[PATCH v2] omap3_beagle: enable the use of a plain text file named uEnv.txt instead of boot.scr
Using the new env import command it is possible to use plain text files instead
of script-images. Plain text files are much easier to handle.
E.g. If your boot.scr contains the following:
Hello Jason,
setenv dvimode 1024x768-16@60
run loaduimage
run mmcboot
you could create a file named uEnv.txt and use that instead of boot.scr:
dvimode=1024x768-16@60
uenvcmd=run loaduimage; run mmcboot
The variable uenvcmd (if existent) will be executed (using run) after uEnv.txt
was loaded. If uenvcmd doesn't exist the default boot sequence will be started,
therefore you could just use
as uEnv.txt because loaduimage and mmcboot is part of the default boot sequence.
For backwards compatibility the use of boot.scr is still supported.
Changes for v2:
   - Eliminated else redundant clause that would be ignored if boot
     succeeds.
If I interpret your change correctly, your v2 would use uEnv.txt and boot.scr if both are existent. I think this would only lead to confusion.
My target was to get rid of boot.scr and to therefor boot.scr would be ignored if uEnv.txt exists. I don't see any reason why boot.scr should be still used when uEnv.txt exists.
Signed-off-by: Jason Kridner<jkridner@beagleboard.org>
Cc: Alexander Holler<holler@ahsoftware.de>
  include/configs/omap3_beagle.h | 26 ++++++++++++++++++--------
  1 files changed, 18 insertions(+), 8 deletions(-)
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h
index f151e98..b7f5480 100644
--- a/include/configs/omap3_beagle.h
+++ b/include/configs/omap3_beagle.h
@@ -229,6 +229,9 @@
    "loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr\0" \
    "bootscript=echo Running bootscript from mmc ...; " \
      "source ${loadaddr}\0" \
+ "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} uEnv.txt\0" \
+ "importbootenv=echo Importing environment from mmc ...; " \
+ "env import -t $loadaddr $filesize\0" \
    "loaduimage=fatload mmc ${mmcdev} ${loadaddr} uImage\0" \
    "mmcboot=echo Booting from mmc ...; " \
      "run mmcargs; " \
@@ -240,15 +243,22 @@
  #define CONFIG_BOOTCOMMAND \
    "if mmc rescan ${mmcdev}; then " \
+ "echo SD/MMC found on device ${mmcdev};" \
+ "if run loadbootenv; then " \
+ "run importbootenv;" \
+ "fi;" \
+ "if test -n $uenvcmd; then " \
+ "echo Running uenvcmd ...;" \
+ "run uenvcmd;" \
+ "fi;" \
      "if run loadbootscript; then " \
- "run bootscript; " \
- "else " \
- "if run loaduimage; then " \
- "run mmcboot; " \
- "else run nandboot; " \
- "fi; " \
- "fi; " \
- "else run nandboot; fi"
+ "run bootscript;" \
+ "fi;" \
+ "if run loaduimage; then " \
+ "run mmcboot;" \
+ "fi;" \
+ "fi;" \
+ "run nandboot;" \
  #define CONFIG_AUTO_COMPLETE 1
Alexander
Hello Jason,
instead
run loaduimage
run mmcboot
uEnv.txt
started,
sequence.
Changes for v2:
succeeds.
if uenvcmd results in a successful boot, then boot.scr would never get executed.
Again, my concern is that this default logic gets overly complex. A
policy of applying linear attempt-then-fall-through will make patches
to this logic apply cleanly as new boot sources are added,
specifically if we ever get the USER button support upstream.
I understand the goal of only using uEnv.txt and not using ucmdenv
such that the u-boot default variables can be used to perform the
boot. I think this goal can easily be achieved by deleting boot.scr.
If boot.scr exists, I don't follow that it would be any less confusing
to the user if it were to *not* be executed following uEnv.txt.
Hello Jason,
instead
run loaduimage
run mmcboot
uEnv.txt
started,
sequence.
Changes for v2:
     succeeds.
But that requires that uenvcmd is set/used which makes uEnv.txt unnecessarily complex and will not be possible to define/change e.g. only the (u-boot) environment variable dvimode.
