Hi everyone,
I´m just starting a project where I´m going to do some tests with a Beagleboard xM that needs to control an external board through a UART channel, some PWM pins, and some GPIOs.
I´ve just prepare my SD Card with the last Debian Image from this link:
https://debian.beagleboard.org/images/bbxm-debian-9.5-lxqt-xm-armhf-2018-10-07-4gb.img.xz
Boot the system and seems everything looks good:
U-Boot SPL 2018.09-00001-ge10814359b (Sep 10 2018 - 19:52:59 -0500)
Trying to boot from MMC1
spl_load_image_fat_os: error reading image args, err - -2
U-Boot 2018.09-00001-ge10814359b (Sep 10 2018 - 19:52:59 -0500), Build: jenkins-github_Bootloader-Builder-65
OMAP3630/3730-GP ES1.2, CPU-OPP2, L3-200MHz, Max CPU Clock 1 GHz
Model: TI OMAP3 BeagleBoard
I2C: ready
DRAM: 256 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
Loading Environment from NAND… *** Warning - readenv() failed, using default environment
Beagle xM Rev C
No EEPROM on expansion board
OMAP die ID: 6c0a00029ff8000001578ca01101202e
Net: usb_ether
starting USB…
USB0: USB EHCI 1.00
scanning bus 0 for devices… 3 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
scanning usb for ethernet devices… 1 Ethernet Device(s) found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1…
SD/MMC found on device 0
Checking for: /uEnv.txt …
Checking for: /boot/uEnv.txt …
432 bytes read in 27 ms (15.6 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.18.11-armv7-x11 …
6550016 bytes read in 520 ms (12 MiB/s)
loading /boot/dtbs/4.18.11-armv7-x11/omap3-beagle-xm.dtb …
94492 bytes read in 786 ms (117.2 KiB/s)
loading /boot/initrd.img-4.18.11-armv7-x11 …
4745973 bytes read in 390 ms (11.6 MiB/s)
debug: [console=ttyO2,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet] …
debug: [bootz 0x82000000 0x88080000:486af5 0x88000000] …
Loading Ramdisk to 89b79000, end 89fffaf5 … OK
Loading Device Tree to 89b5e000, end 89b7811b … OK
Starting kernel …
[ 4.520965] Error: Driver ‘tfp410’ is already registered, aborting…
[ 5.108215] omap2_set_init_voltage: unable to find boot up OPP for vdd_core
[ 5.115936] omap2_set_init_voltage: unable to set vdd_core
[FAILED] Failed to start Load Kernel Modules.
See ‘systemctl status systemd-modules-load.service’ for details.
[DEPEND] Dependency failed for robotcontrol.
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Started File System Check Daemon to report status.
Starting Create Static Device Nodes in /dev…
Mounting Configuration File System…
Mounting FUSE Control File System…
Starting Apply Kernel Variables…
[ OK ] Mounted Configuration File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started File System Check on Root Device.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Journal Service.
Starting udev Kernel Device Manager…
Starting Remount Root and Kernel File Systems…
[ OK ] Started Remount Root and Kernel File Systems.
Starting Load/Save Random Seed…
Starting Flush Journal to Persistent Storage…
Starting udev Coldplug all Devices…
[ OK ] Started Load/Save Random Seed.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Set the console keyboard layout.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories…
Starting Set console font and keymap…
Starting Raise network interfaces…
[ OK ] Started Set console font and keymap.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization…
[ OK ] Started Entropy daemon using the HAVEGE algorithm.
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Raise network interfaces.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Reached target System Initialization.
[ OK ] Listening on bonescript.socket.
[ OK ] Listening on cloud9.socket.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on node-red.socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting LSB: Load kernel modules needed to enable cpufreq scaling…
[ OK ] Started Deferred execution scheduler.
Starting LSB: Start busybox udhcpd at boot time…
Starting Restore /etc/resolv.conf i…fore the ppp link was shut down…
Starting Login Service…
Starting Avahi mDNS/DNS-SD Stack…
[ OK ] Started Bonescript autorun.
[ OK ] Started Regular background program processing daemon.
Starting rc_battery_monitor…
Starting BB WL18xx wlan0 Service…
Starting Generic Board Startup…
Starting System Logging Service…
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting Connection service…
[ OK ] Started System Logging Service.
[ OK ] Started Restore /etc/resolv.conf if…before the ppp link was shut down.
[ OK ] Started rc_battery_monitor.
[ OK ] Started BB WL18xx wlan0 Service.
[ OK ] Started Connection service.
[ OK ] Started LSB: Start busybox udhcpd at boot time.
[ OK ] Started Login Service.
[ OK ] Reached target Network.
Starting OpenBSD Secure Shell server…
Starting Permit User Sessions…
Starting The Apache HTTP Server…
[ OK ] Reached target Network is Online.
Starting LSB: Advanced IEEE 802.11 management daemon…
[ OK ] Started Permit User Sessions.
[ OK ] Started LSB: Advanced IEEE 802.11 management daemon.
Starting Light Display Manager…
[ OK ] Started Getty on tty1.
[ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
Starting Hostname Service…
Starting LSB: set CPUFreq kernel parameters…
Starting WPA supplicant…
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Hostname Service.
[ OK ] Started LSB: set CPUFreq kernel parameters.
[ OK ] Started WPA supplicant.
[ OK ] Started The Apache HTTP Server.
[ OK ] Started Light Display Manager.
[ 51.872741] OF: graph: no port node found in /ocp@68000000/isp@480bc000/ports
Debian GNU/Linux 9 beagleboard ttyS2
BeagleBoard.org Debian Image 2018-10-07
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
beagleboard login: debian
Password:
My question is, as I´ll try to control the PinMux to use the P9 expansion header (to be able to use the UART2), I was curious to see the functions that this image has. I found that I can execute the config-pin -i command to see that:
debian@beagleboard:~$ config-pin -i P9_24
Pin name: P9_24
Function if no cape loaded: gpio
Function if cape loaded: default gpio gpio_pu gpio_pd gpio_input uart can i2c pru_uart pruin
Function information: gpio0_15 default gpio0_15 gpio0_15 gpio0_15 gpio0_15 uart1_txd dcan1_rx i2c1_scl pru_uart pru0_in16
Kernel GPIO id: 15
PRU GPIO id: 47
debian@beagleboard:~$ config-pin -i P9_1
Pin is not modifyable: P9_01 GND
I can see that the P9_1 says it´s GND when it´s actully 1V8 in the schematic of my Rev C2 version
Additionally I can see that the functions match the beagle board (non xM), so it seems the system has boot as a BBB.
So, I´m not sure if I have a wrong image or if the config-pin -i command is not actually reflecting the xM reality, or I have to so an additional configuration when booting to correclty match the xM
Thanks for the support.
Regards.
