pin currents and analog in
Hello community,
is there any example out there how to use the analog in pins?
In the doc
NO PINS ARE TO BE DRIVEN UNTIL AFTER THE SYS_RESET LINE GOES HIGH. DO NOT APPLY VOLTAGE TO ANY I/O PIN WHEN POWER IS NOT SUPPLIED TO THE BOARD. IT WILL DAMAGE THE PROCESSOR AND VOID THE WARRANTY.
So how to wire up dome simple potentiometer ?
And what are the available currents s(sink/source) on the normal io pins?
Sunny greetings
Stefan
to be on a save-side i will use some external ADC
most likely the ADS7830
(there is a nice breakoutboard from adafruit for this one)
