I used information from here
Everything went smoothly. Network came up. However, every 10 seconds I get
This message on the console.
omap_i2c 48060000.i2c: timeout waiting for bus ready
I do not know how to resolve this. I need i2c, but does this mean
it is not working? Is there something i2c needs that is not running?
Thank you for you time,
Durwin
===Console log===
U-Boot SPL 2015.07-dirty (Jul 29 2015 - 10:03:22)
SPL: Please implement spl_start_uboot() for your board
SPL: Direct Linux boot not active!
reading u-boot.img
reading u-boot.img
U-Boot 2015.07-dirty (Jul 29 2015 - 10:03:22 -0600)
OMAP36XX/37XX-GP ES1.2, CPU-OPP2, L3-200MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
Beagle xM Rev C
No EEPROM on expansion board
Die ID #101000229ff80000016830c319017022
Net: usb_ether
Error: usb_ether address not set.
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Checking for: /uEnv.txt …
Checking for: /boot/uEnv.txt …
23 bytes read in 12 ms (1000 Bytes/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.1.3-armv7-x2 …
5305984 bytes read in 342 ms (14.8 MiB/s)
loading /boot/dtbs/4.1.3-armv7-x2/omap3-beagle-xm.dtb …
107969 bytes read in 55 ms (1.9 MiB/s)
debug: [console=ttyO2,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc] …
debug: [bootz 0x82000000 - 0x88000000] …
Kernel image @ 0x82000000 [ 0x000000 - 0x50f680 ]
Using Device Tree in place at 88000000, end 8801d5c0
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.3-armv7-x2 (gcc version 4.9.3 20150113 (prerelease) (Linaro GCC 4.9-2015.01-3) ) #1 SMP Wed Jul 29 10:17:06 MDT 2015
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] Machine model: TI OMAP3 BeagleBoard xM
[ 0.000000] cma: Reserved 16 MiB at 0x9e800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] OMAP3630 ES1.2 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] PERCPU: Embedded 13 pages/cpu @df9fe000 s22144 r8192 d22912 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129664
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 483256K/523264K available (11111K kernel code, 1122K rwdata, 3916K rodata, 904K init, 913K bss, 23624K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0eb50e0 (15029 kB)
[ 0.000000] .init : 0xc0eb6000 - 0xc0f98000 ( 904 kB)
[ 0.000000] .data : 0xc0f98000 - 0xc10b0b88 (1123 kB)
[ 0.000000] .bss : 0xc10b3000 - 0xc11974bc ( 914 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] of_ti_dpll_setup: clock: omap3630-dpll-usb-clock-errata
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/400/600 MHz
[ 0.000000] clock: dpll5: dpll5_clk omap3630
[ 0.000000] clock: dpll5: Applying SPRZ319E 2.1: 13000000, 443, 5, 8
[ 0.000000] OMAP clockevent source: timer1 at 32768 Hz
[ 0.000000] clocksource 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65535999984741ns
[ 0.000000] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000488] Console: colour dummy device 80x30
[ 0.000518] Calibrating delay loop… 597.60 BogoMIPS (lpj=2988032)
[ 0.118225] pid_max: default: 32768 minimum: 301
[ 0.118408] Security Framework initialized
[ 0.118499] AppArmor: AppArmor disabled by boot time parameter
[ 0.118499] Yama: becoming mindful.
[ 0.118774] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.118804] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.119934] Initializing cgroup subsys blkio
[ 0.119964] Initializing cgroup subsys memory
[ 0.120025] Initializing cgroup subsys devices
[ 0.120056] Initializing cgroup subsys freezer
[ 0.120086] Initializing cgroup subsys net_cls
[ 0.120117] Initializing cgroup subsys perf_event
[ 0.120147] Initializing cgroup subsys net_prio
[ 0.120208] CPU: Testing write buffer coherency: ok
[ 0.120269] ftrace: allocating 36294 entries in 107 pages
[ 0.259582] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.259735] Setting up static identity map for 0x80008280 - 0x80008318
[ 0.266174] Brought up 1 CPUs
[ 0.266204] SMP: Total of 1 processors activated (597.60 BogoMIPS).
[ 0.266204] CPU: All CPU(s) started in SVC mode.
