Support for single binary image for NAND/OneNAND based OMAP3 EVM
boards.
This patch has been generated against the tip of u-boot-arm.git.
Signed-off-by: Manikandan Pillai <mani.pillai@ti.com>
boards.
Please subscribe to the beagleboard mailing list so that all of your
posts aren't moderated. Also, given that this patch was not copied to
the u-boot mailing list, I'll assume this is only a request-for-
comment, not a submission. Patches will not be pushed to u-boot-
arm.git based on this mailing list alone. It is good to have us in
copy, but the to should be the u-boot mailing list.
Review comments below...
boards.This patch has been generated against the tip of u-boot-arm.git.
board/omap3/beagle/beagle.c | 2 +
board/omap3/evm/evm.c | 2 +
board/omap3/evm/evm.h | 13 ++--
board/omap3/overo/overo.c | 2 +
common/Makefile | 1 +
common/cmd_nvedit.c | 5 ++
common/cmd_onenand.c | 4 +-
common/env_common.c | 8 ++-
common/env_nand.c | 33 +++++++++-
common/env_onenand.c | 26 +++++++-
cpu/arm_cortexa8/omap3/board.c | 13 ++++
cpu/arm_cortexa8/omap3/mem.c | 134 ++++++++++++++++++++++++++++
cpu/arm_cortexa8/omap3/sys_info.c | 25 ++++++-
drivers/mtd/nand/nand.c | 1 -
drivers/mtd/nand/nand_base.c | 2 +-
include/common.h | 10 +++-
include/configs/omap3_beagle.h | 1 +
include/configs/omap3_evm.h | 8 ++-
include/configs/omap3_overo.h | 1 +
lib_arm/board.c | 25 +++++--
20 files changed, 269 insertions(+), 47 deletions(-)diff --git a/board/omap3/beagle/beagle.c b/board/omap3/beagle/beagle.c
index b600af3..229f2d8 100644
--- a/board/omap3/beagle/beagle.c
+++ b/board/omap3/beagle/beagle.c
@@ -45,7 +45,9 @@ int board_init(void)
DECLARE_GLOBAL_DATA_PTR;+#if !defined(CONFIG_ENV_IS_RUNTIME_SEL)
gpmc_init(); /* in SRAM or SDRAM, finish GPMC */
+#endif
I haven't found the documentation for this flag. Can you give me a
pointer?
/* board id for Linux */
gd->bd->bi_arch_number = MACH_TYPE_OMAP3_BEAGLE;
/* boot param addr */
diff --git a/board/omap3/evm/evm.c b/board/omap3/evm/evm.c
index 57c3d83..d723bec 100644
--- a/board/omap3/evm/evm.c
+++ b/board/omap3/evm/evm.c
@@ -44,7 +44,9 @@ int board_init(void)
+#endif
If you want this done on every board, does it belong here or in the
gpmc_init() function? What is the intention with this change? Please
include that in the commit comment. Are you saying that this breaks
one of NAND or OneNAND?
gd->bd->bi_arch_number = MACH_TYPE_OMAP3EVM;
diff --git a/board/omap3/evm/evm.h b/board/omap3/evm/evm.h
index 4ecea7f..b502baa 100644
--- a/board/omap3/evm/evm.h
+++ b/board/omap3/evm/evm.h
@@ -48,6 +48,7 @@ static void setup_net_chip(void);
* M0 - Mode 0
* The commented string gives the final mux configuration for that pin
#define MUX_EVM() \
/*SDRC*/\
MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) /*SDRC_D0*/\
@@ -217,10 +218,10 @@ static void setup_net_chip(void);
MUX_VAL(CP(MMC2_DAT6), (IDIS | PTD | DIS | M0)) /*MMC2_DAT6 */\
MUX_VAL(CP(MMC2_DAT7), (IEN | PTU | EN | M0)) /*MMC2_DAT7*/\
/*Bluetooth*/\
- MUX_VAL(CP(MCBSP3_DX), (IDIS | PTD | DIS | M0)) /*McBSP3_DX*/\
- MUX_VAL(CP(MCBSP3_DR), (IEN | PTD | DIS | M0)) /*McBSP3_DR*/\
- MUX_VAL(CP(MCBSP3_CLKX), (IEN | PTD | DIS | M0)) /*McBSP3_CLKX */\
