Supports dynamic panel configuration
Supports dynamic tv standard selection
Adds support for DSS register access through generic APIs
Incorporated DSS register access using structures.
Previous discussions are here
http://www.mail-archive.com/u-boot@lists.denx.de/msg27150.html
Signed-off-by: Syed Mohammed Khasim <khasim@ti.com>
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
Configures DSS to display color bar on Svideo
Configures DSS to display background color on DVID
Based on commit f1099c7c43caf5bac3bf6a65aa266fade4747072
Author: Greg Turner <gregturner@ti.com>
New u-boot command for status of USER button on BeagleBoard-xM
Modified bootcmd to check the staus at boot time and set
filename of the boot script.
* Moved to a BeagleBoard specific file.
* Removed changes to default boot command from adding userbutton
command.
* Made to handle pre-xM boards.
* Flipped polarity of the return value to avoid confusion. Success (0)
is when the button is pressed. Failure (1) is when the button is NOT
pressed.
* Used latest revision getting function.
* Used latest macros for board revision.
cool, now lets add USB, ethernet, DSP support,
a simple scheduler and some virtual memory
and we are done
