[PATCH v2] pulseaudio: Run as system-wide instance instead of per-user
* Pulseaudio running as per-user is opening audio devices and blocking everyone else from getting access
  to the device. The problem is it doesn't even seem to be allowing applications to connect to it, this
  patch starts it up in system mode instead which is tested and known to work
Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com>
the startup script should be in a seperate recipe
