What is generally the best path to learn how to program the M4, found inside the PB2? Code Composer via JTAG? Writing and loading firmware via Linux? I see the Zephyr RTOS integration is a WIP, and I haven’t found much on getting that setup either. Any help is appreciated.
Writing and loading Zephyr RTOS firmware using remoteproc is the standard way. One can use Code Composer with Ti FreeRTOS based sdk, but most of the focus from BeagleBoard.org is on Zephyr.
The instructions to build and load a simple hello world Zephyr firmware can be found here. Other than that, everything is standard zephyr. If you follow along with any zephyr tutorials (I remember going through CircuitDojo), you should be fine.
NOTE: If you want to use any peripherals/pins from M4, they do need to be disabled on the Linux side.