[ 0.267150] devtmpfs: initialized
[ 0.323028] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.354614] omap_hwmod: mcbsp2_sidetone using broken dt data from mcbsp
[ 0.355529] omap_hwmod: mcbsp3_sidetone using broken dt data from mcbsp
[ 0.429260] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.431060] xor: measuring software checksum speed
[ 0.527313] arm4regs : 744.800 MB/sec
[ 0.627105] 8regs : 582.000 MB/sec
[ 0.726898] 32regs : 664.000 MB/sec
[ 0.826690] neon : 1065.600 MB/sec
[ 0.826690] xor: using function: neon (1065.600 MB/sec)
[ 0.826965] pinctrl core: initialized pinctrl subsystem
[ 0.828704] NET: Registered protocol family 16
[ 0.832153] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.840759] Reprogramming SDRC clock to 400000000 Hz
[ 0.847930] omap_gpio 48310000.gpio: could not find pctldev for node /ocp/l4@48000000/scm@2000/pinmux@a00/pinmux_gpio1_pins, deferring probe
[ 0.849182] OMAP GPIO hardware version 2.5
[ 0.855255] irq: no irq domain found for /ocp/l4@48000000/scm@2000/pinmux@30 !
[ 0.870361] omap-gpmc 6e000000.gpmc: GPMC revision 5.0
[ 0.871978] platform 48058000.ssi-controller: Cannot lookup hwmod ‘ssi’
[ 0.876220] of_amba_device_create(): amba_device_add() failed (-19) for /etb@5401b000
[ 0.876373] of_amba_device_create(): amba_device_add() failed (-19) for /etm@54010000
[ 0.880035] No ATAGs?
[ 0.880065] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.882415] OMAP DMA hardware revision 5.0
[ 0.884368] Serial: AMBA PL011 UART driver
[ 1.066223] raid6: int32x1 gen() 138 MB/s
[ 1.235992] raid6: int32x1 xor() 103 MB/s
[ 1.405792] raid6: int32x2 gen() 174 MB/s
[ 1.575317] raid6: int32x2 xor() 115 MB/s
[ 1.745086] raid6: int32x4 gen() 176 MB/s
[ 1.914459] raid6: int32x4 xor() 117 MB/s
[ 2.084136] raid6: int32x8 gen() 161 MB/s
[ 2.253814] raid6: int32x8 xor() 104 MB/s
[ 2.423400] raid6: neonx1 gen() 873 MB/s
[ 2.593048] raid6: neonx2 gen() 1160 MB/s
[ 2.762695] raid6: neonx4 gen() 1185 MB/s
[ 2.932342] raid6: neonx8 gen() 737 MB/s
[ 2.932342] raid6: using algorithm neonx4 gen() 1185 MB/s
[ 2.932342] raid6: using intx1 recovery algorithm
[ 2.960479] omap-dma-engine 48056000.dma-controller: OMAP DMA engine driver
[ 2.969390] omap-iommu 480bd400.mmu: 480bd400.mmu registered
[ 2.970764] SCSI subsystem initialized
[ 2.971740] usbcore: registered new interface driver usbfs
[ 2.971862] usbcore: registered new interface driver hub
[ 2.971984] usbcore: registered new device driver usb
[ 2.976043] omap_i2c 48070000.i2c: bus 0 rev4.4 at 2600 kHz
[ 2.976928] omap_i2c 48072000.i2c: bus 1 rev4.4 at 400 kHz
[ 2.977722] omap_i2c 48060000.i2c: bus 2 rev4.4 at 100 kHz
[ 2.978485] media: Linux media interface: v0.10
[ 2.978607] Linux video capture interface: v2.00
[ 2.978759] pps_core: LinuxPPS API ver. 1 registered
[ 2.978759] pps_core: Software ver. 5.3.6 - Copyright 2005-2007
[ 2.978820] PTP clock support registered
[ 2.979797] omap-mailbox 48094000.mailbox: omap mailbox rev 0x40
[ 2.981750] NetLabel: Initializing
[ 2.981781] NetLabel: domain hash size = 128
[ 2.981781] NetLabel: protocols = UNLABELED CIPSOv4
[ 2.981872] NetLabel: unlabeled traffic allowed by default
[ 2.982788] Switched to clocksource 32k_counter
[ 3.136108] NET: Registered protocol family 2
[ 3.137298] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 3.137390] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 3.137481] TCP: Hash tables configured (established 4096 bind 4096)
[ 3.137573] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 3.137603] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 3.137908] NET: Registered protocol family 1
[ 3.138580] RPC: Registered named UNIX socket transport module.