- MUX_VAL(CP(MCBSP3_FSX), (IEN | PTD | DIS | M0)) /*McBSP3_FSX*/\
+ MUX_VAL(CP(MCBSP3_DX), (IDIS | PTD | DIS | M4)) /*McBSP3_DX*/\
+ MUX_VAL(CP(MCBSP3_DR), (IEN | PTD | DIS | M4)) /*McBSP3_DR*/\
+ MUX_VAL(CP(MCBSP3_CLKX), (IEN | PTD | DIS | M4)) /*McBSP3_CLKX */\
+ MUX_VAL(CP(MCBSP3_FSX), (IEN | PTD | DIS | M4)) /*McBSP3_FSX*/\
MUX_VAL(CP(UART2_CTS), (IEN | PTU | EN | M0)) /*UART2_CTS*/\
MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M0)) /*UART2_RTS*/\
MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M0)) /*UART2_TX*/\
@@ -289,7 +290,7 @@ static void setup_net_chip(void);
/*Control and debug */\
MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) /*SYS_32K*/\
MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) /*SYS_CLKREQ*/\
- MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) /*SYS_nIRQ*/\
+ MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M4)) /*SYS_nIRQ*/\
MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /*GPIO_2*/\
/* - PEN_IRQ */\
MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /*GPIO_3 */\
@@ -299,7 +300,7 @@ static void setup_net_chip(void);
MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /*GPIO_7*/\
MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4)) /*GPIO_8*/\
/* - VIO_1V8*/\
- MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) /*SYS_OFF_MODE*/\
+ MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M4)) /*SYS_OFF_MODE*/\
MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) /*SYS_CLKOUT1*/\
MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) /*SYS_CLKOUT2*/\
MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) /*JTAG_nTRST*/\
Ack. You'd know best how to configure these pins.
diff --git a/board/omap3/overo/overo.c b/board/omap3/overo/overo.c
index cf899c0..d94d314 100644
--- a/board/omap3/overo/overo.c
+++ b/board/omap3/overo/overo.c
+#endif
Please justify. I believe this might be better for an Overo
maintainer to submit if this doesn't really go into the gpmc_init()
function.
gd->bd->bi_arch_number = MACH_TYPE_OVERO;
diff --git a/common/Makefile b/common/Makefile
index 9dec4ec..d50c4a4 100644
--- a/common/Makefile
+++ b/common/Makefile
@@ -58,6 +58,7 @@ COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_nvram.o
COBJS-$(CONFIG_ENV_IS_IN_ONENAND) += env_onenand.o
COBJS-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o
COBJS-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o
+COBJS-$(CONFIG_ENV_IS_RUNTIME_SEL) += env_onenand.o env_nand.o# command
COBJS-$(CONFIG_CMD_AMBAPP) += cmd_ambapp.o
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c
index d280cb0..4ea48b4 100644
--- a/common/cmd_nvedit.c
+++ b/common/cmd_nvedit.c
@@ -59,6 +59,7 @@ DECLARE_GLOBAL_DATA_PTR;
!defined(CONFIG_ENV_IS_IN_NAND) && \
!defined(CONFIG_ENV_IS_IN_ONENAND) && \
!defined(CONFIG_ENV_IS_IN_SPI_FLASH) && \
+ !defined(CONFIG_ENV_IS_RUNTIME_SEL) && \
!defined(CONFIG_ENV_IS_NOWHERE)
# error Define one of CONFIG_ENV_IS_IN_{NVRAM|EEPROM|FLASH|DATAFLASH|
ONENAND>SPI_FLASH|NOWHERE}
#endif
@@ -66,6 +67,10 @@ DECLARE_GLOBAL_DATA_PTR;
#define XMK_STR(x) #x
#define MK_STR(x) XMK_STR(x)+#if defined(CONFIG_ENV_IS_RUNTIME_SEL)
+extern saveenv_p saveenv;
+#endif
