hi. problem install opencv2. (beagle bone ai )please help
sudo pip3 install opencv-python
[sudo] password for debian:
Collecting opencv-python
Downloading https://files.pythonhosted.org/packages/77/f5/49f034f8d109efcf9b7e98fbc051878b83b2f02a1c73f92bbd37f317288e/opencv-python-4.4.0.42.tar.gz (88.9MB)
99% |████████████████████████████████| 88.9MB 487kB/s eta 0:00:01Exception:
Traceback (most recent call last):
File “/usr/lib/python3/dist-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/usr/lib/python3/dist-packages/pip/commands/install.py”, line 353, in run
wb.build(autobuilding=True)
File “/usr/lib/python3/dist-packages/pip/wheel.py”, line 749, in build
self.requirement_set.prepare_files(self.finder)
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 620, in _prepare_file
session=self.session, hashes=hashes)
File “/usr/lib/python3/dist-packages/pip/download.py”, line 821, in unpack_url
hashes=hashes
File “/usr/lib/python3/dist-packages/pip/download.py”, line 659, in unpack_http_url
hashes)
File “/usr/lib/python3/dist-packages/pip/download.py”, line 902, in _download_http_url
_download_url(resp, link, content_file, hashes)
File “/usr/lib/python3/dist-packages/pip/download.py”, line 603, in _download_url
hashes.check_against_chunks(downloaded_chunks)
File “/usr/lib/python3/dist-packages/pip/utils/hashes.py”, line 46, in check_against_chunks
for chunk in chunks:
File “/usr/lib/python3/dist-packages/pip/download.py”, line 571, in written_chunks
File “/usr/lib/python3/dist-packages/pip/utils/ui.py”, line 139, in iter
for x in it:
File “/usr/lib/python3/dist-packages/pip/download.py”, line 560, in resp_read
decode_content=False):
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/response.py”, line 432, in stream
data = self.read(amt=amt, decode_content=decode_content)
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/response.py”, line 380, in read
data = self._fp.read(amt)
File “/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py”, line 63, in read
self._close()
File “/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py”, line 50, in _close
self.__callback(self.__buf.getvalue())
File “/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/controller.py”, line 275, in cache_response
self.serializer.dumps(request, response, body=body),
File “/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/serialize.py”, line 55, in dumps
“body”: _b64_encode_bytes(body),
File “/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/serialize.py”, line 12, in _b64_encode_bytes
return base64.b64encode(b).decode(“ascii”)
File “/usr/lib/python3.5/base64.py”, line 59, in b64encode
encoded = binascii.b2a_base64(s)[:-1]
MemoryError
