Hi all,
I have been using Linaro Tool chain and sysroot for cross compiling and building my Qt applications for Beaglebone Black Rev C with debian image
Cross Compile Tool chain used - gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf
Sysroot used - sysroot-eglibc-linaro-2017.01-arm-linux-gnueabihf.
Does this arrangement support OpenGL?
Is there any sysroot available for Beaglebone Black with installed OpenGL ES packages ?
Thanks & Regards,
Sajeevan.K
Hi all,
Please provide help on using OpenGL with Beaglebone Black.
Thanks & Regards,
Sajeevan.K
Hi all,
OpenGL has both hardware-supported and software implementations. If you're
planning to do something ambitious with your graphics, you need the
hardware drivers, which are proprietary and a little tricky (depend on
particular kernel version, etc). What are you trying to accomplish, what
did you try so far and what was the result of your attempts?
Hi Przemek Klosowski,
I would like to implement some 2d graphics with a small amount of animation.
I have already done it in my Ubuntu Host system.
But when I am building it for BBB in Qt Creator it is showing the following messages
10:04:40: Running steps for project qt3d_test_03…
10:04:40: Starting: “/opt/sysroot-eglibc-linaro-2017.01-arm-linux-gnueabihf/home/sajeevank/QtForBBB/bin/qmake” /home/sajeevank/qt-ws/qt3d_test_03/qt3d_test_03.pro -r -spec devices/linux-beagleboard-g++ CONFIG+=debug
Project ERROR: Unknown module(s) in QT: opengl
10:04:40: The process “/opt/sysroot-eglibc-linaro-2017.01-arm-linux-gnueabihf/home/sajeevank/QtForBBB/bin/qmake” exited with code 3.
Error while building/deploying project qt3d_test_03 (kit: BBB)
When executing step “qmake”
10:04:40: Elapsed time: 00:00.
My .pro file is as shown below
T += core gui opengl
greaterThan(QT_MAJOR_VERSION, 4): QT += widgets
TARGET = qt3d_test_02
TEMPLATE = app
SOURCES += main.cpp
mainwindow.cpp
glwidget.cpp
HEADERS += mainwindow.h
glwidget.h
FORMS += mainwindow.ui
LIBS += -lglut -lGLU
target.path += /home/debian
INSTALLS += target
Please suggest the work around to solve this issue.
Thanks & Regards,
Sajeevan.K