[ 3.138610] RPC: Registered udp transport module.
[ 3.138610] RPC: Registered tcp transport module.
[ 3.138610] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.141723] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
[ 3.141815] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 3.147430] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 3.147583] audit: initializing netlink subsys (disabled)
[ 3.147674] audit: type=2000 audit(3.060:1): initialized
[ 3.149505] zpool: loaded
[ 3.149536] zbud: loaded
[ 3.149993] VFS: Disk quotas dquot_6.6.0
[ 3.150115] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 3.151062] NFS: Registering the id_resolver key type
[ 3.151153] Key type id_resolver registered
[ 3.151153] Key type id_legacy registered
[ 3.151214] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 3.151641] fuse init (API version 7.23)
[ 3.152038] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 3.155517] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 3.155822] io scheduler noop registered
[ 3.155822] io scheduler deadline registered
[ 3.155883] io scheduler cfq registered (default)
[ 3.159240] pinctrl-single 48002030.pinmux: 284 pins at pa fa002030 size 568
[ 3.159606] pinctrl-single 48002a00.pinmux: 46 pins at pa fa002a00 size 92
[ 3.160491] pinctrl-single 480025a0.pinmux: 46 pins at pa fa0025a0 size 92
[ 3.166107] 48050000.dss supply vdda_video not found, using dummy regulator
[ 3.166229] OMAP DSS rev 2.0
[ 3.169128] ERROR: Bad of_node_put() on /ocp/dss@48050000/port
[ 3.169158] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.1.3-armv7-x2 #1
[ 3.169189] Hardware name: Generic OMAP36xx (Flattened Device Tree)
[ 3.169219] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
[ 3.169250] [] (show_stack) from [] (dump_stack+0x90/0xa0)
[ 3.169281] [] (dump_stack) from [] (of_node_release+0xa0/0xa4)
[ 3.169311] [] (of_node_release) from [] (kobject_release+0x9c/0x1bc)
[ 3.169342] [] (kobject_release) from [] (kobject_put+0x54/0x80)
[ 3.169372] [] (kobject_put) from [] (of_node_put+0x24/0x28)
[ 3.169403] [] (of_node_put) from [] (omapdss_of_find_source_for_first_ep+0x60/0x88)
[ 3.169433] [] (omapdss_of_find_source_for_first_ep) from [] (tfp410_probe+0x154/0x1d4)
[ 3.169464] [] (tfp410_probe) from [] (platform_drv_probe+0x54/0xb4)
[ 3.169494] [] (platform_drv_probe) from [] (driver_probe_device+0x20c/0x440)
[ 3.169525] [] (driver_probe_device) from [] (__driver_attach+0x9c/0xa0)
[ 3.169525] [] (__driver_attach) from [] (bus_for_each_dev+0x78/0xac)
[ 3.169555] [] (bus_for_each_dev) from [] (driver_attach+0x2c/0x30)
[ 3.169586] [] (driver_attach) from [] (bus_add_driver+0x170/0x22c)
[ 3.169616] [] (bus_add_driver) from [] (driver_register+0x88/0x108)
[ 3.169616] [] (driver_register) from [] (__platform_driver_register+0x64/0x6c)
[ 3.169647] [] (__platform_driver_register) from [] (tfp410_driver_init+0x1c/0x20)
[ 3.169677] [] (tfp410_driver_init) from [] (do_one_initcall+0xe8/0x224)
[ 3.169708] [] (do_one_initcall) from [] (kernel_init_freeable+0x1e0/0x284)
[ 3.169738] [] (kernel_init_freeable) from [] (kernel_init+0x1c/0xf8)
[ 3.169769] [] (kernel_init) from [] (ret_from_fork+0x14/0x2c)
[ 3.176940] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 3.180633] Serial: AMBA driver
[ 3.182189] omap_uart 4806a000.serial: no wakeirq for uart0
[ 3.182464] 4806a000.serial: ttyO0 at MMIO 0x4806a000 (irq = 88, base_baud = 3000000) is a OMAP UART0
[ 3.183593] omap_uart 4806c000.serial: no wakeirq for uart1
[ 3.183837] 4806c000.serial: ttyO1 at MMIO 0x4806c000 (irq = 89, base_baud = 3000000) is a OMAP UART1
