This used to work, but seems to have stopped. The opencv packaged shipped with openembedded cannot be installed onto a rootfs. It fails with
log_check: There were error messages in the logfile
log_check: Matched keyword: [Cannot find package]
Collected errors:
- Cannot find package opencv.
- export D=/exports/john_tmp/built/rootfs
Im not experienced with BB to be able to fix this, as everything else in the recipe looks fine to me. Can someone please take a look at this?
John
The opencv recipe will not generate an 'opencv' packages, as that will be fairly useless since opencv is a library. To include the opencv libs you can do a number of things:
1) include a package that links against an opencv lib, shlib deps will pull libcv<something> in automagically
2) include 'opencv-apps'
3) include 'opencv-samples'
not that 2) and 3) are the same as 1).
Speaking about opencv, does anyone know how to *cross*-compile opencv with octave support?
regards,
Koen
That should have read "note", not "not".
regards,
koen
Collected errors:
The opencv recipe will not generate an ‘opencv’ packages, as that will be fairly useless since opencv is a library. To include the opencv libs you can do a number of things:
- include a package that links against an opencv lib, shlib deps will pull libcv in automagically
- include ‘opencv-apps’
- include ‘opencv-samples’
Thanks!
This answer also clears up a big piece of OE logic that I was not understanding.
Regards
John
Btw, how to install the opencv and opencv samples from OE into angstrom?
'opkg update ; opkg install opencv-samples'. It doesn't install datafiles like haarcascades, but if you download a haarcascade manually you can run the facedetect sample: OpenCV facedetect running on the beagleboard | The facedetec… | Flickr
regards,
Koen