************************************************************************/diff --git a/common/cmd_onenand.c b/common/cmd_onenand.c
index 1a5c1c2..50c13af 100644
--- a/common/cmd_onenand.c
+++ b/common/cmd_onenand.c
@@ -90,11 +90,9 @@ int do_onenand(cmd_tbl_t * cmdtp, int flag, int
argc, char *argv)start >>= onenand_chip.erase_shift;
end >>= onenand_chip.erase_shift;
- /* Don't include the end block */
- end--;
}- if (!end || (end < start)) {
+ if (end < start) {
printf("Error : erase failed ");
printf("end address incorrect\n");
break;
diff --git a/common/env_common.c b/common/env_common.c
index 6be3bb0..b692900 100644
--- a/common/env_common.c
+++ b/common/env_common.c
@@ -46,8 +46,13 @@ DECLARE_GLOBAL_DATA_PTR;extern env_t *env_ptr;
+extern env_get_char_spec_p env_get_char_spec;
+extern env_relocate_spec_p env_relocate_spec;
+#else
extern void env_relocate_spec (void);
extern uchar env_get_char_spec(int);
+#endifstatic uchar env_get_char_init (int index);
@@ -140,7 +145,8 @@ uchar default_environment = {
};#if defined(CONFIG_ENV_IS_IN_NAND) /* Environment is in Nand Flash
- || defined(CONFIG_ENV_IS_IN_SPI_FLASH)
+ || defined(CONFIG_ENV_IS_IN_SPI_FLASH) \
+ || (defined(CONFIG_CMD_NAND) && defined(CONFIG_ENV_IS_RUNTIME_SEL))
int default_environment_size = sizeof(default_environment);
#endifdiff --git a/common/env_nand.c b/common/env_nand.c
index 8af9e74..b4dd1a8 100644
--- a/common/env_nand.c
+++ b/common/env_nand.c
@@ -65,17 +65,22 @@ int nand_legacy_rw (struct nand_chip* nand, int
cmd,
extern uchar default_environment;
extern int default_environment_size;+#if defined(CONFIG_ENV_IS_RUNTIME_SEL)
+char *nand_env_name_spec = "NAND";
+#else
char * env_name_spec = "NAND";
+#endif#ifdef ENV_IS_EMBEDDED
extern uchar environment;
env_t *env_ptr = (env_t *)(&environment[0]);
+#elif defined(CONFIG_ENV_IS_RUNTIME_SEL)
+env_t *nand_env_ptr;
+extern env_t *env_ptr;
#else /* ! ENV_IS_EMBEDDED */
env_t *env_ptr = 0;
#endif /* ENV_IS_EMBEDDED */-
/* local functions */
#if !defined(ENV_IS_EMBEDDED)
static void use_default(void);
@@ -83,7 +88,11 @@ static void use_default(void);DECLARE_GLOBAL_DATA_PTR;
+uchar nand_env_get_char_spec(int index)
+#else
uchar env_get_char_spec (int index)
+#endif
return ( *((uchar *)(gd->env_addr + index)) );
@@ -100,7 +109,11 @@ uchar env_get_char_spec (int index)
* the SPL loads not only the U-Boot image from NAND but also the
* environment.
+int nand_env_init(void)
+#else
int env_init(void)
+#endif
#if defined(ENV_IS_EMBEDDED)
size_t total;
@@ -181,7 +194,11 @@ int writeenv(size_t offset, u_char *buf)
return 0;
#ifdef CONFIG_ENV_OFFSET_REDUND
+int nand_saveenv(void)
+#else
int saveenv(void)
+#endif
size_t total;
int ret = 0;
@@ -224,7 +241,11 @@ int saveenv(void)
return ret;
#else /* ! CONFIG_ENV_OFFSET_REDUND */
+#else
int saveenv(void)
+#endif
size_t total;
int ret = 0;
@@ -284,7 +305,11 @@ int readenv (size_t offset, u_char * buf)
}#ifdef CONFIG_ENV_OFFSET_REDUND
+void nand_env_relocate_spec(void)
+#else
+#endif
size_t total;
@@ -341,7 +366,11 @@ void env_relocate_spec (void)
* The legacy NAND code saved the environment in the first NAND
device i.e.,
* nand_dev_desc + 0. This is also the behaviour using the new NAND
code.
