Please recommend a retail enclosure for BeagleY AI
Dear Friends,
Since BeagleY AI is in the form factor of regular Raspberry Pi SBC, could you recommend a retail enclosure ( with fan, camera cable slit, etc) for it?
I am going to buy one for hobby. :blush:
The one of for Rpi 5 are suitable. I bought one of them from Amazon and had no problems.
But, I can’t run 3.5" TFT screen still.
No LCD or CAM support yet, just a board with HDMI monitor. :smirk:
Kinda got off topic for enclosures, but any Pi 5 enclosure should work well. The OLDI connector might need some consideration, but it generally doesn’t get in the way.
As for camera, did you try Using IMX219 CSI Cameras — BeagleBoard Documentation?
As for DSI, did you check out https://www.youtube.com/watch?v=1OnKZT04JAo ? 3.5" should be similar.
It does not work. I tried within a few days after getting the board. It will detect it if memory is correct. But the issue with the gpu not working and possibly something else is breaking the pipeline, its been many weeks ago since touching that and that may or may not be the correct assessment of the problem.
