git clone git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6.git
linux-omap-2.6
cd linux-omap-2.6
ARCH=arm
PATH=~/oe/tmp/cross/armv7a/bin:~oe/tmp/staging/i686-linux/usr/bin:
$PATH # add cross tools to your path
make CROSS_COMPILE=arm-angstrom-linux-gnueabi- distclean
make CROSS_COMPILE=arm-angstrom-linux-gnueabi- omap3_beagle_defconfig
make CROSS_COMPILE=arm-angstrom-linux-gnueabi- menuconfig # only
needed if you want to change the default configuration
make CROSS_COMPILE=arm-angstrom-linux-gnueabi- uImage
Following the above instructions results in the uImage with the latest
version no. i.e. 2.6.31-rc1-omap1-........ which hangs up while
starting kernel as shown below.
there was post not too long ago regarding this. I’m consolidating the info here again:
Got to: http://wiki.davincidsp.com/index.php/FAQ_for_DaVinci_Linux and follow the instruction to enable low level debugging. Install that uImage a boot. If you notice and panic and it’s in the usb code path, apply the patch I posted earlier:
diff --git a/drivers/usb/musb/omap2430.c b/drivers/usb/musb/omap2430.c
index 3487520…b62435e 100644
— a/drivers/usb/musb/omap2430.c
+++ b/drivers/usb/musb/omap2430.c
@@ -271,7 +271,8 @@ int musb_platform_suspend(struct musb musb)
l |= ENABLEWAKEUP; / enable wakeup */
omap_writel(l, OTG_SYSCONFIG);
otg_set_suspend(musb->xceiv, 1);
if (musb->xceiv)
if (musb->set_clock)
musb->set_clock(musb->clock, 0);
That seems alright. My change is single line change so why don’t you try to add it manually. (in case you are not familier, just remove the line with a leading ‘-’ in the patch and add the lines with the leading ‘+’ in the patch file.)
I tried manually patching the omap2430.c as described in your reply
and compiled the new
kernel image.
Now booting beagleboard with this new image ..... it did went further
from the point where it used to hang but now it hangs somewhere in
between. The command line output is as shown below.
To check if this was the problem with kernel image, I replaced the
kernel image with the old pre-build image and it worked absolutely
fine.
I think I got right set of boot commands... i am using following
command and it works fine with older prebuild uImages, but gives
problem with the one compiles by me.
I’ve not had any luck getting either 2.6.30 or 2.6.31 to work - same issues as described below. I suppose now I’ll be waiting for 2.6.32 to see if its default beagle config actually boots :]
This happened on my beagle board with the latest version of omap3 tree.
It seems that mmc platform device is not created, and I am sure I have enabled
regulator, twl4030...
The only thing I can think of is that the mmc device driver isn’t enabled by default… I’ll do a diff between the .config in 2.6.29 and 2.6.30 to see what’s changed…
there was post not too long ago regarding this. I'm consolidating the info
here again:
boot. If you notice and panic and it's in the usb code path, apply the patch
I posted earlier:
index 3487520..b62435e 100644
--- a/drivers/usb/musb/omap2430.c
@@ -271,7 +271,8 @@ int musb_platform_suspend(struct musb *musb)
l |= ENABLEWAKEUP; /* enable wakeup */
- otg_set_suspend(musb->xceiv, 1);
+ if (musb->xceiv)
+ otg_set_suspend(musb->xceiv, 1);
It seems this patch just works when enabling "NOP USB Transceiver Driver" only.
Once I enable "TWL4030 USB Transceiver Driver", kernel will panic.
2050168 bytes read
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Linux-2.6.31-rc5
Data Size: 2050104 Bytes = 2 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux.............................................................................
.................................................... done, booting the kernel.
i
iii�
Now kernel was compiled using following instrucitons
ARCH=arm
PATH=~/oe/tmp/cross/armv7a/bin:~/oe/tmp/staging/i686-linux/usr/bin:
$PATH
This resulted in an uImage. Booting BB using this uImage doesnot work.
Output from the console is
