Hello all.
Is the following expected to work :
first x-15 is in pci-host (root complex) mode.
second x-15 is in pci-endpoint mode.
the two boards are easily connectable directly (via connecting the pinouts).
the second x-15 is seen appropriately in “lspci” output on the first x-15.
If the above is expected, I would order two x-15’s (plus the connector) right away.
(There are some TI, NXP boards available which allow the above setup, but unfortunately I cannot afford such expensive beasts).
Thanks and Regards,
Ajay