[ 3.184906] 49020000.serial: ttyO2 at MMIO 0x49020000 (irq = 90, base_baud = 3000000) is a OMAP UART2
[ 4.372344] console [ttyO2] enabled
[ 4.377136] omap_uart 49042000.serial: no wakeirq for uart3
[ 4.383300] 49042000.serial: ttyO3 at MMIO 0x49042000 (irq = 96, base_baud = 3000000) is a OMAP UART3
[ 4.395111] [drm] Initialized drm 1.1.0 20060810
[ 4.400054] usbcore: registered new interface driver udl
[ 4.405761] Error: Driver ‘tfp410’ is already registered, aborting…
[ 4.438232] twl 0-0048: PIH (irq 23) chaining IRQs 307…315
[ 4.444244] twl 0-0048: power (irq 312) chaining IRQs 315…322
[ 4.482635] twl4030_gpio twl4030-gpio: gpio (irq 307) chaining IRQs 323…340
[ 4.497772] twl4030_usb 48070000.i2c:twl@48:twl4030-usb: Initialized TWL4030 USB module
[ 4.512237] usbcore: registered new interface driver dln2
[ 4.527435] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.534393] ehci-platform: EHCI generic platform driver
[ 4.540344] ehci-omap: OMAP-EHCI Host Controller driver
[ 4.546447] ehci-omap 48064800.ehci: Can’t get PHY device for port 1: -517
[ 4.553863] tegra-ehci: Tegra EHCI driver
[ 4.561767] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 4.568267] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
[ 4.576812] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.583953] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.591491] usb usb1: Product: MUSB HDRC host driver
[ 4.596710] usb usb1: Manufacturer: Linux 4.1.3-armv7-x2 musb-hcd
[ 4.603118] usb usb1: SerialNumber: musb-hdrc.0.auto
[ 4.609466] hub 1-0:1.0: USB hub found
[ 4.613555] hub 1-0:1.0: 1 port detected
[ 4.622711] using random self ethernet address
[ 4.627502] using random host ethernet address
[ 4.633331] usb0: HOST MAC 3a:9f:f0:47:0f:ec
[ 4.637908] usb0: MAC 66:aa:19:3d:13:0f
[ 4.641967] using random self ethernet address
[ 4.646667] using random host ethernet address
[ 4.651397] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 4.658355] g_ether gadget: g_ether ready
[ 4.663421] mousedev: PS/2 mouse device common for all mice
[ 4.671844] input: twl4030_pwrbutton as /devices/platform/68000000.ocp/48070000.i2c/i2c-0/0-0048/48070000.i2c:twl@48:pwrbutton/input/input0
[ 4.689849] twl_rtc 48070000.i2c:twl@48:rtc: Power up reset detected.
[ 4.697021] twl_rtc 48070000.i2c:twl@48:rtc: Enabling TWL-RTC
[ 4.705444] twl_rtc 48070000.i2c:twl@48:rtc: rtc core: registered 48070000.i2c:twl@48 as rtc0
[ 4.716125] i2c /dev entries driver
[ 4.726989] omap_wdt: OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 4.737182] sdhci: Secure Digital Host Controller Interface driver
[ 4.743743] sdhci: Copyright© Pierre Ossman
[ 4.794281] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.802459] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.809112] hidraw: raw HID events driver © Jiri Kosina
[ 4.819671] usbcore: registered new interface driver usbhid
[ 4.825561] usbhid: USB HID core driver
[ 4.829986] ashmem: initialized
[ 4.844421] oprofile: using arm/armv7
[ 4.848785] NET: Registered protocol family 10
[ 4.855072] mip6: Mobile IPv6
[ 4.858215] NET: Registered protocol family 17
[ 4.863189] Key type dns_resolver registered
[ 4.867706] mpls_gso: MPLS GSO support
[ 4.872070] omap2_set_init_voltage: unable to find boot up OPP for vdd_mpu_iva
[ 4.879669] omap2_set_init_voltage: unable to set vdd_mpu_iva
[ 4.885772] omap2_set_init_voltage: unable to find boot up OPP for vdd_core
[ 4.893096] omap2_set_init_voltage: unable to set vdd_core
[ 4.902801] ThumbEE CPU extension supported.