+#else
+#endif
int ret;
diff --git a/common/env_onenand.c b/common/env_onenand.c
index 3c65b3e..2a13e23 100644
--- a/common/env_onenand.c
+++ b/common/env_onenand.c
@@ -39,11 +39,19 @@ extern uchar default_environment;#define ONENAND_ENV_SIZE(mtd) (mtd.writesize - ENV_HEADER_SIZE)
+char *onenand_env_name_spec = "OneNAND";
+#else
char *env_name_spec = "OneNAND";
env_t *env_ptr = (env_t *) (&environment[0]);
+static unsigned char onenand_env[MAX_ONENAND_PAGESIZE];
+env_t *onenand_env_ptr = (env_t *)&onenand_env[0];
env_t *env_ptr = (env_t *) onenand_env;
@@ -51,12 +59,20 @@ env_t *env_ptr = (env_t *) onenand_env;DECLARE_GLOBAL_DATA_PTR;
+uchar onenand_env_get_char_spec(int index)
+#else
uchar env_get_char_spec(int index)
+#endif
return (*((uchar *) (gd->env_addr + index)));
}+#if defined(CONFIG_ENV_IS_RUNTIME_SEL)
+void onenand_env_relocate_spec(void)
+#else
void env_relocate_spec(void)
+#endif
unsigned long env_addr;
int use_default = 0;
@@ -87,7 +103,11 @@ void env_relocate_spec(void)
gd->env_valid = 1;
+int onenand_saveenv(void)
+#else
int saveenv(void)
+#endif
unsigned long env_addr = CONFIG_ENV_ADDR;
struct erase_info instr = {
@@ -101,7 +121,6 @@ int saveenv(void)
printf("OneNAND: erase failed at 0x%08lx\n", env_addr);
return 1;
/* update crc */
env_ptr->crc =
crc32(0, env_ptr->data, ONENAND_ENV_SIZE(onenand_mtd));
@@ -111,11 +130,14 @@ int saveenv(void)
printf("OneNAND: write failed at 0x%08x\n", instr.addr);
return 2;
return 0;
+int onenand_env_init(void)
+#else
int env_init(void)
+#endif
/* use default */
gd->env_addr = (ulong) & default_environment[0];
diff --git a/cpu/arm_cortexa8/omap3/board.c b/cpu/arm_cortexa8/omap3/
board.c
index 21b4c38..82912a2 100644
--- a/cpu/arm_cortexa8/omap3/board.c
+++ b/cpu/arm_cortexa8/omap3/board.c
@@ -310,6 +310,19 @@ void abort(void)
+ * Routine: print_board_info
+ * Description: Displays cpu and memory information for the board
+void print_board_info(void)
+ u32 mtype, btype;
+ btype = get_board_type();
+ display_board_info(btype);
#ifdef CONFIG_NAND_OMAP_GPMC
* OMAP3 specific command to switch between NAND HW and SW ecc
diff --git a/cpu/arm_cortexa8/omap3/mem.c b/cpu/arm_cortexa8/omap3/
mem.c
index 9fa6e00..66a48e9 100644
--- a/cpu/arm_cortexa8/omap3/mem.c
+++ b/cpu/arm_cortexa8/omap3/mem.c
@@ -26,10 +26,12 @@
*/#include <common.h>
+#include <environment.h>
#include <asm/io.h>
#include <asm/arch/mem.h>
#include <asm/arch/sys_proto.h>
#include <command.h>
+#include <nand.h>/*
* Only One NAND allowed on board at a time.
@@ -41,8 +43,20 @@ unsigned int boot_flash_sec;
unsigned int boot_flash_type;
volatile unsigned int boot_flash_env_addr;+char *env_name_spec;
+env_t *env_ptr;
+extern char *nand_env_name_spec;
+extern char *onenand_env_name_spec;
+extern env_t *nand_env_ptr;
+extern env_t *onenand_env_ptr;
+/* if 1 = NAND, 2 = ONENAND */
+unsigned int env_in_storage;
+extern void onenand_init(void);
+extern int nand_scan_ident(struct mtd_info *mtd, int maxchips);
/* help common/env_flash.c */
-#ifdef ENV_IS_VARIABLE
+#if defined(ENV_IS_VARIABLE) && !defined(CONFIG_ENV_IS_RUNTIME_SEL)uchar(*boot_env_get_char_spec) (int index);
int (*boot_env_init) (void);
@@ -64,9 +78,30 @@ u8 is_nand;
u8 is_onenand;
#endif-#endif /* ENV_IS_VARIABLE */
+#endif /* ENV_IS_VARIABLE && !defined CONFIG_ENV_IS_RUNTIME_SEL */
+extern char *env_name_spec;
+env_get_char_spec_p env_get_char_spec;
+env_init_p env_init;
+saveenv_p saveenv;
+env_relocate_spec_p env_relocate_spec;
+extern uchar nand_env_get_char_spec(int index);
+extern int nand_env_init(void);
+extern int nand_saveenv(void);
+extern void nand_env_relocate_spec(void);
+extern uchar onenand_env_get_char_spec(int index);
+extern int onenand_env_init(void);
+extern int onenand_saveenv(void);
+extern void onenand_env_relocate_spec(void);
+#endif /* CONFIG_ENV_IS_RUNTIME_SEL */#if defined(CONFIG_CMD_NAND)
+u8 is_nand;
+extern nand_info_t nand_info[2];
static u32 gpmc_m_nand[GPMC_MAX_REG] = {
M_NAND_GPMC_CONFIG1,
M_NAND_GPMC_CONFIG2,
@@ -87,6 +122,8 @@ u32 *nand_cs_base;
#endif#if defined(CONFIG_CMD_ONENAND)
+u8 is_onenand;
+extern struct mtd_info onenand_mtd;
static u32 gpmc_onenand[GPMC_MAX_REG] = {
ONENAND_GPMC_CONFIG1,
ONENAND_GPMC_CONFIG2,
@@ -241,6 +278,7 @@ void gpmc_init(void)
u32 f_off = CONFIG_SYS_MONITOR_LEN;
u32 f_sec = 0;
u32 config = 0;
+ u32 gpmc_index = 0;/* global settings */
writel(0, gpmc_base + OFFS(GPMC_IRQENABLE)); /* isr's sources
masked */
@@ -257,16 +295,16 @@ void gpmc_init(void)
writel(0, gpmc_cs_base + OFFS(GPMC_CONFIG7));
sdelay(1000);-#if defined(CONFIG_CMD_NAND) /* CS 0 */
- gpmc_config = gpmc_m_nand;
- nand_cs_base = (u32 *)(GPMC_CONFIG_CS0_BASE +
- (GPMC_CS * GPMC_CONFIG_WIDTH));
- base = PISMO1_NAND_BASE;
- size = PISMO1_NAND_SIZE;
- enable_gpmc_config(gpmc_config, nand_cs_base, base, size);
- is_nand = 1;
-#if defined(CONFIG_ENV_IS_IN_NAND)
- f_off = SMNAND_ENV_OFFSET;
+#if defined(CONFIG_CMD_ONENAND) && !
