Yes, that's probably why.
So in order to download permanent stuff I have to create a new MINI SD
card (it's a Beagleboard-xm)?
Is there no way to do that by using my MINI SD that came with the
Beagleboard?
My card was write-protected as I got it, which is fine with me. I have lots of other cards and like having a known good instance.
It took me sometime to make a bootable image, but I finally did it from an ooeb build I made myself and following the instructions on creating and building the card.
My board is an -xM A2 build. Memory has an ! or i on it depending on how you look at it.
Read the sticker. 00 is Micron and 01 is the Numonyx. It is an āiā and for those that do not know, that is the logo for Intel, which means Numonyx.
