I'm trying to to use u-boot-utils, instead of the Windows application
shipped with TI OMAP3 EVM, to boot the OMAP3 EVM over UART3. But I
have some problems with that.
What happens is this:
$ ./pserial -p /dev/ttyS0 -f /var/lib/tftpboot/omap/u-boot.bin
Waiting For Device ASIC ID: Press Ctrl+C to stop
(here i reboot my card)
ASIC ID Detected.
* (__here the EVM continue to boot with the already installed u-boot)
Sending 2ndFile:
Downloading file: 100.000% completed(333092/333092 bytes)
File download completed.
The u-boot-utils source code is cloned from GIT repo today.
The action at line marked with a * shouldn't happen. The EVM should of
course not had booted before after the file is downloaded completely.
Can anyone help me with this?
Best regards,
Kjetil Aamodt
TANDBERG
ASIC ID Detected.
Sending 2ndFile:
Hi Kjetil,
Seems like the ROM-code times out before u-boot-utils sends back a "Boot
message". The ROM-code timeout is 300ms. More info can be found in the TRM
(spruf98b.pdf) chapter 25.4.5
Best regards - Good luck
Søren
Søren Steen Christensen said the following on 03/14/2009 12:40 AM:
ASIC ID Detected.
this is interesting -> pserial does not verify the ASIC ID. I think that
might be the problem here.. maybe the SYSBOOT is setup to boot off
NOR/NAND as the first boot device.. pserial thinks that is asic id and
proceeds.. (btw, did you connect on UART3?)..