+ gpmc_config = gpmc_onenand;
+ onenand_cs_base = (u32 *)(GPMC_CONFIG_CS0_BASE +
+ (GPMC_CS * GPMC_CONFIG_WIDTH));
+ base = PISMO1_ONEN_BASE;
+ size = PISMO1_ONEN_SIZE;
+ enable_gpmc_config(gpmc_config, onenand_cs_base, base, size);
+ is_onenand = 1;
+#if defined(CONFIG_ENV_IS_IN_ONENAND)
+ f_off = ONENAND_ENV_OFFSET;
f_sec = SZ_128K;
/* env setup */
boot_flash_base = base;
@@ -276,16 +314,46 @@ void gpmc_init(void)
#endif
#endif-#if defined(CONFIG_CMD_ONENAND)
+#if defined(CONFIG_CMD_ONENAND) && defined(CONFIG_ENV_IS_RUNTIME_SEL)
+ (gpmc_index * GPMC_CONFIG_WIDTH));
- is_onenand = 1;
-#if defined(CONFIG_ENV_IS_IN_ONENAND)
- f_off = ONENAND_ENV_OFFSET;
+ /* NAND and/or ONENAND is to be scanned */
+ is_onenand = 0;
+ onenand_init();
+ if (onenand_mtd.size) {
+ is_onenand = 1;
+ f_sec = SZ_128K;
+ /* env setup */
+ boot_flash_base = base;
+ boot_flash_off = f_off;
+ boot_flash_sec = f_sec;
+ boot_flash_env_addr = f_off;
+ env_name_spec = onenand_env_name_spec;
+ env_ptr = onenand_env_ptr;
+ env_get_char_spec = onenand_env_get_char_spec;
+ env_init = onenand_env_init;
+ saveenv = onenand_saveenv;
+ env_relocate_spec = onenand_env_relocate_spec;
+ gpmc_index++;
+#endif
+#if defined(CONFIG_CMD_NAND) && !defined(CONFIG_ENV_IS_RUNTIME_SEL)/
* CS 0 */
+ gpmc_config = gpmc_m_nand;
+ nand_cs_base = (u32 *)(GPMC_CONFIG_CS0_BASE +
+ base = PISMO1_NAND_BASE;
+ size = PISMO1_NAND_SIZE;
+ enable_gpmc_config(gpmc_config, nand_cs_base, base, size);
+ is_nand = 1;
+#if defined(CONFIG_ENV_IS_IN_NAND)
+ f_off = SMNAND_ENV_OFFSET;
f_sec = SZ_128K;
/* env setup */
@@ -293,9 +361,39 @@ void gpmc_init(void)
#endif
+#endif
+#if defined(CONFIG_CMD_NAND) && defined(CONFIG_ENV_IS_RUNTIME_SEL)
+ is_nand = 0;
+ nand_init();
+ if (nand_info[0].size) {
+ is_nand = 1;
+ f_sec = SZ_128K;
+ /* env setup */
+ env_name_spec = nand_env_name_spec;
+ env_ptr = nand_env_ptr;
+ env_get_char_spec = nand_env_get_char_spec;
+ env_init = nand_env_init;
+ saveenv = nand_saveenv;
+ env_relocate_spec = nand_env_relocate_spec;
+ gpmc_index++;
#endif-#ifdef ENV_IS_VARIABLE
boot_env_get_char_spec = env_get_char_spec;
boot_env_init = env_init;
boot_saveenv = saveenv;
diff --git a/cpu/arm_cortexa8/omap3/sys_info.c b/cpu/arm_cortexa8/
omap3/sys_info.c
index 92ac1cd..a18b83e 100644
--- a/cpu/arm_cortexa8/omap3/sys_info.c
+++ b/cpu/arm_cortexa8/omap3/sys_info.c
@@ -34,6 +34,14 @@
extern omap3_sysinfo sysinfo;
static u32 *gpmc_base = (u32 *)GPMC_BASE;+#if defined(CONFIG_CMD_NAND)
+extern u8 is_nand;
+#endif
+extern u8 is_onenand;
+#endif
* get_cpu_rev(void) - extract version info
@@ -179,9 +187,22 @@ void display_board_info(u32 btype)
}printf("OMAP%s-%s rev %d, CPU-OPP2 L3-165MHz\n", sysinfo.cpu_string,
- sec_s, get_cpu_rev());
