hi,
in partion a sd card ,after typing all commands ,when command press
giving "UNABLE TO WRITE /DEV/SDB1"
plz suggest any idea
hi,
Did you sudo or are you root prior to running fdisk?
Glen’s suggestion is the first place to look. Also, make sure you are using lower-case ("/dev/sdb1") instead of capital letters.
