Pin conflict between BB-CAN1 and BB-BONE-LCD4-01
Hi:
I am using 2 overlays to support a custom cape that includes an LCD and a CAN bus transceiver.
The overlays I am using are BB-CAN1 and BB-BONE-LCD4-01. BB-BONE-LCD4-01 uses P9.24 as an input (which I did not hardwire), while BB-CAN1 uses P9.24 as CAN_RX.
When loading the overlays I get an error that BB-CAN1 failed to load because of the pin conflict.
I modified the cape manager configuration so BB-CAN1 is loaded first, hoping that the LCD cape would map as many pins as it can (and would not reserve P9.24). Though it seems that the overlay is just not loaded at all in case of a pin conflict, and the LCD would just not work anymore.
Ideally I guess I need to create a custom overlay for the cape I built. But for now, the easiest might be to modify BB-BONE-LCD4-01 so it does not try to reserve p9.24.
How can I do this?
JS
As long as it's v4.1.x+ then just:
git clone https://github.com/beagleboard/bb.org-overlays
cd ./bb.org-overlays
remove:
https://github.com/beagleboard/bb.org-overlays/blob/master/src/arm/BB-BONE-LCD4-01-00A1.dts#L52
https://github.com/beagleboard/bb.org-overlays/blob/master/src/arm/BB-BONE-LCD4-01-00A1.dts#L115
https://github.com/beagleboard/bb.org-overlays/blob/master/src/arm/BB-BONE-LCD4-01-00A1.dts#L243-L249
./install.sh
sudo reboot
Hi Robert:
Thanks for the reply. I will get this a try tonight.
I have to say that I did try to spin my own overlay by merging the CAN-1, UART2 and LCD4 dts files I got from gihub. Uploaded the resulting dts file to the BB, and compiled it with dtc.
I got several syntax errors including on the #includes, and… I forget what the rest were.
For now I will go ahead with the solution you suggested, but eventually I’d love to be able to create and compile my own dts.
Is there anything special about the dts files on github and the dtc that comes with 4.1.15?
JS
Hi Robert:
I got to try your solution and it worked perfectly. Thank you for your detailed and quick reply, this was greatly appreciated.
Also I now do understand how to create my own overlay, from scratch.
JS
