Hi Guys,
I need to permanently set the MTU on eth0, I know this is very “linux installation variable” from past painful experience.
Does anyone know the correct way to do this on the BeagleV/Fire before I head off hacking everything to try to get it to work?
Andy
FYI, I don’t have a BeagleV.
This is assuming you are running debian 12 image.
$cat /etc/network/interfaces
iface eth0 inet mtu xxxx
Also, make sure the kernel is actually assigning eth0 to the interface.
$ls /sys/class/net
Thanks for the reply.
/etc/network/interfaces didn’t exist, so I added it with iface eth0 inet mtu 1200, rebooted, MTU did not change.
beagle@BeagleV:~$ ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:9e:a7:c9:68 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.10 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 2a02:c7c:dd80:7300:204:a3ff:fe2e:aa6b prefixlen 64 scopeid 0x0<global>
inet6 fd04:bfdb:70f2:0:204:a3ff:fe2e:aa6b prefixlen 64 scopeid 0x0<global>
inet6 fe80::204:a3ff:fe2e:aa6b prefixlen 64 scopeid 0x20<link>
ether 00:04:a3:2e:aa:6b txqueuelen 1000 (Ethernet)
RX packets 533 bytes 101241 (101.2 KB)
RX errors 0 dropped 218 overruns 0 frame 0
TX packets 57 bytes 8433 (8.4 KB)
device interrupt 53
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 100 bytes 8811 (8.8 KB)
TX packets 100 bytes 8811 (8.8 KB)
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.7.2 netmask 255.255.255.0 broadcast 192.168.7.255
inet6 fe80::204:a3ff:fe2e:aa6e prefixlen 64 scopeid 0x20<link>
ether 00:04:a3:2e:aa:6e txqueuelen 1000 (Ethernet)
RX packets 342 bytes 52299 (52.2 KB)
TX packets 252 bytes 44308 (44.3 KB)
Here is the version info:
beagle@BeagleV:~$ uname -a
Linux BeagleV 6.1.33-linux4microchip+fpga-2023.06-20231019+ #1 SMP Thu Oct 19 16:01:29 UTC 2023 riscv64 riscv64 riscv64 GNU/Linux
beagle@BeagleV:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 23.04
Release: 23.04
Codename: lunar
beagle@BeagleV:~$ cat /etc/os-release
PRETTY_NAME="Ubuntu 23.04"
NAME="Ubuntu"
VERSION_ID="23.04"
VERSION="23.04 (Lunar Lobster)"
VERSION_CODENAME=lunar
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=lunar
LOGO=ubuntu-logo
Are you using systemd-networkd to manage networkng ?
If so /etc/network/interfaces might be being ignored.
Hi @benedict.hewson,
I edited /etc/systemd/network/eth0.network and bingo it works, so I guess it is using systemd-networkd
Thanks for the pointer.
Andy
