Hi all,
i want to have openGL support in firefox. I bulid and install the TI SGX -Modules:
ubuntu@arm:~$ lsmod
Module Size Used by omaplfb 12027 0 usb_f_ecm 7909 1 g_ether 1802 0 usb_f_rndis 17719 2 g_ether u_ether 9460 3 usb_f_ecm,usb_f_rndis,g_ether libcomposite 38675 3 usb_f_ecm,usb_f_rndis,g_ether pvrsrvkm 184039 1 omaplfb pruss_remoteproc 12852 0 c_can_platform 5971 0 c_can 9400 1 c_can_platform can_dev 7494 1 c_can uio_pdrv_genirq 2848 0 uio 7032 1 uio_pdrv_genirq ubuntu@arm:~$
The demos like Chameleonman runs perfect.
But i have no hardware renderer!
ubuntu@arm:~$ es2_info
libEGL warning: DRI2: failed to authenticate
EGL_VERSION: 1.4 (DRI2)
EGL_VENDOR: Mesa Project
EGL_EXTENSIONS:
EGL_KHR_surfaceless_context
EGL_CLIENT_APIS: OpenGL OpenGL_ES OpenGL_ES2 OpenGL_ES3
GL_VERSION: OpenGL ES 2.0 Mesa 10.1.3
GL_RENDERER: Software Rasterizer
GL_EXTENSIONS:
GL_EXT_blend_minmax, GL_EXT_multi_draw_arrays,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_format_BGRA8888, GL_OES_depth24, GL_OES_element_index_uint,
GL_OES_fbo_render_mipmap, GL_OES_mapbuffer, GL_OES_rgb8_rgba8,
GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_texture_3D,
GL_OES_texture_npot, GL_OES_depth_texture, GL_OES_packed_depth_stencil,
GL_EXT_texture_type_2_10_10_10_REV, GL_OES_get_program_binary,
GL_APPLE_texture_max_level, GL_EXT_discard_framebuffer,
GL_EXT_read_format_bgra, GL_NV_fbo_color_attachments,
GL_OES_vertex_array_object, GL_ANGLE_texture_compression_dxt3,
GL_ANGLE_texture_compression_dxt5, GL_EXT_texture_rg,
GL_EXT_unpack_subimage, GL_NV_draw_buffers, GL_NV_read_buffer,
GL_EXT_map_buffer_range, GL_OES_surfaceless_context
ubuntu@arm:~$
What can i do?