+ sec_s, get_cpu_rev());
+ printf("%s + %s/", sysinfo.board_string,
+ mem_s);
+ if (is_nand)
+ printf("%s\n", "NAND");
+#endif
+ if (is_onenand)
+ printf("%s\n", "ONENAND");
+#endif
+#else
printf("%s + %s/%s\n", sysinfo.board_string,
- mem_s, sysinfo.nand_string);
+ mem_s, sysinfo.nand_string);
+#endif}
diff --git a/drivers/mtd/nand/nand.c b/drivers/mtd/nand/nand.c
index eeb19ff..1c817f2 100644
--- a/drivers/mtd/nand/nand.c
+++ b/drivers/mtd/nand/nand.c
@@ -54,7 +54,6 @@ static void nand_init_chip(struct mtd_info *mtd,
struct nand_chip *nand,
mtd->name = NULL;
mtd->size = 0;
}void nand_init(void)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/
nand_base.c
index ba05b76..c42a287 100644
--- a/drivers/mtd/nand/nand_base.c
+++ b/drivers/mtd/nand/nand_base.c
@@ -542,6 +542,7 @@ static void nand_command(struct mtd_info *mtd,
unsigned int command,
column -= 256;
readcmd = NAND_CMD_READ1;
chip->cmd_ctrl(mtd, readcmd, ctrl);
ctrl &= ~NAND_CTRL_CHANGE;
@@ -2641,7 +2642,6 @@ int nand_scan_ident(struct mtd_info *mtd, int
maxchips)
/* Store the number of chips and calc total size for mtd */
chip->numchips = i;
mtd->size = i * chip->chipsize;
return 0;
}diff --git a/include/common.h b/include/common.h
index df64bf0..b388b8b 100644
--- a/include/common.h
+++ b/include/common.h
@@ -243,12 +243,20 @@ extern ulong load_addr; /* Default Load
Address */
void doc_probe(unsigned long physadr);/* common/cmd_nvedit.c */
+typedef uchar (*env_get_char_spec_p)(int index);
+typedef int (*env_init_p)(void);
+typedef int (*saveenv_p)(void);
+typedef void (*env_relocate_spec_p)(void);
+#else
int env_init (void);
+int saveenv(void);
+#endif
void env_relocate (void);
int envmatch (uchar *, int);
char *getenv (char *);
int getenv_r (char *name, char *buf, unsigned len);
-int saveenv (void);
#ifdef CONFIG_PPC /* ARM version to be fixed! */
int inline setenv (char *, char *);
#else
diff --git a/include/configs/omap3_beagle.h b/include/configs/
omap3_beagle.h
index f32656a..2f3ef70 100644
--- a/include/configs/omap3_beagle.h
+++ b/include/configs/omap3_beagle.h
@@ -283,6 +283,7 @@
#define CONFIG_SYS_JFFS2_NUM_BANKS 1#define ENV_IS_VARIABLE 1
+#define CONFIG_ENV_IS_RUNTIME_SEL 1#ifndef __ASSEMBLY__
extern unsigned int *nand_cs_base;
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h
index ddbab17..97339e8 100644
--- a/include/configs/omap3_evm.h
+++ b/include/configs/omap3_evm.h
@@ -107,6 +107,7 @@
#define CONFIG_CMD_I2C /* I2C serial bus support */
#define CONFIG_CMD_MMC /* MMC support */
#define CONFIG_CMD_ONENAND /* ONENAND support */
+#define CONFIG_CMD_NAND /* NAND support */#define CONFIG_CMD_AUTOSCRIPT /* autoscript support */
#define CONFIG_CMD_BDI /* bdinfo */
@@ -134,12 +135,15 @@
* Board NAND Info.
