This patch adds basic support (no controls) for
mt9p031 sensor. It applies on kernel 2.6.39.
Signed-off-by: Javier Martin <javier.martin@vista-silicon.com>
Since isp clocks have not been exposed yet, this patch
includes a temporal solution for testing mt9p031 driver
in Beagleboard xM.
There should probably a if (cpu_is_omap3630()) {} wrapped around that, so the camera doesn't get initted on a 3530 beagle.
regards,
Koen
root@beagleboardxMC:~# yavta -f SGRBG8 -s 320x240 -n 4 --capture=10 --skip 3 -F `media-ctl -e "OMAP3 ISP CCDC output"`
Device /dev/video2 opened.
Device `OMAP3 ISP CCDC output' on `media' is a video capture device.
Video format set: SGRBG8 (47425247) 320x240 buffer size 76800
Video format: SGRBG8 (47425247) 320x240 buffer size 76800
4 buffers requested.
length: 76800 offset: 0
Buffer 0 mapped at address 0x402cf000.
length: 76800 offset: 77824
Buffer 1 mapped at address 0x402fe000.
length: 76800 offset: 155648
Buffer 2 mapped at address 0x40362000.
length: 76800 offset: 233472
Buffer 3 mapped at address 0x40416000.
0 (0) [-] 4294967295 76800 bytes 167.403289 1306829219.931121 0.002 fps
1 (1) [-] 4294967295 76800 bytes 167.633148 1306829220.160980 4.350 fps
2 (2) [-] 4294967295 76800 bytes 167.744506 1306829220.272308 8.980 fps
3 (3) [-] 4294967295 76800 bytes 167.855865 1306829220.383667 8.980 fps
4 (0) [-] 4294967295 76800 bytes 167.967193 1306829220.495025 8.982 fps
5 (1) [-] 4294967295 76800 bytes 168.078552 1306829220.606384 8.980 fps
6 (2) [-] 4294967295 76800 bytes 168.189910 1306829220.717742 8.980 fps
7 (3) [-] 4294967295 76800 bytes 168.301269 1306829220.829071 8.980 fps
8 (0) [-] 4294967295 76800 bytes 168.412597 1306829220.940429 8.982 fps
9 (1) [-] 4294967295 76800 bytes 168.523956 1306829221.051788 8.980 fps
Captured 10 frames in 1.254212 seconds (7.973134 fps, 612336.670356 B/s).
4 buffers released.
So that seems to be working! I haven't checked the frames yet, but is isn't throwing ISP errors anymore.
Great!
Do you have a monochrome version of the same sensor?
...speaking of which - if multiarch kernels are supported by OMAP3 you
probably want to use something like
if (!machine_is_omap3_beagle() || !cpu_is_omap3630())
return;
Guennadi
I think I only have the colour version, I got it with my leopard355 board way back.
So what can I do with an unpatched mediactl and unpatched yavta? Is it already possible to point something like mplayer or gstreamer to a v4l2 node and see something? I lost the track of which patch goes where
regards,
Koen
I don't know, I haven't tried.
I'm still using old yavta + Guennadi's patch to enable stdoutput and
"nc" to view images in my PC with mplayer.
If you're a lucky owner of an LCD on your bb-xM;) you might be able to do
something similar, to what's described here
http://download.open-technology.de/BeagleBoard_xM-MT9P031/BBxM-MT9P031.txt
but both yavta and mplayer on the board, while short-circuiting the
network;) I.e., pipe yavta output directly to mplayer.
Guennadi
Shouldn't you check the Beagleboard version instead? The OMAP3530 has an ISP,
so there's nothing wrong with it per-se.
No idea whatsoever - in that part I'm just repeating, what the previous
poster has said:)
Guennadi
It has an ISP, but the pins aren't brought out, so you will never be able to use it. We could check the version, but that will look like:
if (omap3_beagle_get_rev() = OMAP3BEAGLE_BOARD_XM || omap3_beagle_get_rev() = OMAP3BEAGLE_BOARD_XMC || omap3_beagle_get_rev() = OMAP3BEAGLE_BOARD_XMD )
or check if you're not on OMAP3BEAGLE_BOARD_AXBX, OMAP3BEAGLE_BOARD_C1_3 or OMAP3BEAGLE_BOARD_C4. I find the 3630 check a lot simpler
regards,
Koen
regards,
Koen
I tried that and I can say that shining a light into the sensor changes the picture on the screen, but that's about it. Which part needs changing (subdev, isp, mt9p031, beagle-camera, etc) to enable 'standard' access? E.g. opening cheese in gnome.
regards,
Koen
This is what I see with the 5M and the command that worked for you:
root@beagleboard:~# yavta -f SGRBG8 -s 320x240 -n 4 --capture=10 --
Buffer 0 mapped at address 0x40248000.
Buffer 1 mapped at address 0x40265000.
Buffer 2 mapped at address 0x402ce000.
Buffer 3 mapped at address 0x40334000.
Unable to start streaming: 22.
-ENOTENOUGHINFO
did you run the other commands (e.g. the mediactl ones) as well?
Hi Koen,
