I recently have tried starting with a newer image:
bone-debian-9.2-iot-armhf-2017-10-10-4gb.img
on a rev C BeagleBoneBlack.
I have been trying to build it back to the same level as I had before, adding the PRU libraries, ntpdate, and socket. Now I find that the php files I have been using on the previous image no longer work.
I tried:
php -v
and get the following…
-bash: php: command not found
I tried to add php using:
sudo apt-get install php5-common libapache2-mod-php5 php5-cli
but I get:
Package libapache2-mod-php5 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘php5-common’ has no installation candidate
E: Package ‘libapache2-mod-php5’ has no installation candidate
E: Package ‘php5-cli’ has no installation candidate
So I then tried
debian@beaglebone:/var/www/html$ sudo apt-get install php5.6
Reading package lists… Done
Building dependency tree
Note, selecting ‘php5.6-json’ for regex ‘php5.6’
Note, selecting ‘php5.6-common’ for regex ‘php5.6’
0 upgraded, 0 newly installed, 0 to remove and 42 not upgraded.
but php -v still does not work successfully.
If there is any advice I would be pleased to hear it.
Thanks in advance.
Alan
