This was done with the following command-line:
for file in `find . | grep '\.[chS]$'`;
do perl -i -pe 's/(green|yellow|red|blue)_LED_(on|off)/$1_led_$2/g' $file;
done
Signed-off-by: Jason Kridner <jdk@ti.com>
done
done
one line:
find . -name '*.[chS]' -exec \
sed -ri 's/(green|yellow|red|blue)_LED_(on|off)/\1_led_\2/g'
--- a/arch/arm/cpu/arm1176/start.S
+++ b/arch/arm/cpu/arm1176/start.Sbl coloured_LED_init
- bl red_LED_on
+ bl red_led_on
seems like you didnt fix coloured_LED_init
also, i dont see you changing any of the .c files where these funcs are
actually defined
-mike
Hi Mike,
Le 12/09/2011 06:04, Mike Frysinger a �crit :
>> $file;
>> done
> one line:
>> - bl red_LED_on
>> + bl red_led_on
> actually definedThis patch is assumed to apply above the current git tip, where the
function definitions were already changed, and only .S files should be
fixed.
by "current git tip" i'm guessing you mean "current arm master". i was
looking at the mainline u-boot master and the C files weren't changed.
Running MAKEALL arm right now, just to make sure, then I will apply it
on top of u-boot-arm/master.
be nice to send out a single squashed patch to wolfgang rather than a few
known-to-be-broken ones ...
-mike
Le 12/09/2011 18:27, Mike Frysinger a �crit :
you dont need to do that. simply squash them into a branch and have wolfgang
pull that branch. then when you merge his tree back, things get stitched
sanely together via the merge commit.
-mike
Dear Albert ARIBAUD,