[ 4.907440] Registering SWP/SWPB emulation handler
[ 4.912475] SmartReflex Class3 initialized
[ 4.918060] registered taskstats version 1
[ 4.923614] Btrfs loaded
[ 4.928405] Key type encrypted registered
[ 4.933868] 48050000.dss supply vdds_dsi not found, using dummy regulator
[ 4.942047] omapdrm omapdrm.0: DMM not available, disable DMM support
[ 4.950042] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.957092] [drm] No driver support for vblank timestamp query.
[ 5.014465] mmc0: host does not support reading read-only switch, assuming write-enable
[ 5.026306] mmc0: new high speed SDHC card at address e624
[ 5.032775] mmcblk0: mmc0:e624 SE32G 29.7 GiB
[ 5.047241] mmcblk0: p1 p2
[ 5.983245] omap_i2c 48060000.i2c: timeout waiting for bus ready
[ 5.989532] omapdrm omapdrm.0: No connectors reported connected with modes
[ 5.996765] [drm] Cannot find any crtc or sizes - going 1024x768
[ 6.019500] Console: switching to colour frame buffer device 128x48
[ 6.037292] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[ 6.043518] omapdrm omapdrm.0: registered panic notifier
[ 6.049072] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 6.153778] ehci-omap 48064800.ehci: EHCI Host Controller
[ 6.159820] ehci-omap 48064800.ehci: new USB bus registered, assigned bus number 2
[ 6.168243] ehci-omap 48064800.ehci: irq 93, io mem 0x48064800
[ 6.193267] ehci-omap 48064800.ehci: USB 2.0 started, EHCI 1.00
[ 6.199798] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.206970] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.214538] usb usb2: Product: EHCI Host Controller
[ 6.219635] usb usb2: Manufacturer: Linux 4.1.3-armv7-x2 ehci_hcd
[ 6.226013] usb usb2: SerialNumber: 48064800.ehci
[ 6.231903] hub 2-0:1.0: USB hub found
[ 6.235992] hub 2-0:1.0: 3 ports detected
[ 6.243041] input: gpio_keys as /devices/platform/gpio_keys/input/input1
[ 6.251251] twl_rtc 48070000.i2c:twl@48:rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 6.261260] sr_init: No PMIC hook to init smartreflex
[ 6.266906] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 6.275360] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 6.283660] of_cfs_init
[ 6.286254] of_cfs_init: OK
[ 6.304687] VPLL2: disabling
[ 6.308776] VMMC2: disabling
[ 6.313018] VDAC: disabling
[ 6.317657] VAUX3: disabling
[ 6.327362] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 6.335083] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 6.505157] EXT4-fs (mmcblk0p2): recovery complete
[ 6.513977] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.522521] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 6.533782] devtmpfs: mounted
[ 6.538330] Freeing unused kernel memory: 904K (c0eb6000 - c0f98000)
[ 6.553314] usb 2-2: new high-speed USB device number 2 using ehci-omap
[ 6.704162] usb 2-2: New USB device found, idVendor=0424, idProduct=9514
[ 6.711242] usb 2-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 6.720977] hub 2-2:1.0: USB hub found
[ 6.725616] hub 2-2:1.0: 5 ports detected
[ 6.800109] random: systemd urandom read with 35 bits of entropy available
[ 6.811798] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 6.826385] systemd[1]: Detected architecture ‘arm’.
Welcome to e[1mDebian GNU/Linux 8 (jessie)e[0m!
[ 6.875427] systemd[1]: Set hostname to .
[ 7.013397] usb 2-2.1: new high-speed USB device number 3 using ehci-omap
[ 7.133514] usb 2-2.1: New USB device found, idVendor=0424, idProduct=ec00
[ 7.140747] usb 2-2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.317718] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 7.336486] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 7.345184] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.353363] systemd[1]: Expecting device dev-ttyO2.device…
[ 7.373443] systemd[1]: Starting Remote File Systems (Pre).
[e[32m OK e[0m] Reached target Remote File Systems (Pre).
[ 7.393341] systemd[1]: Reached target Remote File Systems (Pre).
[ 7.399902] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 7.408752] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 7.417266] systemd[1]: Starting Paths.
[e[32m OK e[0m] Reached target Paths.
[ 7.433380] systemd[1]: Reached target Paths.
[ 7.438018] systemd[1]: Starting Encrypted Volumes.
