Hi All
I’m starting to delve into this
can someone please advise how can i connect USB-C Breakout board to PocketBeagle
Type-C has two more pins.. CC1 and CC2 which help determine
orientation. Whereas the PocketBeagle is only USB2.0..
https://www.sparkfun.com/products/15100
Connect each CC* pin to gnd with their own 5.1k resistor
Another choice:
Adafruit USB C Breakout Board - Downstream Connection PRODUCT ID: 4090
Digi-Key Part Number 1528-2873-ND
Instructions at
https://www.adafruit.com/product/4090
It already has the two resistors on it, that Robert referred to.
— Graham
Nice! Yeah, that would be much better..
CC1 & CC2 pins from USB-C that you mentioned, which pins on the breakout board of pocket eagle so I connect them too
You don't connect them to anything "on" the PocketBeagle.. Take a
look at your breakout board, as we don't know which version you have..
Just make sure CC1 and CC2 have their own 5.1K resistor tied to Ground..
