I am using gstreamer port in android. When i tried to play an mp3 file over http, it reported error.
GstPlayer.cpp:35, GstPlayer(): Enter
D/GstPlayer( 823): [835], DEBUG GstPlayerPipeline.cpp:460, GstPlayerPipeline(): Enter
D/GstPlayer( 823): [835], DEBUG GstPlayerPipeline.cpp:200, init_gst(): Check gstreamer environment variables.
D/GstPlayer( 823): [835], DEBUG GstPlayerPipeline.cpp:201, init_gst(): GST_PLUGIN_PATH="/system/
plugins"
D/GstPlayer( 823): [835], DEBUG GstPlayerPipeline.cpp:202, init_gst(): LD_LIBRARY_PATH="/system/lib"
D/GstPlayer( 823): [835], DEBUG GstPlayerPipeline.cpp:203, init_gst(): GST_REGISTRY="/sdcard/reg.bin"
D/GstPlayer( 823): [835], DEBUG GstPlayerPipeline.cpp:237, init_gst(): Gst has been initialized
D/GstPlayer( 823): [835], DEBUG GstPlayerPipeline.cpp:576, create_pipeline(): Pipeline is created successfully
D/GstPlayer( 823): [835], DEBUG GstPlayerPipeline.cpp:501, GstPlayerPipeline(): Leave
D/GstPlayer( 823): [835], DEBUG GstPlayer.cpp:45, GstPlayer(): Leave
D/GstPlayer( 823): [835], DEBUG GstPlayer.cpp:50, initCheck(): mInit = OK
D/GstPlayer( 823): [835], DEBUG GstPlayerPipeline.cpp:674, setDataSource(): Enter, url=http://play.last.fm/user/902c6e92fd6fc3471a51dd7b8ea67c72.mp3
D/GstPlayer( 823): [835], DEBUG GstPlayerPipeline.cpp:712, setDataSource(): playbin2 uri: http://play.last.fm/user/902c6e92fd6fc3471a51dd7b8ea67c72.mp3
D/GstPlayer( 823): [835], DEBUG gstplaybin2.c:1031:gst_play_bin_set_uri: set new uri to http://play.last.fm/user/902c6e92fd6fc3471a51dd7b8ea67c72.mp3
D/GstPlayer( 823): [835], DEBUG GstPlayerPipeline.cpp:789, setAudioSink(): MediaPlayerInterface::AudioSink: 0x6f3d8
D/GstPlayer( 823): [1000], DEBUG GstPlayerPipeline.cpp:888, prepareAsync(): Enter
D/GstPlayer( 823): [1000], DEBUG gstplaybin2.c:2308:setup_next_source: setup sources
D/GstPlayer( 823): [1017], DEBUG GstPlayerPipeline.cpp:252, bus_callback(): Get state-changed Message From playsink4
D/GstPlayer( 823): [1000], DEBUG gstplaybin2.c:2132:activate_group: making new uridecodebin
D/GstPlayer( 823): [1000], DEBUG gsturidecodebin.c:1324:setup_source: setup source
W/GstPlayer( 823): [1000], WARN gsturidecodebin.c:835:gen_source_element: error: No URI handler implemented for “http”.
D/GstPlayer( 823): [1000], DEBUG gstplaybin2.c:2245:activate_group: failed state change of uridecodebin
D/GstPlayer( 823): [1000], DEBUG gstplaybin2.c:2344:setup_next_source: activate failed
D/GstPlayer( 823): [1000], DEBUG GstPlayerPipeline.cpp:890, prepareAsync(): state_return = 0
E/GstPlayer( 823): [1000], ERROR GstPlayerPipeline.cpp:893, prepareAsync(): Fail to set pipeline to PAUSED
D/GstPlayer( 823): [1017], DEBUG GstPlayerPipeline.cpp:1318, handleStateChanged(): State changed message: playsink4, old-1, new-2, pending-0
D/GstPlayer( 823): [1017], DEBUG GstPlayerPipeline.cpp:252, bus_callback(): Get state-changed Message From playbin24
D/GstPlayer( 823): [1017], DEBUG GstPlayerPipeline.cpp:1318, handleStateChanged(): State changed message: playbin24, old-1, new-2, pending-3
D/GstPlayer( 823): [1017], DEBUG GstPlayerPipeline.cpp:252, bus_callback(): Get state-changed Message From uridecodebin4
D/GstPlayer( 823): [1017], DEBUG GstPlayerPipeline.cpp:1318, handleStateChanged(): State changed message: uridecodebin4, old-1, new-2, pending-3
D/GstPlayer( 823): [1017], DEBUG GstPlayerPipeline.cpp:252, bus_callback(): Get error Message From uridecodebin4
D/GstPlayer( 823): [1017], DEBUG GstPlayerPipeline.cpp:1277, handleError(): gst-resource-error-quark error(1): No URI handler implemented for “http”. debug: exter4
E/MediaPlayer( 960): error (1, 0)
Is gstreamer supports http other than rtp,rtsp. if so, any plugin have to be ported.
Thanks and Regards,
HarishKumar.V