+#define CONFIG_NAND_OMAP_GPMC
#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */
/* to access nand */
#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */
/* to access */
/* nand at CS0 */+#define GPMC_NAND_ECC_LP_x16_LAYOUT 1
#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */
/* NAND devices */
#define SECTORSIZE 512
@@ -264,7 +268,7 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP-#define CONFIG_ENV_IS_IN_ONENAND 1
#define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */
#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */@@ -287,8 +291,6 @@
#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS
#define CONFIG_SYS_JFFS2_NUM_BANKS 1-#define ENV_IS_VARIABLE 1
extern unsigned int boot_flash_base;
diff --git a/include/configs/omap3_overo.h b/include/configs/
omap3_overo.h
index 201995a..cddfe83 100644
--- a/include/configs/omap3_overo.h
+++ b/include/configs/omap3_overo.h
@@ -275,6 +275,7 @@
diff --git a/lib_arm/board.c b/lib_arm/board.c
index 4ba1f5e..c1894d9 100644
--- a/lib_arm/board.c
+++ b/lib_arm/board.c
@@ -59,6 +59,11 @@ DECLARE_GLOBAL_DATA_PTR;ulong monitor_flash_len;
+extern void gpmc_init(void);
+extern void print_board_info(void);
+#endif
#ifdef CONFIG_HAS_DATAFLASH
extern int AT91F_DataflashInit(void);
extern void dataflash_print_info(void);
@@ -246,12 +251,17 @@ static int init_func_i2c (void)
typedef int (init_fnc_t) (void);int print_cpuinfo (void); /* test-only */
+extern env_init_p env_init;init_fnc_t *init_sequence = {
cpu_init, /* basic cpu dependent setup */
board_init, /* basic board dependent setup */
interrupt_init, /* set up exceptions */
+ NULL, /* initialize environment */
+#else
env_init, /* initialize environment */
+#endif
init_baudrate, /* initialze baudrate settings */
serial_init, /* serial communications setup */
console_init_f, /* stage 1 init of console */
@@ -338,13 +348,14 @@ void start_armboot (void)
/* armboot_start is defined in the board-specific linker script */
mem_malloc_init (_armboot_start - CONFIG_SYS_MALLOC_LEN);-#if defined(CONFIG_CMD_NAND)
- puts ("NAND: ");
- nand_init(); /* go init the NAND */
-#endif
- onenand_init();
+ gpmc_init(); /* in SRAM or SDRAM, finish GPMC */
+ env_init();
+ init_baudrate(); /* initialze baudrate settings */
+ serial_init(); /* serial communications setup */
+ console_init_f(); /* stage 1 init of console */
+ display_banner();
+ print_board_info();
#endif
Now I have a better idea of what this CONFIG_ENV_IS_RUNTIME_SEL flag
is doing. If I understand properly, you are using it to enable many
of your enhancements while continuing to support the ability to have
only one non-volatile memory type in the configuration. I believe the
code should always enable run-time selection and that this is an abuse
of configuration options. If a configuration option is desired, I
believe it should be in a separate patch. As in, I'd like to see the
changes to add this new feature on its own first.
Jason Kridner wrote:
Please subscribe to the beagleboard mailing list so that all of your posts aren't moderated. Also, given that this patch was not copied to the u-boot mailing list, I'll assume this is only a request-for-comment, not a submission. Patches will not be pushed to u-boot-arm.git based on this mailing list alone. It is good to have us in copy, but the to should be the u-boot mailing list.
I'd really like if you could wait with sending OMAP3 related patches to U-Boot list until OMAP3 hits mainline. Else it might be confusing for U-Boot maintainers and might stall OMAP3-merge-to-mainline process.
I have remaining diff from Steve's omap3-dev branch ready to send to U-Boot list, but will wait until mainline has OMAP3 support, too.
Dirk
Hi Jason,
I have subscribed to beagle board mailing list on gmail.
This patch is submitted for getting comments for the single binary support.
Regards
Manikandan
From: Jason Kridner [mailto:jkridner@beagleboard.org]
Sent: Thursday, January 29, 2009 10:17 PM
To: Pillai, Manikandan
Cc: Khasim Syed Mohammed; Dirk Behme; Beagle Board
Subject: Re: [beagleboard] [PATCH 1/1] Changes for single binary image for u-
boot for NAND/OneNAND flash.Please subscribe to the beagleboard mailing list so that all of your
copy, but the to should be the u-boot mailing list.Review comments below...
