I was curious about the change in behavior for P9/pin 10 from SYS_RESET on beaglebone black and friends to RESETSTATz (MAIN domain warm reset status output). We have a provisioning use case where we require external programatic control over holding the board in reset. Is there an alternative path to SYS_RESET other than the user button? Is this an error or is there a stronger use case for exposing the MAIN domain reset status that I am missing?
Hi @mobileoverlord which RESET change you looking at? Rev A6 7/25/2013 or Rev C3 4/1/2021?
I am specifically comparing BBB Rev C3 to BBAI64. However, It appears that the behavior of P9 / pin 10 (SYS_RESET) on the cape header was consistent throughout the series (beaglebone black, blue, green, ai) up until the AI-64. On the AI-64, the pin is an output and it seems is used to read the warm reset status. It can no longer be used to hold the system in reset.
@jkridner can you comment on this?
It looks like it should go to RESET_REQZ
(ball C28) for reset request
or PORZ
(ball J24) for hard reset
page 133 of datasheet
