Hi, I’m trying to work with a display using lcd4linux.
I have 4 gpio to manage the data bits (4 bits) and all the hardware done. My display is compatible with the HD44780 driver.
I read the documentation about configuration and it says that I need a parallel port on /dev (/dev/parports/*).
I read a lot more and I found something about ppdev-module.
I know that the beagle doesn’t come with parallel port, but: there’s a way to cheat the display?.
I need to know if I could use lcd4linux for my purpose.
Hi, I'm trying to work with a display using lcd4linux.
I know that the beagle doesn't come with parallel port, but: there's a way
thank's...
You could write a driver which uses the parport API but which toggles
some GPIOs instead.
I did this on a gumstix for programming AVRs. I crosscompiled some
host software (avrdude and avrisp) which expected to talk to a
parallel port.
You can take a look at my code over here: http://gitorious.org/gumstix-oe/mainline/blobs/org.openembedded.dev/recipes/robostix-module/files/robostix.c
Search for PPRSTATUS and PPRCONTROL, PPWCONTROL, PPRDATA, PPWDATA,
PPCLAIM, PPRELEASE, PPDATADIR ioctls.
These were the ioctls I needed to implement that the AVR programmers
used. You may need a slightly different set for lcd4linux.
