Adding support for OMAP3 EVM Board
Signed-off-by: Syed Mohammed Khasim <khasim@ti.com>
Just two minor cosmetic comments below:
* Syed Mohammed, Khasim <khasim@ti.com> [080416 19:09]:
arch/arm/mach-omap2/Kconfig | 3 +
arch/arm/mach-omap2/Makefile | 1
arch/arm/mach-omap2/board-omap3evm.c | 79 +++++++++++++++++++++++++++++
include/asm-arm/arch-omap/board-omap3evm.h | 53 +++++++++++++++++++
include/asm-arm/arch-omap/hardware.h | 4 +
5 files changed, 140 insertions(+)Index: my_branch/arch/arm/mach-omap2/Makefile
--- my_branch.orig/arch/arm/mach-omap2/Makefile 2008-04-16 14:39:51.000000000 +0530
+++ my_branch/arch/arm/mach-omap2/Makefile 2008-04-16 14:41:28.000000000 +0530
@@ -34,6 +34,7 @@
board-sdp-hsmmc.o \
board-3430sdp-usb.o \
board-3430sdp-flash.o
+obj-$(CONFIG_MACH_OMAP3EVM) += board-omap3evm.o
obj-$(CONFIG_MACH_OMAP_APOLLON) += board-apollon.o \
board-apollon-mmc.o \
board-apollon-keys.oIndex: my_branch/arch/arm/mach-omap2/Kconfig
--- my_branch.orig/arch/arm/mach-omap2/Kconfig 2008-04-16 14:40:02.000000000 +0530
+++ my_branch/arch/arm/mach-omap2/Kconfig 2008-04-16 14:41:28.000000000 +0530
@@ -106,3 +106,6 @@
bool "OMAP 3430 SDP board"
depends on ARCH_OMAP3 && ARCH_OMAP34XX+config MACH_OMAP3EVM
+ bool "OMAP 3530 EVM board"
+ depends on ARCH_OMAP3 && ARCH_OMAP34XXIndex: my_branch/arch/arm/mach-omap2/board-omap3evm.c
--- /dev/null 1970-01-01 00:00:00.000000000 +0000
+++ my_branch/arch/arm/mach-omap2/board-omap3evm.c 2008-04-16 14:42:30.000000000 +0530
@@ -0,0 +1,79 @@
+ * linux/arch/arm/mach-omap2/board-omap3evm.c
+ * Copyright (C) 2008 Texas Instruments
+ * Modified from mach-omap2/board-3430sdp.c
+ * Initial code: Syed Mohammed Khasim
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License version 2 as
+ * published by the Free Software Foundation.
+#include <linux/kernel.h>
+#include <linux/init.h>
+#include <linux/platform_device.h>
+#include <linux/delay.h>
+#include <linux/err.h>
+#include <linux/clk.h>
+#include <linux/io.h>
+#include <asm/hardware.h>
+#include <asm/mach-types.h>
+#include <asm/mach/arch.h>
+#include <asm/mach/map.h>
+#include <asm/arch/gpio.h>
+#include <asm/arch/board.h>
+#include <asm/arch/common.h>
+static struct omap_uart_config omap3_evm_uart_config __initdata = {
+ .enabled_uarts = ((1 << 0) | (1 << 1) | (1 << 2)),
+static int __init omap3_evm_i2c_init(void)
+ omap_register_i2c_bus(1, 2600, NULL, 0);
+ omap_register_i2c_bus(2, 400, NULL, 0);
+ omap_register_i2c_bus(3, 400, NULL, 0);
+ return 0;
+static void __init omap3_evm_init_irq(void)
+ omap2_init_common_hw();
+ omap_init_irq();
+ omap_gpio_init();
+static struct omap_board_config_kernel omap3_evm_config __initdata = {
+ {OMAP_TAG_UART, &omap3_evm_uart_config },
Can you please add a space between { OMAP_TAG_UART... above?
+static void __init omap3_evm_init(void)
+ omap_board_config = omap3_evm_config;
+ omap_board_config_size = ARRAY_SIZE(omap3_evm_config);
+ omap_serial_init();
+arch_initcall(omap3_evm_i2c_init);
+static void __init omap3_evm_map_io(void)
+ omap2_set_globals_343x();
+ omap2_map_common_io();
+MACHINE_START(OMAP3EVM, "OMAP3 EVM")
+ /* Maintainer: Syed Mohammed Khasim - Texas Instruments */
+ .phys_io = 0x48000000,
+ .io_pg_offst = ((0xd8000000) >> 18) & 0xfffc,
+ .boot_params = 0x80000100,
+ .map_io = omap3_evm_map_io,
+ .init_irq = omap3_evm_init_irq,
+ .init_machine = omap3_evm_init,
+ .timer = &omap_timer,
+MACHINE_ENDIndex: my_branch/include/asm-arm/arch-omap/hardware.h
--- my_branch.orig/include/asm-arm/arch-omap/hardware.h 2008-04-16 14:39:51.000000000 +0530
+++ my_branch/include/asm-arm/arch-omap/hardware.h 2008-04-16 14:44:09.000000000 +0530
@@ -335,6 +335,10 @@
#include "board-3430sdp.h"
#endif+#ifdef CONFIG_MACH_OMAP3EVM
+#include "board-omap3evm.h"
+#endif
#ifdef CONFIG_MACH_OMAP_APOLLON
#include "board-apollon.h"
#endifIndex: my_branch/include/asm-arm/arch-omap/board-omap3evm.h
+++ my_branch/include/asm-arm/arch-omap/board-omap3evm.h 2008-04-16 14:44:09.000000000 +0530
@@ -0,0 +1,53 @@
+ * linux/include/asm-arm/arch-omap/board-omap3evm.h
+ * Hardware definitions for TI OMAP3 EVM.
+ * Initial creation by Syed Mohammed Khasim <khasim@ti.com>
+ * This program is free software; you can redistribute it and/or modify it
+ * under the terms of the GNU General Public License as published by the
+ * Free Software Foundation; either version 2 of the License, or (at your
+ * option) any later version.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
+ * NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
+ * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * You should have received a copy of the GNU General Public License along
+ * with this program; if not, write to the Free Software Foundation, Inc.,
+ * 675 Mass Ave, Cambridge, MA 02139, USA.
+#ifndef __ASM_ARCH_OMAP3_EVM_H
+#define __ASM_ARCH_OMAP3_EVM_H
+#ifdef CONFIG_TWL4030_CORE
+#define TWL4030_IRQNUM INT_34XX_SYS_NIRQ
+/* TWL4030 Primary Interrupt Handler (PIH) interrupts */
+#define IH_TWL4030_BASE IH_BOARD_BASE
+#define IH_TWL4030_END (IH_TWL4030_BASE+8)
+#define IH_TWL4030_PWRBASE (IH_TWL4030_END)
+#define IH_TWL4030_PWRBASE_END (IH_TWL4030_PWRBASE+8)
+#ifdef CONFIG_TWL4030_GPIO
+/* TWL4030 GPIO Interrupts */
+#define IH_TWL4030_GPIO_BASE (IH_TWL4030_PWRBASE_END)
+#define IH_TWL4030_GPIO_END (IH_TWL4030_GPIO_BASE+18)
+#define NR_IRQS (IH_TWL4030_GPIO_END)
+#else
+#define NR_IRQS (IH_TWL4030_PWRBASE_END)
+#endif /* CONFIG_I2C_TWL4030_GPIO */
+#endif /* End of support for TWL4030 */
+#endif /* __ASM_ARCH_OMAP3_EVM_H */
Please remove the extra space above before __ASM_ARCH...
Resending after incorporating these minor comments
Khasim
Sorry sent some of these in HTML format. Resending again...
Khasim
