Using the serial connection to bacon bits cape to pocket beagle, it seems that it doesn’t shut down cleanly?
debian@beaglebone:~/src$ sudo shutdown -h now
[85060.880449] reboot: Power down
[85063.372620] rtc_power_off failed, bailing out.
[85063.398178] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00
[85063.398178]
[85063.407436] CPU: 0 PID: 1 Comm: systemd-shutdow Not tainted 4.9.82-ti-r102 #1
[85063.414625] Hardware name: Generic AM33XX (Flattened Device Tree)
[85063.420846] [] (unwind_backtrace) from [] (show_stack+0x)
[85063.428686] [] (show_stack) from [] (dump_stack+0x80/0x9)
[85063.436003] [] (dump_stack) from [] (panic+0x100/0x28c)
[85063.443055] [] (panic) from [] (complete_and_exit+0x0/0x)
[85063.450450] [] (complete_and_exit) from [] (SyS_reboot+0)
[85063.458545] [] (SyS_reboot) from [] (ret_fast_syscall+0x)
[85063.466330] —[ end Kernel panic - not syncing: Attempted to kill init! exi0
[85063.466330]
It's fine, the mmc/drive was already down.
We just need to figure out the proper way to tell the RTC to power off
the unit..
The problem seems to be, that the rtc has no active oscillator:
If I set RTC_OSC_REG to 0x40 (internal oscillator) shutdown works normal.
But I’m not sure whether this is the correct way to solve this issue.
Regards
Beat Bieler
Thanks guys, with the help of Matthijs, we have this implement in
u-boot and the kernel..
My PocketBeagle now shut's down..
You can get the updated bootloader via:
debian@beaglebone:~$ sudo /opt/scripts/tools/developers/update_bootloader.sh
I've also add a print statement about the RTC
U-Boot 2018.03-00002-gac9cce7c6a (Apr 05 2018 - 13:07:46 -0500),
Build: jenkins-github_Bootloader-Builder-47
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: Internal. <-------------------
Pocket: Internal
BeagleBone Black: External
Right now only v4.16.0-bone7 has the kernel change, and it's building right now
http://gfnd.rcn-ee.org:81/farm/deb/
I'll start the backport shortly to previous kernels..
How exactly do i change the value of the register? I have no idea which file to look for
onsdag den 4. april 2018 kl. 15.55.41 UTC+2 skrev beatb...@gmail.com:
The default BeagleBoard images already take care of this issue now..
Are you trying to modify that register in a non-u-boot, non-linux OS?
