2_mcspi-Flush-posted-writes.patch | 6 +-
...-threaded-IRQ-remove-IRQ-enable-in-interr.patch | 57 +++++++
...0-rtc-twl-Fix-registration-vs.-init-order.patch | 122 ++++++++++++++
...Enable-audio-capture-by-default-for-twl40.patch | 6 +-
...odecs-twl4030-Turn-on-mic-bias-by-default.patch | 6 +-
...l4030-move-clock-input-selection-prior-to.patch | 6 +-
...l-add-support-for-backup-battery-recharge.patch | 12 +-
...001-ARM-L2-Add-and-export-outer_clean_all.patch | 4 +-
...ix-build-break-caused-by-update_mode-remo.patch | 44 +++++
...ays-Add-support-for-ThreeFiveCorp-S9700-D.patch | 170 --------------------
.../ulcd/0002-omap3-beagle-added-lcd-driver.patch | 72 --------
...d-Set-LCD-power-enable-GPIO-in-board-file.patch | 49 ------
...004-Make-fbset-show-correct-timing-values.patch | 40 -----
recipes-kernel/linux/linux_3.0.bb | 40 +++---
208 files changed, 942 insertions(+), 768 deletions(-)
create mode 100644
recipes-kernel/linux/linux-3.0/beagle/0006-omap_hsmmc-Set-dto-to-max-value-of-14-to-avoid-SD-Ca.patch
create mode 100644
recipes-kernel/linux/linux-3.0/beagle/0007-OMAP2-add-cpu-id-register-to-MAC-address-helper.patch
create mode 100644
recipes-kernel/linux/linux-3.0/beagle/0008-HACK-OMAP2-BeagleBoard-Fix-up-random-or-missing-MAC-.patch
create mode 100644
recipes-kernel/linux/linux-3.0/sakoman/0009-rtc-twl-Use-threaded-IRQ-remove-IRQ-enable-in-interr.patch
create mode 100644
recipes-kernel/linux/linux-3.0/sakoman/0010-rtc-twl-Fix-registration-vs.-init-order.patch
create mode 100644
recipes-kernel/linux/linux-3.0/ulcd/0001-OMAP_VOUT-Fix-build-break-caused-by-update_mode-remo.patch
delete mode 100644
recipes-kernel/linux/linux-3.0/ulcd/0001-omap2-displays-Add-support-for-ThreeFiveCorp-S9700-D.patch
delete mode 100644
recipes-kernel/linux/linux-3.0/ulcd/0002-omap3-beagle-added-lcd-driver.patch
delete mode 100644
recipes-kernel/linux/linux-3.0/ulcd/0003-lcd-Set-LCD-power-enable-GPIO-in-board-file.patch
delete mode 100644
recipes-kernel/linux/linux-3.0/ulcd/0004-Make-fbset-show-correct-timing-values.patch
No
I'm not sure
The overly long smtp headers in patches are one example
Could you please respin it without the git header churn in most of the patches? And to be safe, please split the commit up in one per feature change, since some changes aren't in your commit message.
The git header churn comes from using patch.sh and copying export on
top, per your recommendation.
I can start over again with adding the individual patches rather than
copying from export, but I cannot guess at which patches you want me
to copy over. It has to be all or specific ones.
