I am new to Beagle and linux in general. I am having two
problems whenattempting to set up DSPLINK.
I have built a kernel using the Beagle_omap configuration file and it
is runningwith the ALSA Filesystem on the board. I have built the
dsplink.ko and the lpmko as well and I can load them using insmod. I
ran lsmod and it looks as if theyare loaded and /dev/dsplink is
there.
[root@OMAP3EVM ti-dsplink]# lsmod
Module Size Used by Not tainted
lpm_omap3530 6321 0
dsplinkk 237949 1 lpm_omap3530
Question 1) However when I try to using the cache clearing
executables(lpmON.lpmOFF )I get the following error message.
[root@OMAP3EVM bin]# ./lpmON.x470uC
==== LPM ON Test ====
app: LPM_open
Error: LPM_open failed
The lpm seems to be loaded though, I can see it in /dev
[root@OMAP3EVM /dev]# ls -l lpm*
brw-rw---- 1 253, 0 Jan 1 00:00 lpm0
I have looked in the forum and no-one seems to have reported this so I
amassuming I have done something pretty stupid.
Question 2) When I run ./messagegpp message.out 1000 I get the
following error.
[root@OMAP3EVM cmd_compiled]# ./messagegpp message.out 1000
========== Sample Application : MESSAGE ==========
Entered MESSAGE_Create ()
dsplink driver open: /dev/dsplink: No such device or address
PROC_setup () failed. Status = [0x80008008]
Leaving MESSAGE_Create ()
Entered MESSAGE_Delete ()
Assertion failed (IS_VALID_MSGQ (msgqQueue)). File : msgq.c Line : 478
MSGQ_release () failed. Status = [0x8000800b]
Assertion failed (((drvObj != NULL) && (IS_OBJECT_VALID (drvObj,
SIGN_DRV)))||1Assertion failed (IS_VALID_MSGQ (msgqQueue)). File :
msgq.c Line : 329
Leaving MESSAGE_Delete ()
My loadmodules script uses mknod
# insert DSP/BIOS Link driver
