The problem is that when I run autoreconf, I got the following
beagleboard:/projects/opencv# autoreconf -i --force
Putting files in AC_CONFIG_AUX_DIR, `autotools'.
Makefile.am: installing `./INSTALL'
Makefile.am: required file `./NEWS' not found
Makefile.am: required file `./README' not found
Makefile.am: required file `./AUTHORS' not found
Makefile.am: installing `./COPYING'
Makefile.am:51: use `install-data-hook' or `install-exec-hook', not
`install-hook'
autoreconf: automake failed with exit status: 1
I can't find out what's wrong.
Does anybody of you have an idea?
Do you have all these installed? autoconf, automake, libtool?
Yes, I've installed this three packages with, I guess, the latest
versions.
Anyway, I have the required versions.
So, I still don't know why he can't open this three files, because
they are in the folder.
The only difference is that in the messages the file name is written
in upper case and in the folder, they are written in lower case, but
"INSTALL" and "COPYING" also.