[e[32m OK e[0m] Reached target Encrypted Volumes.
[ 7.463348] systemd[1]: Reached target Encrypted Volumes.
[ 7.469238] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[e[32m OK e[0m] Set up automount Arbitrary Executable File Formats F…utomount Point.
[ 7.503387] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.513427] systemd[1]: Starting Swap.
[e[32m OK e[0m] Reached target Swap.
[ 7.533355] systemd[1]: Reached target Swap.
[ 7.537933] systemd[1]: Expecting device dev-mmcblk0p1.device…
[ 7.563385] systemd[1]: Starting Root Slice.
[e[32m OK e[0m] Created slice Root Slice.
[ 7.583374] systemd[1]: Created slice Root Slice.
[ 7.588409] systemd[1]: Starting User and Session Slice.
[e[32m OK e[0m] Created slice User and Session Slice.
[ 7.613403] systemd[1]: Created slice User and Session Slice.
[ 7.619537] systemd[1]: Starting Delayed Shutdown Socket.
[e[32m OK e[0m] Listening on Delayed Shutdown Socket.
[ 7.643371] systemd[1]: Listening on Delayed Shutdown Socket.
[ 7.649475] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[e[32m OK e[0m] Listening on /dev/initctl Compatibility Named Pipe.
[ 7.673339] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 7.680725] systemd[1]: Starting Journal Socket (/dev/log).
[e[32m OK e[0m] Listening on Journal Socket (/dev/log).
[ 7.703369] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.709686] systemd[1]: Starting udev Control Socket.
[e[32m OK e[0m] Listening on udev Control Socket.
[ 7.733367] systemd[1]: Listening on udev Control Socket.
[ 7.739166] systemd[1]: Starting udev Kernel Socket.
[e[32m OK e[0m] Listening on udev Kernel Socket.
[ 7.763366] systemd[1]: Listening on udev Kernel Socket.
[ 7.769073] systemd[1]: Starting Journal Socket.
[e[32m OK e[0m] Listening on Journal Socket.
[ 7.793365] systemd[1]: Listening on Journal Socket.
[ 7.798767] systemd[1]: Starting System Slice.
[e[32m OK e[0m] Created slice System Slice.
[ 7.823425] systemd[1]: Created slice System Slice.
[ 7.828765] systemd[1]: Starting File System Check on Root Device…
[ 7.856781] systemd[1]: Starting system-systemd\x2dfsck.slice.
[e[32m OK e[0m] Created slice system-systemd\x2dfsck.slice.
[ 7.893493] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 7.900207] systemd[1]: Starting system-getty.slice.
[e[32m OK e[0m] Created slice system-getty.slice[ 7.908508] systemd[1]: Created slice system-getty.slice.
[ 7.918518] systemd[1]: Starting system-serial\x2dgetty.slice.
[e[32m OK e[0m] Created slice system-serial\x2dg[ 7.926055] systemd[1]: Created slice system-serial\x2dgetty.slice.
etty.slice.
[ 7.937866] systemd[1]: Starting Increase datagram queue length…
[ 7.953735] systemd[1]: Mounted Huge Pages File System.
[ 7.959838] systemd[1]: Mounting Debug File System…
[ 7.987915] systemd[1]: Starting Create list of required static device nodes for the current kernel…
Starting Create list of required static device nodes…rrent kernel…
[ 8.030334] systemd[1]: Starting Load Kernel Modules…
[ 8.050140] systemd[1]: Started Set Up Additional Binary Formats.
[ 8.083404] systemd[1]: Starting udev Coldplug all Devices…
[ 8.098297] systemd[1]: Mounting POSIX Message Queue File System…
[ 8.147552] systemd[1]: Starting Slices.
[e[32m OK e[0m] Reached target Slices.[ 8.163391] systemd[1]: Reached target Slices.
[e[32m OK e[0m] Mounted POSIX Message Queue File System.
[ 8.213073] systemd[1]: Mounted POSIX Message Queue File System.
[e[32m OK e[0m] Mounted Debug File System.[ 8.236389] systemd[1]: Mounted Debug File System.
[e[32m OK e[0m] Started Increase datagram queue [ 8.272003] systemd[1]: Started Increase datagram queue length.
length.
[e[32m OK e[0m] Started Create list of required [ 8.306243] systemd[1]: Started Create list of required static device nodes for the current kernel.
static device nodes …current kernel.
