pocketbeagle 2 rtc-ds1307 driver
@RobertCNelson
can you add the rtc-ds1307 driver to the next PB2 build
also, where is the kernel source and defconfig file for PB2 ?
It’s enabled:
CONFIG_RTC_DRV_DS1307=y
# CONFIG_RTC_DRV_DS1307_CENTURY is not set
Kernel Builds are generated off these scripts:
Build scripts: https://openbeagle.org/RobertCNelson/ti-linux-kernel-dev/-/tree/ti-linux-arm64-6.12.y?ref_type=heads
config: https://openbeagle.org/RobertCNelson/ti-linux-kernel-dev/-/blob/ti-linux-arm64-6.12.y/patches/defconfig?ref_type=heads
does not seem to be in the 1025-01-30 build, grep does not return a .ko file
i’ll give your scripts a try.
thanks
a .ko file isn’t generated when it’s built in (y)…
so i need to modify the dts to add the ds1307 to the i2c2 section.
Something like as root:
echo ds1307 0x68 > /sys/bus/i2c/devices/i2c-Z/new_device
