Did a ‘git pull’ this morning and now I get this error attempting to build my image:
ERROR: function do_compile failed
ERROR: see log in /home/cmma/oe/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r0/temp/log.do_compile.31675
NOTE: Task failed: /home/cmma/oe/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r0/temp/log.do_compile.31675
NOTE: package omap3-sgx-modules-1.3.13.1397-r0: task do_compile: failed
ERROR: TaskFailed event exception, aborting
[cmma@localhost openembedded]$ cat /home/cmma/oe/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r0/temp/log.do_compile.31675
NOTE: make -j4 -e MAKEFLAGS= KERNEL_PATH=/home/cmma/oe/angstrom-dev/staging/beagleboard-angstrom-linux-gnueabi/kernel KERNEL_SRC=/home/cmma/oe/angstrom-dev/staging/beagleboard-angstrom-linux-gnueabi/kernel KDIR=/home/cmma/oe/angstrom-dev/staging/beagleboard-angstrom-linux-gnueabi/kernel KERNELDIR=/home/cmma/oe/angstrom-dev/staging/beagleboard-angstrom-linux-gnueabi/kernel KERNEL_VERSION=2.6.29-omap1 CC=arm-angstrom-linux-gnueabi-gcc LD=arm-angstrom-linux-gnueabi-ld AR=arm-angstrom-linux-gnueabi-ar BUILD=release
make -C /home/cmma/oe/angstrom-dev/staging/beagleboard-angstrom-linux-gnueabi/kernel M=pwd
make[1]: Entering directory /home/cmma/oe/angstrom-dev/staging/beagleboard-angstrom-linux-gnueabi/kernel' LD /home/cmma/oe/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r0/omap3-sgx-modules-1.3.13.1397/services4/3rdparty/dc_omap3430_linux/built-in.o CC [M] /home/cmma/oe/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r0/omap3-sgx-modules-1.3.13.1397/services4/3rdparty/dc_omap3430_linux/omaplfb_displayclass.o CC [M] /home/cmma/oe/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r0/omap3-sgx-modules-1.3.13.1397/services4/3rdparty/dc_omap3430_linux/omaplfb_linux.o /home/cmma/oe/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r0/omap3-sgx-modules-1.3.13.1397/services4/3rdparty/dc_omap3430_linux/omaplfb_linux.c: In function 'OMAPLFBUninstallVSyncISR': /home/cmma/oe/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r0/omap3-sgx-modules-1.3.13.1397/services4/3rdparty/dc_omap3430_linux/omaplfb_linux.c:117: error: too few arguments to function 'omap_dispc_unregister_isr' make[3]: *** [/home/cmma/oe/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r0/omap3-sgx-modules-1.3.13.1397/services4/3rdparty/dc_omap3430_linux/omaplfb_linux.o] Error 1 make[2]: *** [/home/cmma/oe/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r0/omap3-sgx-modules-1.3.13.1397/services4/3rdparty/dc_omap3430_linux] Error 2 make[1]: *** [_module_/home/cmma/oe/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/omap3-sgx-modules-1.3.13.1397-r0/omap3-sgx-modules-1.3.13.1397] Error 2 make[1]: Leaving directory /home/cmma/oe/angstrom-dev/staging/beagleboard-angstrom-linux-gnueabi/kernel’
make: *** [all] Error 2
FATAL: oe_runmake failed
How to I get back to a stable environment?
