So I did all the steps to have internet via usb from windows 10:
1- I did the sudo route add default gw 192.168.7.1
2- I enabled internet sharing within my network and manually set the ip for the usb connection.
3-I added nameserver 8.8.8.8 nameserver 8.8.4.4 to /etc/resolv.conf
4- I also added files to root and /etc/init.d so I wouldn’t have to do this at every reboot
5- I also did the necessary chmod and symbolic links commands
So after this I reboot and I had internet, and to make sure, even reboot my note and pocket again, and still had internet, after a few days, the internet is one and all the files and setup are still the same.Does anyone have an idea of what’s going on?
Sorry it took me a while to answer. Nothing happens and if I use ctrl+c it outputs 100% packet loss
for both of them.They can transmit but not receive.
Hi, so I disabled internet sharing , rebooted both my machine and pocket, then enabled it, did the ipv4 configuration for the usb connection, rebooted the pocket again and now it works. I don’t if it helps much figuring out the DNS problem. I didn’t modify anything that I already had ready in pocket, only the things I had to do on windows side.
