I flashed a Rev B machine with 3.8.13 bone50 2gb image and added cape-universal with HDMI off and this is what I get
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 1715936 1504988 122116 93% /
udev 10240 0 10240 0% /dev
tmpfs 101700 468 101232 1% /run
/dev/disk/by-uuid/a4e1a49a-5183-4dbf-9c57-026e860677ca 1715936 1504988 122116 93% /
tmpfs 254248 0 254248 0% /dev/shm
tmpfs 254248 0 254248 0% /sys/fs/cgroup
tmpfs 102400 0 102400 0% /run/user
tmpfs 5120 0 5120 0% /run/lock
/dev/mmcblk0p1 98094 73876 24218 76% /boot/uboot
Can anybody suggest what is wrong here
Hi Mike,
So what exactly is the issue here?
debian@beaglebone:~$ df -h
Filesystem Size Used
Avail Use% Mounted on
rootfs 1.7G 1.5G 138M 92% /
Yes, that's exactly what's left after adding every "requested"
application to be installed in the default install.
If you need more space, you can start by removing some applications
you aren't going to use.
Next look into cleaning up /usr/share/
Next, look into using my "bare" Debian image:
http://eewiki.net/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-RootFileSystem(smallflash)
Small enough to fit in 64Mb of flash.
Oh, there is always this one too:
http://elinux.org/BeagleBoardDebian#Flasher
So bigger then 64Mb but smaller then 1.5Gb