[e[32m OK e[0m] Started File System Check on Root Device.
[ 8.373443] systemd[1]: Started File System Check on Root Device.
[e[32m OK e[0m] Started Load Kernel Modules.
[ 8.393432] systemd[1]: Started Load Kernel Modules.
[e[32m OK e[0m] Started udev Coldplug all Devices.
[ 8.623535] systemd[1]: Started udev Coldplug all Devices.
[ 8.659332] systemd[1]: Starting Apply Kernel Variables…
[ 8.687713] systemd[1]: Mounting Configuration File System…
[ 8.716583] systemd[1]: Mounting FUSE Control File System…
[ 8.756866] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 8.797424] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 8.827087] systemd[1]: Starting Syslog Socket.
[e[32m OK e[0m] Listening on Syslog Socket.
[ 8.848144] systemd[1]: Listening on Syslog Socket.
[ 8.853515] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ 8.862182] systemd[1]: Starting Journal Service…
[e[32m OK e[0m] Started Journal Service.
[ 8.913482] systemd[1]: Started Journal Service.
[e[32m OK e[0m] Mounted FUSE Control File System.
[e[32m OK e[0m] Mounted Configuration File System.
[e[32m OK e[0m] Started Apply Kernel Variables.
[e[32m OK e[0m] Started Remount Root and Kernel File Systems.
[e[32m OK e[0m] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager…
[ 9.126217] systemd-fsck[80]: rootfs: clean, 25296/1949696 files, 286335/7788416 blocks
Starting Load/Save Random Seed…
[e[32m OK e[0m] Reached target Local File System[ 9.259704] systemd-udevd[112]: starting version 215
s (Pre).
[e[32m OK e[0m] Started udev Kernel Device Manager.
[e[32m OK e[0m] Started Load/Save Random Seed.
Starting Copy rules generated while the root was ro…
Starting LSB: Tune IDE hard disks…
[e[32m OK e[0m] Started Copy rules generated while the root was ro.
[e[32m OK e[0m] Started LSB: Tune IDE hard disks.
[ 10.022094] omap_ssi 48058000.ssi-controller: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 10.032257] ssi0: runtime PM failed -19
[ 10.339172] twl4030_keypad 48070000.i2c:twl@48:keypad: OF: linux,keymap property not defined in /ocp/i2c@48070000/twl@48/keypad
[ 10.351348] twl4030_keypad 48070000.i2c:twl@48:keypad: Failed to build keymap
[ 10.539276] twl4030_keypad: probe of 48070000.i2c:twl@48:keypad failed with error -2
[ 10.550567] twl4030_madc 48070000.i2c:twl@48:madc: clk disabled, enabling
[ 10.689453] Driver for 1-wire Dallas network protocol.
[ 10.788330] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.5. Driver in Interrupt mode
[e[32m OK e[0m] Found device /dev/mmcblk0p1.
Starting File System Check on /dev/mmcblk0p1…
[e[32m OK e[0m] Found device /dev/ttyO2.
[ 10.949642] systemd-fsck[148]: fsck.fat 3.0.27 (2014-11-12)
[ 10.951870] systemd-fsck[148]: 0x25: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
[ 10.953457] systemd-fsck[148]: Automatically removing dirty bit.
[ 10.954921] systemd-fsck[148]: Performing changes.
[ 10.956386] systemd-fsck[148]: /dev/mmcblk0p1: 3 files, 229/6123 clusters
[e[32m OK e[0m] Started File System Check on /dev/mmcblk0p1.
[ 11.130432] omap-aes 480c5000.aes: OMAP AES hw accel rev: 2.6
Mounting /boot/uboot…
[e[32m OK e[0m] Mounted /boot/uboot.
[e[32m OK e[0m] Reached target Local File Systems.
Starting Create Volatile Files and Directories…
[e[32m OK e[0m] Reached target Remote File Systems.
Starting Trigger Flushing of Journal to Persistent Storage…
[ 11.429595] omap-twl4030 sound: twl4030-hifi <-> 49022000.mcbsp mapping ok
Starting LSB: Raise network interfaces…
[e[32m OK e[0m] Started Create Volatile Files and Directories.
[ 11.575561] systemd-journald[110]: Received request to flush runtime journal from PID 1
[e[32m OK e[0m] Started Trigger Flushing of Journal to Persistent Storage.
