Hi everyone,
I’m playing around with a BeagleBone Black that I have and I’m trying to flash the onboard eMMC with a new Debian image. I’m using the Debian 9.9 2019-08-03 4GB SD IoT image from https://beagleboard.org/latest-images.
Everything works as I would expect. I can burn the image to a microSD card, boot from it, setup the flasher script, and reboot and it flashes the internal eMMC as expected. The problem is that when I boot from the eMMC there isn’t any space to actually do anything. Here’s the output of df. Is this expected on a fresh install of Debian? Do I need to use a smaller image?
debian@beaglebone:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 215M 0 215M 0% /dev
tmpfs 49M 5.4M 44M 11% /run
/dev/mmcblk1p1 3.5G 3.3G 0 100% /
tmpfs 242M 0 242M 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 242M 0 242M 0% /sys/fs/cgroup
tmpfs 49M 0 49M 0% /run/user/1000
Mark