> boards.
> +#endifI haven't found the documentation for this flag. Can you give me a
pointer?
[Pillai, Manikandan] The CONFIG_ENV_IS_RUNTIME_SEL is a new flag that detects the type of flash during runtime rather than hard configure it. For OMAP3 EVM
One of the requests was for a single binary image for NAND/OneNAND flash. This
Flag was added to support it.
> +#endifIf you want this done on every board, does it belong here or in the
[Pillai, Manikandan] This call used to make the system hang.
> * M0 - Mode 0
> #define MUX_EVM() \
> /*SDRC*/\
> /*Bluetooth*/\
> /* - PEN_IRQ */\
> /* - VIO_1V8*/\
> MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) /*JTAG_nTRST*/\Ack. You'd know best how to configure these pins.
> +#endifPlease justify. I believe this might be better for an Overo
function.
[Pillai, Manikandan] I can revert this change.
> # command
> #endif
> +#endif
> argc, char *argv)
> - end--;
> break;
> +#else
> +#endif
Flash
> #endif
> cmd,
> +#else
> +#endif
> env_t *env_ptr = 0;
> +#else
> +#endif
> * environment.
> +#else
> int env_init(void)
> +#endif
> size_t total;
> return 0;
> +#else
> int saveenv(void)
> +#endif
> size_t total;
> int ret = 0;
> return ret;
> +#else
> int saveenv(void)
> +#endif
> size_t total;
> int ret = 0;
> +#else
> +#endif
> size_t total;
> device i.e.,
> code.
> +#else
> +#endif
> int ret;
> +#else
> +#endif
> +#else
> +#endif
> +#else
> +#endif
> gd->env_valid = 1;
> +#else
> int saveenv(void)
> +#endif
> return 1;
> /* update crc */
> env_ptr->crc =
> return 2;
> return 0;
> +#else
> int env_init(void)
> +#endif
> /* use default */
> board.c
> + u32 mtype, btype;
> mem.c
> @@ -26,10 +26,12 @@
> #include <common.h>
> #include <asm/io.h>
> +#include <nand.h>
> +env_t *env_ptr;
> u8 is_onenand;
> #endif
> +saveenv_p saveenv;
> +u8 is_nand;
> #endif
> +u8 is_onenand;
> u32 f_sec = 0;
> u32 config = 0;
> masked */
> sdelay(1000);
> - is_nand = 1;
> + is_onenand = 1;
> f_sec = SZ_128K;
> /* env setup */
> #endif
> #endif
> - is_onenand = 1;
> + is_onenand = 0;
> + onenand_init();
> + is_onenand = 1;
> + f_sec = SZ_128K;
> + /* env setup */
> + gpmc_index++;
> +#endif
> * CS 0 */
> + is_nand = 1;
> f_sec = SZ_128K;
> /* env setup */
> #endif
> +#endif
> + is_nand = 0;
> + nand_init();
> + is_nand = 1;
> + f_sec = SZ_128K;
> + /* env setup */
> + gpmc_index++;
> #endif
> omap3/sys_info.c
> @@ -34,6 +34,14 @@
> +extern u8 is_nand;
> +#endif
> +#endif
> + mem_s);
> + if (is_nand)
> +#endif
> + if (is_onenand)
> +#endif
> +#else
> +#endif
> mtd->name = NULL;
> mtd->size = 0;
> nand_base.c
> column -= 256;
> maxchips)
> chip->numchips = i;
> return 0;
> Address */
> +#else
> +int saveenv(void);
> +#endif
> #else
> omap3_beagle.h
> @@ -283,6 +283,7 @@
> @@ -107,6 +107,7 @@
> * Board NAND Info.
> /* to access */
> /* nand at CS0 */
> /* NAND devices */
> @@ -264,7 +268,7 @@
> @@ -287,8 +291,6 @@
> omap3_overo.h
> @@ -275,6 +275,7 @@
> +#endif
> +#else
> +#endif
> - puts ("NAND: ");
> -#endif
> - onenand_init();
> + env_init();
> + display_banner();
> #endifNow I have a better idea of what this CONFIG_ENV_IS_RUNTIME_SEL flag
[Pillai, Manikandan] The CONFIG_ENV_IS_RUNTIME_SEL need not be enabled
for OMAP3 options. The other boards and also the OMAP3 EVM can have
CONFIG_ENV_IS_IN_NAND or CONFIG_ENV_IS_IN_ONENAND enabled. If there is
Requirement for single binary run time flash select, this option can be
Enabled.
