And they are a cool Blue, rather than industrial Black.
— Graham
— Graham
Working on that internally, found another Amphenol FCI that we do
stock, in 36 pin:
https://www.digikey.com/products/en?lang=en&site=us&KeyWords=609-4507-ND
For price that is cheaper:
https://www.digikey.com/products/en?lang=en&site=us&KeyWords=A118476-ND
With pin's that are smaller then Amphenol's 0.2x0.5(TE Connectivity)
vs: 0.2x0.6(Amphenol)
BEWARE !!!
With pin’s that are smaller then Amphenol’s 0.2x0.5(TE Connectivity)
The A118476-ND is a 2mm connector system, NOT a 0.1 Inch / 2.54 mm system that is required.
— Graham
I installed male headers on the top by filing some of the plastic from the area where they would have hit the Octavo chip. Was simple and the headers now sit flat.
So what did you decide the best option is? I’m sort of torn between a socket that you could push wires into like a solderless breadboard and something to attach a ribbon cable to, which would go to solderless breadboard or vectorboard a few inches away. There was a statement somewhere about having a socket (not pins) on the bottom of the board so when you set it down it isn’t going to short out. If you could get really long pins, like for wire wrap, you could have sockets on the bottom and pins sticking out the top, so you could do both. There’s plenty of room on the bottom for the socket and the pins could stick past obstacles on top. I’d like to get something ordered, but I’m not so good at desoldering as I used to be so I probably shouldn’t change my mind later. Tried Newark?
I was able to fully seat these female headers on top without issue.
https://www.adafruit.com/product/598
