What is the method for setting the pin mode(s) on the pocketbeagle 2? The setup guide does provide how to set GPIO pins but there is no clarification on setting pin modes. The old pin-mode command does not seem to work so I guess the overlays won’t work either.
I used a lot config-pin on BBB, so when i got the PB2 and it was missing.
I did a back port of the gpio-helper and the dts generation for the PB2. I planed to do the merge request but there is still some issue with the PB2 having pins connected together.