We could just delete the logic for boot.scr. Another approach would be to print a warning like "The usage of boot.scr is deprecated and will be removed with the next release!" if boot.scr will be used and delete the stuff for boot.scr with the next release.
Again, I think such an approach will only confuse people because stuff from two files might be used. And what is used will depend on what u-boot is used. There might be people with an u-boot in NAND, for which a boot.scr on an SD-card still is required. But if you want to serve people with an new u-boot too, you'll need an uEnv.txt too. And with your logic that has to use an uencmd, which makes uEnv.txt more complicate than needed.
And most people never see the bootcmd, but they see uEnv.txt and/or boot.scr because they have to define the resolution for their monitor there.
So I still would prefer to leave bootcmd currently a bit more complicated, with the advantage that only a simple uEnv.txt is possible which just contains e.g. "dvimode=1024x768-16@60".
just a last word. I don't have to decide which patch is used and I don't have any problem if v2 is used. I'm able to modify bootcmd like I wish and can live with any version.
I've justed wanted to make clear why I haven't used a simpler approach.
Anyway, if v2 will be used, please just remove my name as author, I don't want to be responsible for the possible arising confusion.
Everyone can still use as much from that patch as he wishes, please just don't use my name as author for a modified patch with a changed logic. :wink:
Alexander
Hello Jason,
So, just a thought.. Are you guys planning to push this same boot
method to all the other "omap" devices that just finally got boot.scr
boot support by default in u-boot? It also seems's like it'll end up
be the FAQ of the month for the beagleboard group.. :wink:
Hello Jason,
Sorry, but I think that line in the description should get removed too.
I'll submit a v4.
Indeed it is likely to be FAQ of the month, especially if it lands in
the next software update that gets shipped with the board. It is a
case, however, in which I like the answer--no more need to run
mkimage. The conversion process of a boot.scr script (commands) to a
uEnv.txt file (variable setting) won't be exactly trivial, so that has
me a tiny bit concerned. Still, most cases will be solved by a *much*
simpler uEnv.txt script and an overall simpler process.
I still see a need to use the USER button to go into some sort of
fall-back state to ignore this file and boot some sort of recovery
image. Since that code isn't upstream yet, there is still going to be
some delta between upstream and what ships on the board--unless I can
somehow figure out an easy way to get a command added for the generic
gpio framework.
I would say that should be decided by every board-maintainer, just like the change from ttyS2 to ttyO2. E.g. I don't think the devkit8000-sdk will change as soon as the stuff the for the beagleboard.
Alexander
Oh, we will work around it over the transition, so it's not a big deal..
It was just kinda nice, (if we assume all boards have xlo/u-boot in
nand) that most boards would boot on one boot.scr/kernel/rootfs
combination. Since the mainline kernel can boot on all omap2/3/4
boards (in mainline) at this point..
But since both the xM/Panda don't have nand, my point's kinda moot as
they'll need a different xlo/u-boot...
Hello Jason,
I've just seen a patch which makes env import optional, so you might consider adding CONFIG_CMD_IMPORTENV to omap3_beagle.h to be prepared when env import will get optional.
Alexander Holler
Hello Jason,
Sorry for the noise, the patch which makes it optional enables it by default, so no action is necessary. Haven't seen that at first.
Dear Alexander Holler,
instead
run loaduimage
run mmcboot
uEnv.txt
started,
sequence.
Changes for v2:
    succeeds.
Changes for v3:
  - Removed boot.scr per discussion with Alexander.
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
Pushed to u-boot-ti after making changes to the patch header
Dear "Paulraj, Sandeep",
In message <0554BEF07D437848AF01B9C9B5F0BC5DC365D49D@dlee01.ent.ti.com>
you wrote:
> > From: Alexander Holler <holler@ahsoftware.de>
files
> > instead
> > run loaduimage
> > run mmcboot
boot.scr:
> > uEnv.txt
> > started,
> > sequence.
> > Changes for v2:
> > succeeds.
> > Changes for v3:
I think you might have missed Jason Kridner's Signed-off-by ?
Best regards,
Wolfgang Denk
I have fixed this.
I had to edit the patch headers of quite a few patches and missed this one.
Sandeep
