Hi
I want to use beagleboard for my cnc router. And I need parallel port.
İs beagleboard has parallel port. I couldnt see on beagleboard.
mabey look into PWM on the gpio pins then make an interface to mock the port voltages your controller is expecting.
ulusoyab wrote:
Hi
there is no parallel port
there are a number of GPIOs that you might use to drive a parallel
connected devices. Other options are to add a I2C or SPI based
"port extender"
