Im trying to install packages via opkg Command on Angstrom Linux Factory installed Kernel version v3.8.13-bone67
-bash: opkg: command not found
I tried apt-get install with other packages it works fine but to im trying to install qt4-embedded via apt-get
it returns with error Unable to locate package qt4-embedded
can i get any help to get opkg package manager on my beaglebone black
So either you have the name wrong (for qt4-embedded) or it's not
available for the distribution you are using.
Are you sure you're running Angstrom? If you have apt-get it sounds
as if you have Debian or Ubuntu. What does 'cat /etc/issue' return?
If you're not running Angstrom installing opkg is only going to cause
you grief.
Thanks for your reply ,
YES It’s not Angstrom Linux.
the cat /etc/issue returns Debian GNU/Linux 7 \n \l
Thanks for pointing out i never checked that .
Just connected VIA SSH without LCD and assuming I’m working on Angstrom.
