Partitioning the eMMC during microSD to eMMC fashing
beagle-flasher structure is a little new for me. Is there a comprehensive readme for it anywhere?
I am trying to setup the a beaglebone with 2 partitions during copy from microSD card to eMMC.
  1. root partition - ext4 - 2.2GB
  2. user partition - ext4 - remaining 1.3GB
Is there an easy method to do this with beagle-flasher?
The reason I want to make 2 partitions is to make the root partition read-only to ensure that it does not corrupt on power-outage. I am making the root partition read-only from the /etc/fstab during boot.
Thanks for the help in advance.
automata
There is a preinstalled package called overlayroot which allows this functionally, otherwise with some patches that should be doable.
Thanks for the the quick reply.
I understand the overlayroot package and its use for making an overlay partition for the root fs.
I would still like to figure out how to partition the eMMC during the eMMC flashing process if it is possible.
Also where does the beagle-flasher repository get pulled in from? only during running the omap-builder or can it be updated after the OS is made.
  • automata
Here you go… arm32/usr/sbin/beagle-flasher · master · BeagleBoard.org / usr-customizations · GitLab
it get’s pulled in thru the our apt package: bb-beagle-flasher so easily to update…
For arm64/BeaglePlay, i’ve updated it too add a swap partition… some of those ideas can be used in the arm32 script to expand another partition…
arm32: default path: arm32/usr/sbin/beagle-flasher · master · BeagleBoard.org / usr-customizations · GitLab
arm64: with 3rd swap partition: arm64/usr/sbin/beagle-flasher · master · BeagleBoard.org / usr-customizations · GitLab
Hi Robert,
Thanks for the pointers.
I have been able to successfully add a partition to the eMMC during initial flashing.
Best Regards,
-automata