Starting Network Time Synchronization…
[ 11.717041] smsc95xx v1.0.4
Starting Update UTMP about System Boot/Shutdown…
[e[32m OK e[0m] Started Update UTMP about System Boot/Shutdown.
[ 11.851837] random: nonblocking pool is initialized
[ 11.895202] smsc95xx 2-2.1:1.0 eth0: register ‘smsc95xx’ at usb-48064800.ehci-2.1, smsc95xx USB 2.0 Ethernet, c2:50:9c:40:cc:aa
[e[32m OK e[0m] Started Network Time Synchronization.
[e[32m OK e[0m] Reached target System Time Synchronized.
[ 11.995391] usbcore: registered new interface driver smsc95xx
[e[32m OK e[0m] Reached target Sound Card.
[ 12.682220] smsc95xx 2-2.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 12.689941] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.174072] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.182769] smsc95xx 2-2.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 17.093231] omap_i2c 48060000.i2c: timeout waiting for bus ready
[e[0me[31m* e[0m] A start job is running for LSB: Raise network interf…10s / no limit)
e[K[e[1;31me[0me[31m e[0m] A start job is running for LSB: Raise network interf…10s / no limit)[ 18.123229] omap_i2c 48060000.i2c: timeout waiting for bus ready
e[K[e[31me[1;31me[0me[31m* e[0m] A start job is running for LSB: Raise network interf…11s / no limit)
e[K[e[32m OK e[0m] Started LSB: Raise network interfaces…
[e[32m OK e[0m] Reached target Network.
[e[32m OK e[0m] Reached target Network is Online.
[e[32m OK e[0m] Reached target System Initialization.
[e[32m OK e[0m] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[e[32m OK e[0m] Listening on D-Bus System Message Bus Socket.
[e[32m OK e[0m] Reached target Sockets.
[e[32m OK e[0m] Reached target Timers.
[e[32m OK e[0m] Reached target Basic System.
Starting Cape Manager Service…
Starting Regular background program processing daemon…
[e[32m OK e[0m] Started Regular background program processing daemon.
Starting OpenBSD Secure Shell server…
[e[32m OK e[0m] Started OpenBSD Secure Shell server.
Starting Restore /etc/resolv.conf if the system cras…s shut down…
Starting /etc/rc.local Compatibility…
Starting Login Service…
Starting LSB: Start busybox udhcpd at boot time…
Starting LSB: Load kernel modules needed to enable cpufreq scaling…
Starting LSB: Apache2 web server…
Starting LSB: Advanced IEEE 802.11 management daemon…
Starting Avahi mDNS/DNS-SD Stack…
Starting D-Bus System Message Bus…
[e[32m OK e[0m] Started D-Bus System Message Bus.
[e[32m OK e[0m] Started Avahi mDNS/DNS-SD Stack.
Starting System Logging Service…
Starting Permit User Sessions…
[e[32m OK e[0m] Started Cape Manager Service.
[e[32m OK e[0m] Started Restore /etc/resolv.conf if the system crash…was shut down…
[e[32m OK e[0m] Started /etc/rc.local Compatibility.
[e[32m OK e[0m] Started LSB: Start busybox udhcpd at boot time.
[e[32m OK e[0m] Started LSB: Load kernel modules needed to enable cpufreq scaling.
[e[32m OK e[0m] Started LSB: Advanced IEEE 802.11 management daemon.
[e[32m OK e[0m] Started Permit User Sessions.
[e[32m OK e[0m] Started System Logging Service.
[e[32m OK e[0m] Started Login Service.
Starting LSB: set CPUFreq kernel parameters…
Starting Getty on tty1…
[e[32m OK e[0m] Started Getty on tty1.
Starting Serial Getty on ttyO2…
[e[32m OK e[0m] Started Serial Getty on ttyO2.
[e[32m OK e[0m] Reached target Login Prompts.
[e[32m OK e[0m] Started LSB: set CPUFreq kernel parameters.
[e[32m OK e[0m] Started LSB: Apache2 web server.
[e[32m OK e[0m] Reached target Multi-User System.
[e[32m OK e[0m] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[e[32m OK e[0m] Started Update UTMP about System Runlevel Changes.
Debian GNU/Linux 8 arm ttyO2
default username:password is [debian:temppwd]
arm login:
