BeagleBoard-X15 is the next generation Open Source Hardware
BeagleBoard based on TI's AM5728 SoC featuring dual core 1.5GHZ A15
processor. The platform features 2GB DDR3L (w/dual 32bit busses),
eSATA, 3 USB3.0 ports, integrated HDMI (1920x108@60), separate LCD
port, video In port, 4GB eMMC, uSD, Analog audio in/out, dual 1G
Ethernet.
Just add basic support for the moment, the following updates are needed:
i) Ethernet - depends on SoC dts fixes
ii) USB Client (USB2) - depends on GPIO extcon
ii) HDMI - additional driver fixes pending
iii) Audio - additional driver fixes pending
Signed-off-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
Yes, it should either be the full and correct value or 0x0 (like a
number of PowerPC platforms do) so it's clear something else gives us
the right value here.
Honest mistake, my bad.. I thought I cleaned up the patch! Sigh!!! i
will repost with proper 2GB. it is better that way in case being used
with "other bootloaders" which are not exactly too good like u-boot.
yep - will do that similar to https://patchwork.kernel.org/patch/5125431/ - same rationale unless
there is any specific voltage rail that you are explicitly interested
in that needs additional explanation. Is there additional rails of
interest?
> * Nishanth Menon <nm@ti.com> [141106 08:44]:
>>>>> device_type = "memory"; + reg = <0x80000000 0x40000000>; /* 1GB
>>>>> to start. Target 2GB */
>>>> 1GiB ? Why would you put this here btw ? u-boot fills this one up.
> Can you also describe why all the always-on regulators are needed?
yep - will do that similar to ARM: dts: dra7-evm: Keep all VDD rails always-on - Patchwork - same rationale unless
interest?
Here is what I have in mind: (updated with comments from Felipe/Tom and
above) - would you like more details added - if you could point out
areas of interest, I can help improve information provided here.
8<---
From d73029bc01c9e2193fb769ce5cc6cc5abb14eba5 Mon Sep 17 00:00:00 2001
